View Full Version : Parts Wanted
- Alero 2DR Right Lower Clean Patch Panel
- 15x7 SSlll wheels
- WTB: 1970 442/w-33 carb 7040257
- WTB 1/4 inch fuel return line | 1972 442
- 71 Cutlass Convertible decklid
- Wanted: 71 Cutlass Supreme decklid
- pearl 70 door panels
- 1970 Cutlass Supreme Convertible Black Center Console
- Need driver's side exhaust manifold.
- WTB 1956 Olds '98' trim
- 72 cutlass vapor canister bracket
- WTB: '71 Delta 88 Royale Radio Bezel/Center dash cluster
- 1968 Olds Delmont 88 Convertible quarter panel
- 1968 Delta 88 Rear Window Trim
- 70 Supreme molding and ?
- 64/65 Console
- Remote driver side mirrior
- TCS solenoid
- WTB 70-72 Floor Shift Tilt Steering Column
- 73 "S" Bumper filler & 1/4 window stainless
- 1968 4 speed linkage needed.
- 1100879 alternater wanted
- AC Mounting Bracket
- '72 OAI Hood
- Power steering cap and fitting
- g body cruise control parts
- 1972 Cutlass Rear End Wanted: Near Chicago
- Need disc rotors for 1968 Delta 88.
- 1966 442 or Cutlass
- Looking for a 400 G Block Engine for a rebuild
- Looking For a 400g block engine for rebuild
- P/side door and fender 76 Cutlass Supreme
- 1970 Cutlass lower air deflector
- 1990-1991 Cutlass Supreme Sedan Tail Panel
- 84 Hurst
- 72 Cutlass Headers
- Pre-76 350
- Window regulator
- Need SS1 Wheel with trim Ring
- 72 442 AC hose, or a set of hoses
- 72 cutlass350 4bbl cruise control
- omega trim 1973
- '48 98 Vent Door Arm Needed
- kickdown switches
- Back-Up Light delete plate for 56 Holiday 88 Wanted
- Radiator tags wanted
- WANTED: 9.375 full size gear set
- '64 Dynamic 88 PARTS NEEDED
- 1971 Cutlass Power Quarter Window Regulator
- mirror brackets for 65 cutlass
- Need 4 of This Item (?) for '69 H/O, 442, Ctlss
- Wanted 1967 442 Dash Bezel insert
- 71 rear bumper
- 1967 442 400 E engine
- WTB: 61 to 64 Olds F/S 2.56 Differential/3rd members
- WTB: 57/58 Olds drum to drum rear end
- ISO: 4-Barrel Intake Manifold and Carb for '71 350
- WTB, 1967 Cutlass inner park lense
- Needed: Seatbelts for 1969 442
- Trunk light assy and switch with bracket
- 400,425,455 tining chain cover
- Wanted CE or OG radiator tag
- nos positive battery cable
- 70-72 glove box light
- 70 442 parts
- 1968 Delta 88 Peak Molding
- 66 AC fan blade needed
- Ignition parts wanted
- 1970 Left fender
- Needed: Neutral Safety Switch 1969 Olds 442 floor shift
- #6 Alternator pulley
- 68-72 convertible frame
- wtb: 62 Starfire hood letters and gunsight
- INSIDE DOOR HANDLE PULL 66 toro
- WtB: hubcaps for 1967 98
- 1968-1977 A/c rear compressor hose bracket/tie bar needed
- Antenna Spacer
- 1970 Cutlass Wheel Moulding NOS 230925 Front LH
- 1964 Dynamic spindle
- 455 bare block
- Need a hood
- Wanted, 69w scoops
- 70 NOS Hood Pins
- 67 442
- Wanted 1975 4 Door Cutlass parts
- NOS '68 442 Convertible Quarter Panel
- 1964 nintey eight body mouldings
- Front fender seals
- 1964 cutlass mirrors
- 1959 or 1960 trunk mat
- 1970 442/Cutlass Front Fenders - Wanted
- WANTED : 1961 f85 manifold intake & nipple
- WTB: Front disk setup for 72 cutlass
- WTB: 2 groove (a/c equipped) power steering pump pulley (455)
- Convertible rear armrest
- 66 cutlass windshield wiper clip
- Wheels
- 455 Lifter Valley Shield
- Rear bracket, 8 track player - 1970 Cutlass
- 70 Trunk Release Button
- 67 drive shaft
- 1981 - 1988 Cutlass Rear Window Glass Trim Molding
- 1964 Dynamic 88 emblem
- 1964 Dynamic 88 Celebrity Sedan with H.O. 394
- Wanted: 1969 Delta drivers side tail light lens
- 1977-81 Holiday 88 interior
- 71 442 carb 7041253
- carb linkage
- 67 dash
- worked once 67 442 headlight bezel
- '67 trunk lid
- 1968 442
- Fan shroud for 67 442 with a/c
- 1970 Olds 442 Convertible Frame/ Chassis Wanted
- 2⅜" plastic door molding clips 1967 CS
- 1988 Oldsmobile Toronado Parts?
