455 Brackets, Pullys, etc.
Old Feb 13, 2017 | 06:28 PM
crafttx's Avatar
I have a '73 455 out of a Delta 88 that will be going into another vehicle where brackets and fitting is not an issue. I am in need of brackets and accessories that are missing. I only have a single bracket for the ps and for the alternator. I will only need an alternator and ps pump. I will be running electric fans so no fan clutch is needed but I do need a pulley for the water pump.
It would be nice to go aftermarket with a billet set up but that is not the budget. Anyone have what I need? Suggestions to simplify? It does not have to fit the '73 and simple is better. The picture is where I am currently with it.
Old Feb 13, 2017 | 06:56 PM
tru-blue 442's Avatar
Old School Olds
Looks like you have the long snout water pump for a/c.
Check you crank pulley for #399405 KC. It's mate for the W/P
should be a 399404 KF. I may have the steel a/c brackets if needed
and the short bracket for the P/S pump at the bottom to the 1st bolt in
the exhaust manifold, but no pulleys.
Old Feb 13, 2017 | 07:44 PM
442crzy's Avatar
Pulleys wanted
I have several pulleys, lmk what one you need thanks
Old Feb 14, 2017 | 07:58 AM
crafttx's Avatar
Thanks to you guys for offering help; it is much appreciated. I received a few missing parts last night from the shop I got the engine from. I now have both exhaust manifolds although I may need headers as the crossover tube may not work with my set up. I got the correct starter, WP pulley, fan and clutch as well as the correct alternator. Without running AC I believe I only need the bracket on the back of the PS pump and a lower bracket for the alternator unless that is one and the same. Of course, I am wondering about looking for a non-AC set up to see if that would simplify things; maybe two belts rather than three?
Old Feb 14, 2017 | 09:25 AM
Kennybill's Avatar
I don't want to start a MAW (might as well) but you might want to pull off the fuel pump and check the timing chain for slop. If sloppy nows the time to replace it. If you replace the timing chain and gears you might want to pull the oil pan and make sure the oil pump screen doesn't have neoprene from the timing gear teeth and/or other debris, just saying. That's how MAW starts. I'm doing a similar Ga headed 455 in a 1972 Supreme now. It just keeps snowballing but better now while it's easier to work on. Jmo.
Old Feb 14, 2017 | 10:12 AM
crafttx's Avatar
Kennybill, Thank you for the advice. I appreciate all I can get as each brand seems to have those little things that are unique. This motor was supposedly freshened by the shop I bought it from a few thousand miles ago. While they have a good reputation, that doesn't mean they are experts at everything so I do plan to check out the timing chain/gear, take a look at the bottom end and at the top under the valve covers. Hopefully I can confirm what I was told and if not...maybe save a little more $ and do a complete rebuild with mild performance work.
Old Feb 14, 2017 | 11:36 AM
70cutty's Avatar
Beer Connoisseur
Check out cvfracing, they have affordable billet pulleys.
Old Feb 20, 2017 | 09:01 PM
crafttx's Avatar
70cutty, thank you for the tip on CVF Racing. I contacted them since I didn't find anything regarding Olds parts and they have this coming shortly for the Olds 455! Starting to fill the piggy bank.
Old Feb 20, 2017 | 09:35 PM
crafttx's Avatar
tru-blue 442, If you have the bracket for the back of the ps pump I'm interested. Is it also what the lower part of the alternator mounts to?
Old Feb 21, 2017 | 04:44 AM
Old School Olds
Your alt. bracketry set-up is different from mine. Mine uses the H bracket. I may have the lower bracket for what you have but I'm not sure what it looks like. I also checked and could not find an extra short brace for the p/s pump. You may check with oldspackrat, aka, Scott. He has a lot of parts. or John, 2blu442.
Old Feb 21, 2017 | 05:04 PM
442crzy's Avatar
Bracket for PS pump
PM sent
Old Feb 22, 2017 | 05:53 AM
Roger60's Avatar
Brackets
Any of these help?
Old Feb 22, 2017 | 05:59 AM
Old School Olds
He can use #'s 5&7 together for the alt set-up. These are what I use.
Old Feb 22, 2017 | 11:26 AM
70cutty's Avatar
Beer Connoisseur
Holy crap, that looks nice.
Briansteinke
Jul 9, 2015 09:58 AM
NDERISE
Mar 12, 2015 01:33 PM
kwz
Feb 20, 2012 01:19 PM
2blu442
Jul 24, 2011 12:50 PM
2blu442
Sep 26, 2009 06:50 PM
