- Wanted$$$ 66-67 Bench Seat Headrests
- Wanted>75 delta passenger/right outside mirror
- Idle Speed Up Solenoid
- Auto To Manual Parts Wanted
- want spindle setup 70' delta88
- Wanted: 67 Cutlass Radiator Support
- 70 Cutlass Transmission wanted
- 68 442/cutlass chrome antenna base
- Rocket Rallye Pac
- Cruise Control "Stalk"
- in seek of 69 cutlass parts
- 1969 AC Heater duct
- 1970 442 metal between rear window & trunk
- Looking for some SSI or SSII wheels...
- 69 post rear side windows and chrome
- 1954 gas tank
- 67-69 4 speed console rocket emblem
- wiper arms
- WTB-swival bucketseat belts for 73-77 cutlass
- AC Parts
- 3:42 geared rear-end
- WTB Inline Flathead 6
- WTB: 307 coolant tank
- wanted 394 standard trans parts,62 88 speed gem?
- 67 Delta 88 Horn
- WTB Horn relay 1115882 in excellent shape
- 65 F85 moldings
- 85olds cutty fan shroud
- 68 442/cutlass items
- BB intake and carb
- 67 Delta 88 Window Motor
- Window trim
- 68 442 Jack hold down
- 3 groove pulleys for 64 394
- looking for 71-72 auto-floor shifter
- 1969 88 delta parts wanted.
- wanted 62 starfire fender trim
- 79-81 Z28 or Trans Am front sway bar
- 79 Hurst/Olds front grills
- 67 cutlass shifter
- K&N air cleaner lid
- Looking for an original 4-spd black shift ball + H/W for 70-72
- 68 Fisher Body Service manual TRADE for A 70 Manual
- Connecting rods
- wheels
- NOS Trunk Lid
- Need Driveshaft for '73 Delta (not 98)
- need reverse lights lens for 76 cutlass
- 1956 Clock chromium plated face
- 68-72 B pillar molding
- 1971 Cutlass S - Oldsmobile Grill Script
- Wanted SBO Big Valve Heads
- 455 brackets
- Roto-Hydramatic Yoke
- In need of 70-72 Cutlass convertible top switch
- Needed for a '53 Olds 88 hardtop
- Wanted: '71 Turbo 400, 71 OW or 71 BB on tag
- 1969 W-30 4 sp. linkage
- Drivers side rear quarter panel 70-72 442 wanted
- 455 frame mounts in inland empire
- 1970 cutlass dash
- Bumper shocks
- wanted air cleaner base for '66/67 w/ quadrajet
- Need a driveshaft for a 1953 88
- radio mounting plate
- Wanted: Assembly Manual for 1970 1971 or 1972 Cutlass
- Need door hinges asap
- Trim rings rallye wheels or tip where I can buy
- wanted: intake manifold for 350
- Wanted: 2-groove P/S pulley #399406
- Wanted air cleaner 425
- 1951 52 53 parts
- Need stock 1956 wheels
- Wanted: 1970 Rallye 350 parts
- wanted: 1967 330 intake manifold
- i'm looking for a gas tank for a 1952 olds 88???
- needing 69 cutlass parts
- 68 or 69 Cutlass or 442 Headlight Switch Retainer Cup
- 1966 330 4bbl Choke Thermostat
- WTB: 2x Trim rings for 62 olds full size
- Bumper Jack lift pad
- 1983 1984 Royal Brougham Interior
- Need '70 RH front turn signal lens, rear taillight lenses
- 1961-63 F-85 door frame stainless
- TH400 Auto Shifter assemby
- 67 olds 98
- #5 heads
- '75 Starfire Manual Steering Box, intermediate shaft
- 1940's Olds engine thtust plates
- 1962 Dynamic parts wanted
- 1962 Dynamic parts for sale
- WTB: 80-85 Delta 88 Chrome side mirrors
- Need some black interior parts for 1970 Cutlass S
- Comp Cams Steel Roller tip rockers
- Camshaft
- Searching for 77 Omega parts
- 1967-68 Full Size Olds Dash Pad
- Anyone with a driveshaft for a '73 2-door B-body in the Northeast?
- H/O SHIFTER hurst olds
- 71 Cutlass Headlight Bezel
- #5,6,7 heads in NC or SC
- 72 442 fender emblems
- Need OAI Hood for 71-72 & Other Misc. Parts
- 68 olds delta 88 spindle nut retaining clip
- 1940 Fuel Tank
- OAI hood lock brackets with bolts 71-72
- 1971-1972 A body driver side fender (rust free)
- '70 olds electric trunk release
- WTB an original 1967 442 steering wheel.
- '57 Super 88 2 door hardtop
- 7040250 carb needed.... again!
