Sport Steering Wheel horn plunger..
I am not 100% sure what its called but its the contact between the button and the column. Its not the same as a regular steering wheel with the spring and the spade connector, I think its some sort of plunger deal.
Its for a 1981 Delta
I hope someone knows what I'm talking about.
John
John
Hi John
I think this is what you need. They're on ebay all the time. I've got step by step photos of removing a sport wheel on my photobucket site. The link below is it. Let me know if you have any questions. John
http://s90.photobucket.com/albums/k2...el%20Assembly/
Yeah I did some research last night. They all LOOK the same, however not many are listing for Oldsmobile. They are rather cheap though. $6.50 on Ebay so far, but they didn't list a part number for me to research.
I'll keep digging.
John
I'll keep digging.
John
http://www.gmpartsdirect.com/results.cfm
You can search any GM part # and find if it it still in the GM parts chain, it will not tell you if some dealer has it in stock, that info needs to be searched by a dealer.
I keep 1 or 2 of these in my parts stash.
They look the same 'cause they are the same. Part #474102. Go here
Sadly all the the dealers in my area sell at full retail and offer NO discounts. I can still get parts cheaper from GMparts even with the HUGE shipping charges.
John
I have a question for 2blu442...The sport wheel and horn on my 72 works, but has a couple issues. The horn button can't be adjusted straight. It only turns so far, then will fall off if pushed further. Plus, I had to run a jumper wire to the horn contact to make it work. I bought the contact, horn button and all related parts from Fusick and use on an original factory 72 wheel.
I noticed on your pictures that the canceling cam (?), the white shaft that sticks out at about 2:00. If memory serves me, mine is located on the left side. Any ideas, and does that matter?
Terry
