Pre-76 350
Old Nov 5, 2018 | 11:03 AM
csstrux's Avatar
Pre-76 350
I am in the Vegas area looking for a running non windowed main 350 for a project I have. Leads are appreciated.
Old Nov 5, 2018 | 01:56 PM
cdrod's Avatar
Rodney
I have a '71 350 in a Cutlass Supreme that is completely bone stock from the Q-jet to the oil pan. The car is not running so a rebuild would be in order, and I'm in Houston, TX. Not too far from OK but a good drive from NV.
Old Nov 22, 2018 | 09:37 PM
csstrux's Avatar
If I were still in Shawnee that might be worth the huff. Looks like I need to edit my location. I keep forgetting to do that... Thanks for the heads up though.
Old Nov 23, 2018 | 06:55 AM
oldsmobiledave's Avatar
1976 engines use solid main webs so your title should read pre 1977 wanted.
good luck
Old Nov 23, 2018 | 01:02 PM
2blu442's Avatar
Hi Chad
I've got some 1968-77 350's up in Oregon. Not sure if I have anything that runs good enough to use without rebuilding. But if you strike out closer let me know. If you could wait a few weeks I might be able to set something up to run and get a compression test on. John
Chuck Cole
Sep 25, 2019 02:23 PM
brandon reynolds
Oct 3, 2018 05:28 PM
travisbeamon
Sep 3, 2012 11:02 AM
xplicit666
May 21, 2009 05:54 PM
