power door lock actuator
Old Feb 10, 2017 | 05:57 AM
Zr1bandit's Avatar
Looking for a drivers side power door lock actuator, or someone who can rebuild one that stopped working-------------thanks---Greg
Old Feb 10, 2017 | 06:04 AM
4R5's Avatar
4R5
Hi Greg, are you sure it's not gummed up or jammed? I've seen several where all they need is some penetrant to get 'em going? Or are the terminals corroded?
Old Feb 10, 2017 | 06:09 AM
Zr1bandit's Avatar
terminals seem ok, seems the arm will not move up or down like its either stuck or just not working---guess i could try to connect to 12 volts and see if i hear it trying to operate
Old Feb 10, 2017 | 02:49 PM
4R5's Avatar
4R5
When you hook 12 volts to it (one terminal is for up, the other for down, ground the case) if it sparks that's a pretty good sign the coil is OK. Then I would try to pull away the boot from the body or work the little prayer pipe into the boot by the shaft and squirt in some penetrant (WD40 is OK, but something like PB plaster or Kroil is better). You should be able to move the plunger (shaft) up and down, there'll be some resistance but not much.
Old Feb 10, 2017 | 02:52 PM
4R5's Avatar
4R5
Oops typing to fast... prayer should be sprayer...
Old Feb 10, 2017 | 04:19 PM
2blu442's Avatar
I can't find it, but there's an old thread where Rob (Lady72nRob71) rebuilt his power locks. He said it wasn't hard to do. If the guts on yours are bad but the plugs and housings are good, I've got some from a full sized car that have the wrong brackets for the A-body. But you may be able to take the internals out of one of them and install that into yours. Just a thought. John
Old Feb 10, 2017 | 06:42 PM
Zr1bandit's Avatar
Will give it a try. Thanks.
Old Feb 10, 2017 | 06:43 PM
Zr1bandit's Avatar
. Will. Try and open it up to see what it looks like inside --thanks
Old Feb 12, 2017 | 11:40 AM
Zr1bandit's Avatar
found one---thanks
Zr1bandit
Feb 9, 2017 02:52 PM
geoff442
May 29, 2016 08:19 AM
socalrs
Aug 14, 2012 11:07 AM
75supreme
Aug 14, 2011 01:09 PM
clinton70
Jan 24, 2010 04:20 PM
