Need Door Open repeater.
Old Jan 24, 2017 | 08:06 AM
Miles71's Avatar
The shaft used to hold the inside door open handle is sometimes called the Door Repeater.
My drivers side door repeater has a broken spring.
The door opens fine, but you need to manually push the lever back down to close/latch the door.
The broken spring is built into the assembly and cannot be replaced.
I called a few of the big cars company's and no-one carries the Door-repeater for the 1970-1972 cars with "Chrome Back-plate Arm Rests".
It seems the Door-repeater comes in 2 different Shaft-Lengths.
The Short-Shaft is used on 68-69 cars.
The longer shaft (Approximately 35.5 millimeters) is required for CS that use the common "Chrome Back-plate Arm Rests".
The Big stores only sell the Short-shaft, for cars that do not have a back-plate behind the arm rest.
Personally, I do not recall ever seeing a 70-72 without a back plate behind the arm rest.
I do not have the measurements for the Short-Shaft.
Looks like I will need to hit the Junk yards this spring.
Does anyone know of a source for the long shaft door repeater?
Regards Miles
Old Jan 24, 2017 | 09:13 AM
oldspackrat's Avatar
Miles,
I might have one. There are at least 3 sizes of these & as you can imagine, the driver side is always the one that breaks as it's used the most. The F85 & Cutlass S did not have the chrome plate behind the armrest, only the Supreme I believe. I'll try to check on one today.
Old Jan 24, 2017 | 02:21 PM
Miles71's Avatar
Hi Oldspackrat, thanks for looking and for updating me on the armrests.
I have had 9-Cutlasses. Only 1 was a 4-door, long time ago. All of the rest for Cutlass Supremes 70-72.
Old Jan 24, 2017 | 04:04 PM
I checked today and I do not have any that are the same size as yours sorry.
Old Jan 24, 2017 | 05:15 PM
nicks1966's Avatar
I looked up the gm prt numbers
8789690 is the right side
8789691 is the left side
use parts voice to search the numbers
https://www.partsvoice.com/partsearch
Chicago auto parts shows they have stock on the 8789691
http://chicagoautoparts.us/search
there is a 8789960 on ebay for 45.00
Old Jan 31, 2017 | 05:03 AM
Miles71's Avatar
Still looking for the "Door latch remote LH".
It seems that many auto websites do carry a GM and Oldsmobile parts, but since they do not list the shaft length, it is hard to find the correct part.
I sent a few emails to auto parts stores with a detailed description of the part, including the shaft length.
Here is a part number from Goodmark. Part#: GMK4020443681L, $14.95.
I think this is a Short Shaft-Part.
Drivers Side Door latch Remote, The Red marks indicate where I took the measurements (+/- 2mm error).
mv213
Feb 16, 2014 11:38 AM
bobs 69
Apr 18, 2010 08:24 AM
Tangovino
Feb 11, 2010 02:58 PM
UCF72Cutlass
May 23, 2008 11:28 AM
poppy
Jun 18, 2006 11:19 AM
