PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. H-Heads
  2. 1950 olds emergency brake
  3. 70-71 Evaporator Inner Cover
  4. 72 cutlass S Core support
  5. 1970 Dash pad capture clip
  6. Dual gate shifter mounts
  7. 68-69 Toronado quarter panel side marker lamps
  8. 1962 88/98 Rear Bumper
  9. 15 inch "dog dish" style Oldsmobile hub caps
  10. wanted nos 1972 442 grills
  11. '78 Cutlass Rally dash cluster
  12. 70 W-30 Vacuum Advance Canister
  13. 12 bolt o-axle housing
  14. WTB- AC Ducting Under Dash 72 Cutlass
  15. WTB Wheel Trim Rings: ‘61 Super 88 14” — See Pics
  16. WTB: 80-84 98, 80-85 D88, or 80-87 CC Blue Litter Can Kick Panel
  17. Green Floor Mats
  18. anyone have this part? 1965(?) 4 speed bracket
  19. WTB '64 - '65 Cutlass trunk lid.
  20. NEED 67 Cutlass Trunk Deck Torsion Rods
  21. 1964 Olds Dynamic 88 - Hydra-Matic Manual Rod For Shifting Gears
  22. Water pump pulley
  23. WTB O-Type #673 posi carrier
  24. shifter detente bracket 69 Cutlass, th350, w/console
  25. Dash Pot Bracket
  26. 69 Cutlass hood tongue emblem
  27. Delta 88 ss111 snap on caps
  28. Edelbrock performer 2151
  29. 70-72 Convertible Door Panel Top Rails
  30. 1965 Cutlass Hood Chrome spear
  31. 1957 oldsmobile jetaway transmission filter
  32. 1967 titled 442 Sport Coupe Shell with doors/trunk lid only
  33. 70 Sport Coupe Deck lid
  34. Batten header to fit my friends G body.
  35. W27 cover / rear
  36. 71 w30 no AC water pump
  37. 1970 442 rear cut out bumper
  38. 1970/2 442 Pass Side Rear Window Trim wanted
  39. 371 block
  40. 1970 O.G. Trans.
  41. 7042953 Rochester Quadrajet
  42. 71 vista cruiser rear glass sash
  43. TH 350 end Floor Shift Cable attacment arm
  44. Bucket Seat Back
  45. 1970-72 Post door wanted
  46. 1971 Fenderwell large washer bolts
  47. 1972 alternator 1102441
  48. Do not post response-message only
  49. 70 Olds 442 original speakers
  50. 1964 Dynamic 88 Need A Part
  51. Wanted 71 442 starter
  52. Quadrajet primary rods
  53. #57 bulb instrument cluster sockets
  54. Batten header flanges
  55. 57 Olds J2 tri power wanted
  56. 1984 delta 88
  57. Vinyl top trim
  58. Wtb 15x7 rally wheels
  59. Wanted 1966 tricarb throttle rod
  60. w27 10 bolt cover
  61. Cutlass horns
  62. Looking For a Working POA Valve For 70 442
  63. Vista cruiser two tone trim
  64. Wanted hood hinges
  65. 73-77 swivel bucket seat belts
  66. One Bucket Seat Cover Wanted
  67. 1995 Cutlass convertible parts needed.
  68. 69 cutlass steering column etc.....dash stuff
  69. 72 3 port CA built charcoal canister
  70. 68 69 Olds 400 pistons .040 wanted
  71. WANTED 1949 Oldsmobile T Trunk handle and base
  72. 74 Oldsmobile Omega front bumper
  73. 1968 hinges
  74. 394
  75. 72 Cutlass ‘S’ Ignition Buzzer Switch
  76. 1965 Oldsmobile cutlass inner fender needed
  77. ISO 66 Dearborn/Phord 3 Speed Toploader Transmission
  78. 70-72 Vista Cruiser tailgate emblem
  79. 1970 W30 parts
  80. 64 cutlass parts wanted
  81. Anyone coming to OCA nationals with these items?
  82. 455 cam bearings
  83. Wanted: 1964 Front Bumper Bars
  84. 1957-1958 371 v8
  85. Parts wanted
  86. SsII rally’s 15x7 and 15x10 set
  87. Quadrajet part
  88. Wanted 89 Custom Cruiser LR wheel opening trim
  89. ISO Front Bumper '79 Cutlass Supreme Brougham
  90. ISO 66-69 OEM Oldsmobile 4 Speed Shift Rods & Arms
  91. Looking for source for short pins.
  92. Looking for 1975 Cutlass passenger side exterior door handle
  93. 70 442 carb.
