What's up with the Junction Block/Horn Relay $$$?
My horn is not working, so I figured I'd walk down to NAPA (3 blocks away!) and pick-up a New Horn Relay/Junction Block for my 1964 Cutlass. Didn't have one and didn't show one listed(part#),they said they would check for me.(they were busy at the time.) I went home to search online and found that they range from $40.00 - $99.00! Is that correct? A horn relay for a 64 Chevy is $9.00-$12.00. Am I missing something? Does anyone have a part# or a crossover?-Thanks Dan
GTOver-priced!
I am not concerned about original as much as I am functional. I have everything else electrical working on the car now,except the horn and back-up lights.
I don't have any Oldsmobile manuals yet, is there a schematic for the horn relay somewhere online I can look at? I have a wiring diagram, but it is not as detailed as I would like. -Thanks for the replys! -Dan
The 64 manual is a 5-volume set, though you might find Vol 4 separate. It includes electrical, heater/ AC, and instrument panel.
Try unplugging everything and cleaning all the connections good, from horn relay to the horns. Use contact cleaner and a wire brush. Also- try grounding the small black wire on the plug. That wire goes to the horn button. If horns blow by grounding it, either the relay or the horn contact on steering column is bad.
You can make a parts store universal 12V horn relay work, it's just that the OE type incorporated everything in one unit. Run a 10 gage wire from the battery cable post on your original relay to the 12V term on the universal type relay. Green wire on the plug goes to the horn or load terminal, and the black wire in the plug goes to ground or horn button terminal. I'd use jumper wires so that when the day comes you find an OE type cheap, you haven't buggered any wires.
You can also take the horn bar off the steering wheel and clean the horn button contacts on it- sandpaper can work wonders here. Worst to worst, take the wheel off and clean the brass slip ring at top of column, and check to make sure the wire hasn't come loose from it. That spray can contact cleaner/lube is great stuff!
All kinds of tricks to try before shelling out the cash for the correct relay. Can ya tell I've been down this road before? on a 64 and a 66 fullsize Pontiac.
Thanks Rocketraider! I have run continuity checks and cleaned everything with CRC electrical contact cleaner,tested both high and low horns seperately(both work!), the Horn Relay seems to be the broken link in the chain. I appreciate the help! - Dan
mphyle0927
November 5th, 2013 10:03 AM
