View Full Version : Parts Wanted
- Long Shot - WTB Arm for 66 Sidewinder Tach
- 1967 oldmobile cutlass 442 front license plate bracket
- Muncie
- 1970 Aluminum Thermostat Housing
- Glovebox Lamp/cig lighter
- Wheels SSII or hub cap 15" x 7" wide
- 399402 kb crankshaft Pulley
- 73 cutlass supreme interior parts
- 69 442 rear power antenna set up
- 65 cutlass seat
- 1968 Cutlass Left (Driver) Fender Eyebrow (Upper) Molding
- WTB brake and clutch pedal set up..
- Hurst Dual Gate Brackets
- 455 Piston +0.040"
- Olds Cutlass 1966 AM radio knobs
- 69 bucket seat head rests
- 70-72 cruise bracket
- Pillar Post Weatherstrip Chrome
- 1971 Dual Gate Shifter Cable
- Hood for 66 cutlass/442
- Retractors for 68 to 72 GM lap belts for use with shoulder belt
- 68 Cutlass core support
- 1958 Oldsmobile
- 1954-56 324 Engine V8
- 72 cutlass supreme package tray windlace end caps
- Wanted - 1967 Cutlass Inner Fender
- Need a 70 4 speed bench seat shifter
- 1972 vista cruiser parts
- 1956 trunk emblem
- 65 vista cruiser part search
- 1967 Delta 88 -parts
- '63 OLDS F-85 bumpers needed
- NEED! 215 V8 Parts
- 67 Cutlass Louvre hood
- 11968 cutlass S
- 1967 Olds 88/98 425 exhaust crossover pipe
- Alternator bracket for a 64 cutlass convertible.
- 1970 442 grills needed
- Rally rim
- Parts for a 66 442
- Need help
- 425 crankshaft
- 1964 cutlass convert interior parts
- rare parts for germany needed
- Need tons of parts for a '77 Cutlass Supreme Brougham 4-Door
- 1979 Cutlass Cruise Control Rod Needed
- Pistons
- Wanted Ram Air OAI Lid
- WTB automatic floor shifter handle, 71 cutlass (and other years
- Plug wires with vintage look.
- 1970 Post Coupe Stainless Trim
- WTB Hydramatic for 1952 Super 88
- 1964-65 two tone paint molding
- Door panels for 1971 Olds 98 needed!
- 69 cutlass dash plastics
- 1970 442 Cutlass sport mirrors
- Driveshaft
- 1972 Cutlass Steering Column w/o shifter
- 69 and 70 window parts needed
- Blue seat belts wanted
- 67 Cutlass/442 Tail Light Bezels and misc lenses
- 65 to 67 flywheel
- Looking for 66 442 Power Seat Track Parts
- Oldsmobile SSII or SSIII 15" wheels
- Front Fenders for 1970 442
- Frame mounting bracket for a proportioning valve needed
- WTB 1949 Olds Deluxe steering wheel
- 1970 olds 98
- 1967 442 400 flywheel
- 67 "OLDSMOBILE" trunk trim
- 1957 Olds 2 dr hdtp exterior door handles
- 1961 olds latch
- 7040258 Carb needed for '70 442 W30 auto
- 1986 Cutlass Air Cleaner Housing
- wheel opening moldings
- 66-68 cutlass flowmaster downpipes
- 425 Dipstick tube
- Seat Belts
- 1964 cutlass wheel housing cover
- 1970 Olds 98 Fender patch panel
- Needed 68 Cutlass hood latch
- WTB-original #7040253 70-442 Carb 4 speed
- 1975 455 Hurst Olds Alternator Bracket/Brackets
- 72 cs parts
- Front Bumper & Right Fender for 75 Delta 88
- 69 442 rear power antenna nut
- Grilles for 71/72 Toronado needed badly!
- Clamshell parts!
- I need a th350 2500 stall for my 72 cutlass
- '70-'72 Hood Latch Cable
- Want nos 1970-72 sport steering wheel
- 1966 Cutlass bumper jack foot
- 67 Cutlass hardtop trim
- Wanted 1972 nos cruise regulator #409597
- 1970 442 bumper bracket
- 75 Hurst
- 1968-69 wagon/vista tail light and backup lens
- Mid 70's GM Rubber Trunk Mat
- # 673 posi unit
- 66 442 Steel wheels
- Looking for a good running olds 350 and trans for 84 Delta 88
- 1967 cutlass holiday left front fender
- Harmonic balancer
- 66 Cutlass front fender extensions
- 70 Cutlass S L/R side molding
- ISO non operational 68-72 ticktoc tach for parts
- 1950 2 door sedan
- 455 Brackets, Pullys, etc.
- Delta 88 convertible bezel
- 62 seat belt kit wanted
- Seat belt cover
- WTB gas tank 1964 Dynamic 88
- pitman arm
- Thornton Jr 350 manifolds
- Iso : Dark green seat covers & carpeting & extras
- 1970 Cutlass 442 NOS LH EYEBROW MOLDING
- 70 Cutlass/442 under trunk cross brace
- Courtesy light lenses
- wtb 1970 455 Fan shroud
- 70 455 F heads
- 75-77 hurst hatch t top "T" Brace
- 14" SSII near Chicago
- power door lock actuator
- Wanted 1968 Quadrajet Carb 7028251
- '68-69 Cutlass Washer Reservoir
- trade?