  94. '67 Bucket Seats
  95. Looking for 4 15” SS rims for Cutlass or 14” Keystone Rogue
  96. 1954 LOW Rocker moldings for an 88
  97. 68 cutlass vinyl top molding needed
  98. Single 330 #1 head
  99. WTB "C" Heads
  100. 1972 cutlass hood latch assembly
  101. Olds 455 Aftermarket Intake Wanted!
  102. 1 15x10 SS1 Wanted!
  103. 455 manifolds needed
  104. SSi rims
  105. I need a good fuse box
  106. 1956 Olds windshield
  107. Looking for 1969 holiday coupe passenger side door
  108. Rocker shaft brackets 1964 98
  109. 66 cutlass rear body panel
  110. 1970 442 arm rest backing plate clips
  111. 1966 Cutlass Front Bumper
  112. Exhaust: Left Tailpipe. '79 H/O
  113. Wheel hub 98 1966
  114. Floormats wanted
  115. 68 442 Cast iron manifold
  116. factory trunk light wire extension
  117. tilt steering column
  118. 70 Cutlass front brake drum/hub assembly
  119. Wanted: 1970 NOS Headlight Housing - LH 404749
  120. 72 cutlass inner fenders
  121. Suspension braces
  122. 69 Hurst Cruise Control Rod
  123. 442 grills
  124. looking for a working 70 cutlass front speaker
  125. WTB: 1971 442 Grille Numbers
  126. 91-92 OCC aluminum wheel
  127. Broken throttle linkage switch 1967
  128. Looking for Seat Covers for 1971 Cutlass
  129. 1984 olds 98 grille needed
  130. 68/69 moldings needed
  131. 1968 delmont 88 rear quarter
  132. 4 Core Lower Radiator saddles 71 Cutlass
  133. looking for cast iron intake manifold
  134. 66-67 Toro air cleaner housing
  135. cam bearings
  136. 67 Cutlass R front wheel opening trim
  137. WTB 1970 442 Driver side front grille
  138. Big block springs
  139. 68 442 glove box lock
  140. WANTED: spark plug and coil wire
  141. WTB 1970-72 cutlass body/shell
  142. 1970-72 A Body wagon rear window escutcheon
  143. Wanted: 1966 442 4 blade water pump spacer
  144. need a rim for a 68 Toro
  145. 1977 Cutlass DS Door Glass WTB
  146. 1 oldsmobile scripted valve cover
  147. Converting 1970 98 to Dual Exhaust need W33 style hangers
  148. In search of Hurst Hood Scoop, Gbody cutlass rear spoiler and Rally Wheels
  149. WTB - 1970 442 W and Z exhaust manifold
  150. WTB - 1970 442 rear bumper with cut out
  151. WTB: w/p pulley crank pulley & hub air cleaner 1979 403 trans am engine
  152. GM OEM 1970-72 Olds Vista Cruiser Roof Luggage Rack
  153. ISO: Early 400/425 7" rod
  154. 1970-1972 Rally Pack Tachometer Wanted
  155. 1969 442 Clutch Fork
  156. 66 cutlass sail panel clip
  157. 68 442 Stainless Trim and Redlines
  158. '61 f-85 gas tank needed
  159. Water pump pulley
  160. 1970-72 cutlass center console lower section
  161. 67 Center Link ( drag-link )
  162. Wanted 66 442 inner fender battery tray patch
  163. Need an Engine Wiring Harness for a1984 Hurst Olds
  164. 1964 f85/cutlass convertible deck filler
  165. 71 Toronado dipstick tube
  166. 215 cu in valve covers
  167. Fuel pump needed
  168. 71-72 Original Type Heat Control Valve
  169. Looking for 8-track brace
  170. Shorty Headman Headers
  171. 67 cutlass red park brake lens
  172. WANTED: 1971 442 Grille
  173. Heat shield, starter, BBO, hi torque
  174. 63 cutlass transmission mount
  175. Idle Stop Solenoid, Brackets/Bolts to Q-Jet, harness for 72 455 and compatible
  176. 7042250 Carb wanted (and possibly intake as well)
  177. 1966 cutlass front drivers turn signal assembly
  178. wanted 1970 Hood pin in survivor quality.