- Sail panel 72 cutlass
- '47 Series 60 Headlight Ring
- 59 98 rear bumper
- Convertible rear seat
- WTB 15” SSII wheels
- Ignition and door locks 1970 Cutlass
- Wanted 67Cutlass Radio Antenna
- 1970 AM FM Stereo and 8-Track
- Wanted: Headlight Retaining Ring
- Wanted 70-72 nos washer bottle
- Sport Wheel Parts
- Wanted 1968 Oldsmobile am radio (442)
- Throttle cable/ tv bracket
- WTB: Speedo cable #6454859
- 1967 Delta rear bumper fillers
- sun visiors needed
- WTB 1948 oldsmobile 98 Driveshaft
- central console 442 1971
- ram air hood and both fenders on 442 1971
- 1970 rally I wheel LZ 14x7
- 1960 dynamic 88 alt. Bracket
- 1966-70 PO5 SS1 wheel needed
- 404847 Pump
- 1966 67 wagon tailgate power window parts
- 67 headlight bezels
- 1962 F85 brake drums
- wanted W-31 Balancer 1970
- Choke assembly
- Driver side red inner fender
- 1972 Cutlass Supreme Bucket Seat Tracks
- 1972 Cutlass Windshield Wiper Motor
- Deluxe seat belts
- -65 Cutlass accident
- Steering Column
- 4-Speed Console Parts
- Wanted, One 1970 SS1 Wheel or complete set.
- "Battery Tray, Battery Hold Down & Battery Rod Bolt needed for a 1973 Olds Cutlass".
- Need a 394 Flywheel
- 67 Cutlass Sheetmetal
- 1972 Delta 88 Flip down license plate holder
- 1972 dash pad
- 1967-69 auto console doors
- 66 Cutlass Vert rear courtesy lights
- 1983 olds hurst interior
- 66 Olds L69 tall oil filler tube
- Wanted/ trade for 68 442 bucket seats
- 1971 Cutlass Supreme Part Needed for door panel
- Oldsmobile Fuel Economy Meter
- 72 cutlass s
- 14” dog dish hubcaps
- 74 cutlass front marker lights wanted
- power steering pump cap
- WANTED: 70 442 Gold Kick Panels
- WANTED: 70 442 rear window windlace in GOLD
- Wanted: 1969 Wiper Motor
- Headlight Switch Knob, '69 H/O
- Wanted 292 B-R Embossed Coil
- Power steering reservoir cap
- 1981 cutlass cruiser power seat transmission
- '69 H/O Outside Mirror Glass
- 1972 Cutlass Air/Heat Ducts
- 1956 Rims
- 1965 442
- clutch hold in relay
- Wanted: pristine 68 black seat belts
- Wire wheel tool.
- 1968 cutlass s convertible trunk lid
- Speedo Housing
- 1968 442 Distributor - for trade
- WTB: Mini starter for 455
- 1984 old custom cruiser wagon
- fiberglass hood 69 Cutlass
- Pistons for 425 bored .040
- Need “T” piece for automatic shifter, ‘69
- '69 1100853 Alternator
- Please help! Glass needed!
- Wanted 70 Cutlass Sport Bullet Mirrors
- 70 Cutlass S seat cover
- 70 O.A.I. air cleaner base
- Starter drive
- 53 98 Rear Fender Support Bracket
- WANTED: 1950 Olds 88 Windshield Washer Nozzles
- Passenger Side mirror
- WANTED>66-68 OEM Hurst 4 Speed Shifter Linkage
- TCS solonoid and fan for 1970 455
- Wanted 68 cutlass vinyl top moulding
- Wanted: TH400 Kickdown switch 1969 cutlass/442
- NEED 1966 Vista Cruiser Tailgate Moldings
- WANTED: 70 442 Temp Sender - Original
- 1969 442 cigarette lighter element needed.
- Door hardware
- 1955 Oldsmobile rims:
- WANTED: 1972 rear lower boxed control arms
- 69 cutlass washer reservoir
- WANTED: 70 442 RH Defroster Duct
- 1971 Cutlass S driver side grill NOS or excellent
- 70 - 72 Cutlass A/C Duct Work
- Power window regulator
- 64 Cutlass parts
- 1959 Transportable radio bracket
- 1956 88 front and rear bumpers
- Drivers side door lock switch 84 custom cruiser
- Need SMALL 330 Harmonic balancer bolt.
- Walker tail pipe tip #35614
- Left rear wheel opening molding 1970 Cutlass
- 7029251 carburetor.
- 1976 Cutlass Supreme backup light lens
- radio delete plate
- Need 2 Rear 1969 Cutlass Tail lights Housings!
- 72 cutlass stove pipe
- Wanted 68 442 seatbelts
- WANTED: 70 442 Jack hook and Mechanism
- WTB: Hood emblem for 61 Dynamic 88
- 455 Crankshaft
- WANTED: 70 442 Air Dam and lower console base
- Correct Carb Needed
- looking for 1970 tail light panel
- WTB: grille emblem to fit 64 cutlass
- Wanted: 8 track rear brace
- 10 bolt rear end
- anybody selling a alternator w/ac for 1971 cutlass
- 1973 vista cruiser or cutlass headlight bezels and trim
- 15" Trim rings
- Fuel emission part
- Gumpp dealer trunk emblem wanted
- Looking for ash tray door/ 69 Cutlass S
- alternator and power steering brackets
- 69 Delta 88 Rear Bumper
- 1983 Olds 98 Regency ISO body parts
- Damaged OAI Hoods 70 & 71/71.
- Vista Cruiser Quarter Panels
- 72 Supreme rear window reveal
- Looking for 1961 era Starfire Interior