- wanted shift knob bezel 70 442 4 speed
- 70 Cutlass fenders
- Wanted: 1972 Olds Cutlass Supreme Trunk Torsion Bars
- Hey fellow olds owners. I'm new so nice meeting everyone...
- Rear window trim
- 70 Vista Cruiser Parts Needed
- 1992 toronado hood
- Seeking NJ sller of this Ram Air Hood
- Wanted lower control arms 70 A body
- Bucket seats
- Wanted: 455 block or complete engine
- 1985 Olds 88 tail light
- S FL or GA 73-77 Cutlass axle or 79-91 caprice
- 1952 Super Front Bumper Part wanted
- 1970 posi rear
- 1970 442 AC duct work
- Turbo 400
- intake manifold plug on manual brake cars
- 1980 Ninety Eight window trim wanted!
- 1965 Cutlass dash gas gauge needed
- Wanted: 1969 Hurst olds antenna
- WANTED: 71-72 Supreme Trunk Lid
- High side A/C line
- 1964 Cutlass Frame
- black door panels for 1970 f85 Raylle
- turn signal cable
- Raylle 350 bumpers
- Rust Free 67 Fenders
- 83 B/C body turn signal lever
- 68 cutlass radiator core support
- WTB: 1965 Starfire stabilizer bar bracket
- 1938 Touring Sedan
- WTB 1970 442 Air Cleaner Base
- Need 1970-442 MT carb #7040253
- 72 A-body hood latch rod
- 1969 f-85
- 75 Hurst sail panels
- power steering swap
- 1970 Ring & Pinion, 8.6 rear end
- 1970 w 31
- WTB Edelbrock Perfomer 2151 BB Intake
- Wanted: 1 pair of good core big-valve K heads for marine app.
- Cutlass 66 radio knobs
- Looking for a pair of 1967 4-4-2 Headlight Bezels
- 70 sport mirrors
- Rear quarter chrome for 68 442 convert
- 1962 Cutlass Rear Bumper
- Steering Column parts - 68 442
- Wanted 71 Cutlass Rear Moldings (pict)
- Looking for used frame-67 cutlass, prefer SE states
- WTB B85 window moulding NOS
- 1969 cutlass convertible mouldings
- 1956 324 Block or Complete Engine
- gas tank for a 1955 Olds 4 door hdtp
- 1969 ramrod
- Oldsmobile 307 Camshaft Thrust Plate
- 1964 Cutlass Dash
- Looking for 1955 holiday gas tank
- 76 Cutlass/442 seat belt parts
- WTB Street Avenger Carb
- 1968 w30 carb 7028254 wanted
- Wanted 1/2" factory diesel head bolts
- '70 Vista Cruiser front roof glass
- Bucket Seat Tracks
- Wanted-70 Cutlass plastic inner wells
- rear spoiler for 1976 442
- wanted Front Bumper 1969 Cutlass
- 1969 Oldsmobile Delta 88 Steering Column Wanted.
- Sport Mirrors for 1972 Cutlass 442
- Need Door Open repeater.
- Wanted- 394 Olds spark plug wire holder
- 1968 442 passenger door near Atlanta?
- 1972 Cutlass Supreme Trunk Tension Rods
- 1972 Cutlass Supreme Rear Window Moldings
- 1972 Cutlass Supreme B85 Moldings Wanted
- Trim/Beauty Ring
- Grey Armrests for 1960 4dr 88
- Shifter Stick for 1972 Oldsmobile Cutlass Surpreme
- WTB Rally or Rallye Gauges, 1970 Cutlass
- Right Door inner section part
- 1970 Front frame section
- Need a '78 Omega nose and Right Headlight Bezel
- 1992 Custom Cruiser
- Need parts for a 55
- Wanted: 1963 Jetfire parts
- 61-63 4 speed shift lever
- WTB Oldsmobile "A" body amp or case
- 72 Cutlass Supreme back window trim moldings
- 1961 Olds 88 hood latches
- WTB 72' 350 4bbl air cleaner assembly botttom
- 1968-69 4 door/wagon door panels
- 1983 H/O Sand Gray Interior Items
- 1967 Delta 88 4 door roof
- dash speaker cover
- WANTED1994 Cutlass Supreme front Strut Tower Brace
- 62 Cutlass 4 speed shifter wanted
- Speedometer cable
- ISO 1969 Cutlass front hood moldings
- 394 Olds valve covers wanted....
- 67 Cutlass Blower motor cooling tube
- Wanted 68 am fm radio and multiplex
- 70 442
- 425 olds crankshaft
- Passenger front body mount box 1972 Supreme
- Wanted 68 carb number 7028251
- Olds 455 Blower/ manifold wanted!!
- Wanted: 69 H/O engine/block
- '70 350 4 bbl Exhaust Manifold Shroud
- 1966 442 Q-Jet needed
- 1966 442 Rear bumper
- valvecover breather
- Wanted, 66 Antenna Switch and Bezel
- 1975 Delta 88 Royale 4 door hard top
- looking for passenger door
- 1970 -1972 frame
- 67 442 rally pac
- 87 salon bucket seats
- 72 bumper, grills, etc. (driver)
- 4x4.5 wheels
- 1966 olds f85 deluxe hood
- NOS driver side fender 72 cutlass
- power steering
- Outside mirror, passenger side
