"Battery Tray, Battery Hold Down & Battery Rod Bolt needed for a 1973 Olds Cutlass".
Old Oct 1, 2018 | 01:03 PM
patshotrods's Avatar
Pat
Question "Battery Tray, Battery Hold Down & Battery Rod Bolt needed for a 1973 Olds Cutlass".
Battery Tray, Battery Hold Down and a Battery Rod Bolt needed for a 1973 Oldsmobile Cutlass Supreme. 1973 thru 1977 should be the same.
Please let me know what you have. You can send me some Pictures thru this Thread, PM me or you can get in touch with me thru my E-Mail:
patshotrods@comcast.net
Thanks for your time...
Please Advise...
Old Oct 1, 2018 | 01:21 PM
76olds's Avatar
Hookers under Hood
Depending on what battery your using .
Fusicks sells a stock battery tray and hold down hardware .
Eric
Old Oct 1, 2018 | 02:55 PM
zodiacblue442's Avatar
If you're worried about 100% correct, a 1973 Cutlass battery tray is a one year only part.
Not sure if mounting locations are the same for the later battery trays. Fusick does sell a reproduction battery tray for 1974-1977. Technically 1974 is a one year only part too.
Old Oct 1, 2018 | 03:36 PM
76olds's Avatar
Hookers under Hood
Gary is rite on the period correct battery tray . 73-74 are a one year only if your looking for factory correct . Fusick doesn't list the 73-74 tray but the 75-77 can be made to work, depending on what battery you are using .
They list the battery hold down ( crossbar ) 73-77 though
Hope this helps!
Eric.
http://www.fusickautomotiveproducts....ges/HD7387.jpg
http://www.fusickautomotiveproducts....ges/BT7577.jpg
Old Oct 2, 2018 | 09:17 AM
Pat
Thanks Gary and Eric!
JukeboxJohn
Mar 29, 2017 01:04 AM
stevengerard
Sep 14, 2014 08:01 AM
69'442
Feb 23, 2012 04:46 PM
Railguy
Sep 28, 2010 06:25 AM
Kaline
Feb 5, 2008 08:08 PM
