Floor shift Column needed for a 68
Old Apr 29, 2022 | 03:07 PM
Amplitude's Avatar
I'm looking for a good condition or even rebuilt column for my 68 442. This is a non-tilt manual trans car, although I would entertain the idea of a tilt column if the price was right.
After messing around trying to get some weird issues ironed out with mine, I've come to the conclusion that somebody cobbled it together from multiple cars, with not all of the correct parts...
Rather than waste any more of my time on it, I just want to replace the damn thing, and get my car back on the road.
Thanks,
Old Apr 29, 2022 | 04:12 PM
oldolds88's Avatar
you have pm.
Old Apr 29, 2022 | 04:50 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
https://classicoldsmobile.com/forums...l-misc-161380/
Old Apr 29, 2022 | 05:08 PM
lunaboy's Avatar
The Rocket Astronomer
I just listed one on ebay a few days ago , here is the link:
https://www.ebay.com/itm/334416298019
Old Apr 30, 2022 | 02:30 PM
Amplitude's Avatar
I had already seen and responded to your ad thread.
-I’ll send a PM in just a minute
Old Apr 30, 2022 | 02:39 PM
72455442RA's Avatar
thanks for the ad bump DR OLDS
my red column is still available...
Updated my ad also !
Scott T
Old Apr 30, 2022 | 02:51 PM
Amplitude's Avatar
Scott T
Apologies, doing this from my phone which I’m not used to. Normally I have multiple PC monitors in front of me so I didn’t catch that Dr Olds wasn’t the owner of the ad linked.
Scott T, I’ll shoot you a PM in just a minute.
Old May 2, 2022 | 06:26 PM
Here is how the Ididit tilt column looks in my 68 Vette. Very high quality well made assembly.
The steering wheel adaptor is billet and the shaft is raw. I clear-coated both. The contrast blends well in the sun.
Get a new firewall seal and rag joint kit. Fusick Year One for both.
The wire harness connector must be a generic shell GM used for a few years as 1/2 of it is empty and can be trimmed down for a cleaner install.
The horn contact needed a minor modification to work(someone or I should tell Ididit this). I can detail that if needed.
The threaded holes in the billet adaptor are a different thread count compared to the OEMs. (I should tell Ididit that too). Source quality SS taper head screws that match the threads in the adaptor from a good hardware source. Home Deep Hole generally sells chineasium grade -8 fasteners. Not what you want holding a steering wheel on.
The other trouble spot was the pins in the box side adaptor. See the new shiny pins by the clamp bolt? You need to grind off the heads and drift punch them out. The kit comes with new pins. The joint instructions made no mention of this. Grind carefully so you don't damage the adaptor.
Not sure how much of this applies to a 68 Cutlass but I'll bet 99% does.
shamusj
Apr 27, 2021 05:45 AM
distributorguy
Jul 17, 2016 10:16 AM
allyolds68
Jan 28, 2016 08:21 AM
67442nut
Mar 7, 2013 07:02 PM
Bitburger
Dec 30, 2012 04:49 PM