  179. WTD: 67 Cutlass NOS headlight switch
  180. Correct 72 only T-3 sealed beams
  181. 1963 oldsmobile dynamic 88
  182. 69-70 Olds 98 defroster defuser needed asap
  183. Kent Moore J-23119
  184. 1973-1975 RR Wheel Opening Molding
  185. WTB 1969 N34 steering wheel
  186. KG single groove power steering pulley
  187. WTB 70-72 lower rear window trim
  188. Left Side Exhaust Manifold
  189. Looking for a 84 Hurst wheel
  190. 78-88 G body door weatherstripping
  191. WTB: 73 Cutlass Supreme dashboard speaker cover brown
  192. 1965 Jetstar 1 seat belt, black
  193. WTB: 1 notched valve cover
  194. WTB: 1970 98 Blue Rubber Floor Mats
  195. WTB: 307 bracketry
  196. Wtb: 1951 nos ribbed backup lights
  197. 1965 f85 parts needed
  198. 1966 Cutlass/442 Hood Latch/Assembly
  199. Inlet valve for cabin air for non A/C 1970 Cutlass
  200. 67 442 passenger side headlight bezel
  201. WTB: 78-87 G-Body Power Drivers Bucket Seat
  202. Looking for a set of SSIs. Have a set of SSIIs for possible trade
  203. 1965 delta 88 core support and R F fender
  204. power steering/alternator brackets for ac big block
  205. 69 Cutlass Fender Trim Clips
  206. 1970 442 Evaporator Case
  207. Looking for a '69 Engine Lift Hoop
  208. 1970 W30 F heads
  209. 1966 Cutlass/442 hood hinges
  210. 1963 S88 air cleaner body
  211. RH 70 cutlass /442 fender
  212. 1956 324 starter
  213. 66 67 Cutlass Headrest Hardware
  214. WTB - 1970 442 cutout rear bumper
  215. Red Fender wells
  216. Exhaust manifolds
  217. 1970 350 left side manifold
  218. 65 Cutlass power steering pump with reservoir
  219. 1971 washer bottle w/cap
  220. WTB - 1970 442 black dash pad
  221. 1967 cutlass bench seat with arm rest
  222. 67 400 w/ air pulleys and carb
  223. Wanted 1965 olds 442 frame
  224. 65 cutlass
  225. 1965 olds 44 steering wheel center cap and assebly
  226. 1966 Delta 88 Fan Shroud Needed
  227. 1969 cutlass/442 passenger front fender
  228. 1971 oldsmobile cutlass (outside) tail light lens upper
  229. In Search of a 200r4 Transmission
  230. Edlebrock Victor Intake #2810
  231. 67 cutlass 442 hood, please?
  232. Floor shift Column needed for a 68
  233. 71 drivers side white door panel
  234. 1970 Cutlass NOS parts wanted
  235. Wanted: Edelbrock small block intake
  236. 1984 Olds 98 Side Marker Lamps
  237. Wanted: Front Marker Light Lenses
  238. 1970 Cutless Supreme
  239. 70-72 Cutlass Center Console (2 of them)
  240. Wanted: 1970 Burlwood Grain Factory Pieces Dash and Console
  241. 1968 442/Cutlass Post Car Trim
  242. 64 Cutlass Water Pump
  243. WTB: Manual steering gear 55' Olds
  244. 81-88 Cutlass Tail Lights
  245. 1964 cutlass front bumper brackets
  246. NOS Hood Insulation Pad
  247. 68-72 Cutlass / 442 Bucket Seat Cores
  248. Just joined and am looking to buy a nice 1956 Olds 88 rear bumper...thank you.
  249. Looking for a ugly rear bumper for a 1965 cutlass
  250. 70-72 heater switch knob
