Need pictures of air cleaner
Old May 23, 2011 | 09:35 PM
craftsman1956's Avatar
I am looking for pics of the correct air cleaner for a 72 cutlass 4bbl,pics of top and bottom.I have 3 bottoms and 2 tops from olds, but they don't fit right,and each look different.One cover has hole in the center,one is offset.Need to know which is correct, if any.I may need to buy one if mine are not right.Thanks for the help!
Old May 24, 2011 | 02:06 AM
jensenracing77's Avatar
the hole for the carb should be in the center. the offset one would be off a newer car with HEI. if you have added an HEI to your car you will have to use the offset one or cut the back of the other one.
Old May 24, 2011 | 06:30 PM
Thanks,I have an original cover with hole in the center,so now I need to know if one of my 3 bottoms is for a 72.One hole is round,and another hole is round with a couple notches and larger indents as if to make room for something that would be in the way with the cleaner on the carb.
Old May 24, 2011 | 08:57 PM
orange442's Avatar
Here is an original I restored a while back:
Old May 24, 2011 | 09:42 PM
Photographs of the parts in question would be helpful.
Old May 24, 2011 | 09:59 PM
Originally Posted by orange442
Here is an original I restored a while back: Looks like mine,but I need to see what shape the hole is in the bottom part that sits on the carb.I sent pics of the 2 I have,which one is correct? notice hoses,cutouts, and hose to rocker cover fitting. Thanks
Old May 24, 2011 | 10:08 PM
orange442's Avatar
The one on the left is correct. The right one looks to be a later Toro style base with all the cutouts for clearance because of the lo-profile intake and distributor.
jstrits
Jul 15, 2015 10:00 AM
montvaleplace
Feb 3, 2013 08:34 PM
69CutlassAlex
Dec 2, 2011 08:01 AM
Viper
Aug 13, 2008 10:58 AM
Oldsguy
Aug 31, 2007 07:49 AM