- 1975 olds delta88 vert parts wanted
- 66-67 400 .030 pistons
- Cowl to radiator support rods
- 1951/52 Oldsmobile parts
- 1968 98 conv Quarter
- WTB: 70-72 Cutlass Right Rear Marker Light
- 1967 Olds Cutlass Convertible rear bumper
- need parts for a 1971 olds 98
- Cruise handle wanted
- WTB: 455 Notched Valve Covers
- 1966 Toronado Deluxe Inner Door Panel
- 66 Toronado - R&L Exhaust Manifolds WANTED
- 66 Toronado - Cruise Control Cable
- 81-87 Cutlass top/rear front fender trim/molding
- Need Q-Jet 7040252 (1970 Toro)
- License plate frames and dealership items
- 69 cutlass door
- 64 dynamic trim
- 1969 Cutlass S Full Trunk Chrome Wanted
- 350 rocket engine
- 72 cutlass door parts
- 1961 Dynamic 2 door parts car
- WTB: a hazard flasher knob Cutlass/442 -69
- nick of time, need some parts
- 62 starfire console
- !967 Cutlass Supreme
- Intake
- Wanted 70-72 cutlass 442 trunk lock retainer
- '60 headliner plastic bow - need just one!
- WTB: 1968 442 dog dish hubcaps
- WTB - 71 Cutlass Hood and Fender Molding
- 1968 Olds Cutlass S 4 Speed Console Base
- I need a 68-72 tach for parts to repair my 71 tach
- Wanted: 1963 Olds Cutlass Jetfire F85 parts!!!
- Wide rocker molding trim clips
- 68 cutlass trunk lock rod
- WTB Steering Wheel.
- Need pair of Seat Belt Bolts
- Delta 88 cov top switch
- T-3 Headlight highbeam needed - ky
- Lower Trm, 65 Olds
- WTB 71-72 RH fender
- Re-manufactured quadrajet carb
- Hood Tongue for a 1970 442
- 65 Front Bumper
- loking for parts for different oldsmobiles
- air intake parts needed
- '67 Cutlass side chrome retainers
- '69 Cutlass Parking Light Ass'y needed in CT
- 70 cutlass s wheel trim
- help!!!!
- WTB Good running 455 or 425
- Wanted 70-72 Fastback Trunk Lid, North Florida
- 71 Cutlass sunvisor supports
- Rallye 350 Bumpers Wanted - North Florida
- 1969 88 Hood
- 1974 delta 88 convertible
- 72 Cutlass Upper Rad Plate for 4 core Needed
- 71-71 Cutlass / 442 NOS Front Bumper
- Need radiator support front center "brace" for '70 Cutlass
- WTB trunk trunk channel
- relay
- Need 67 Toronado wheel beauty trim ring
- 1968 SSII wheels
- 71 cutlass passenger wiper arm & sport mirrors
- 70-72 Cutlass 4 Speed Parts
- 1969 SS1 wheels for disc brakes car
- 4 speed console
- 1969 442 antena
- 54 Olds Rear Bumper Guards
- 66 OAI scoops and/or bezels
- Glovebox emblem 442 -69
- 1967 Instrument Panel
- up and down switch for a 1967 dela 88 cov.
- '68-'72 Sport Mirrors
- Clock for 1968/69 cutlass
- 72 Cutlass Supreme Grill/Wheel Moldings
- 1965 olds 88
- 65 cutlass
- 66 Cruise contol parts wanted
- WTB: Super 88 trunk & passenger side script
- WTB: 62 bumper brackets for full size
- WTB Clean 1971/72 Delco Moraine Brake Booster
- 54.5" Driveshaft
- Rocker panel retainers
- Wanted 72 cutlass 350 downpipes / head pipes 75.00
- 1935 parts info needed
- Need pictures of air cleaner
- WTB 1972 Cutlass AM radio Model 23APB1
- 41-48 Olds Instrument Panel WTB
- Wanted 1965 tail light bulb w/ carrier
- 1960 dynamic 88
- Wanted: 1972 98 power seat switch
- WANTED: 1970 Cutlass S/442 Blue Interior Pieces
- WTB: 80-85 delta royale tailights
- 66/67 power steering pitman arm
- wanted.. 1969 442 bumper jack
- WTB: A4 307 intake - ugly ok
- Vacuum trunk releasbutton 1968-69
- rally gauges for 68 442
- wanted:67 vista cruiser tailgate window switch
- 1959 super 88 holiday parts needed
- Need an Upper Trailing Arm for a '67 Cutlass/4-4-2
- Needle in a haystack-- H heads
- Big block 422 oldsmobile motor or 455 oldsmobile motor wanted!!!!!!
- 71 Sports Mirror
- 67/69 Floor shifter needed
- 1966 steering column
- Bumper Braces
- 56 jetaway flexplate
- 68 cutlass hood latch assembly.
- WANTED: 7028250 Quadrajet carb for 68 Cutlass 350 rebuilt/restored
- 67 cutlass throttle bracket assembly
- 1956 parts wanted
- Speedo cable
- Wanted: 1971 Delta 88 trunk molding
- WANTED: 68 Cutlass Supreme 4dr door panels
- Hurst shifter
- a/c hose 73 olds 98
- blue non ac dash pad and steering wheel for 68 442
- dip stick tube
- 1942 - 1947 oldsmobile tail light
- door panels/floor pans
- KS or LA 3 groove crank pulley
- 8 track harness
- 71 cutlass convertible rear side glasses
- B Body front disks
- 56 Olds gas door chrome
- WTB: 67-70 Toronado Chrome Disc Brake wheels
- Wanted!
- 72 cutlass ashtray cover and driver door panel needed
- 1935 parts needed
- TH400 speedometer gear housing
- 72 cutlass int parts
- console
- 68-69 4bbl air cleaner
- Eighty-Eight dash plate emblem
- 455 Short Block
