54.5" Driveshaft
Old May 25, 2011 | 01:49 PM
allyolds68's Avatar
54.5" Driveshaft
I just replaced my 66 Type B 2.93 for a new Type O 3.42 rear from Brian & the driveshaft is too long. I can probably get it shortened but I was wondering if anyone had one. As stated it in the title, it should be about 54.5" Shipping would be to 13148
Thanks,
Mike
Old May 26, 2011 | 05:28 AM
ROCKETMAN269V's Avatar
Smile 54.5" Driveshaft
Where are you getting the dimension from? Driveshafts are typically measured from center to center on the u-joints. I have a very large collection of clean driveshafts and a book that lists them by application. What transmission are you using? Let me know: drolds1@bellsouth.net. I'm in south Florida. Thanks, Bob.
Old May 26, 2011 | 05:40 AM
allyolds68's Avatar
It's a 68 442 with a type O posi and a Muncie M20. My existing center to center is 55 5/8" with the suspension compressed and the yoke bottomed out in the tranny. Most recommendations are to measure the center to center in this position and reduce it by 3/4" to 1" to come up with the correct shaft length. 54 1/2" is a common shaft length that I've seen for the application that I have.
Old May 28, 2011 | 07:16 AM
How about 54 3/8"? I just went through my massive collection of driveshafts (~80-100!) and I have one that was fresh from the shop and only used for ~ 1000 miles before we pulled it and installed a 700R4. It has a T-400 yoke, which I know that you can't use. Do you need a yoke to go with the Muncie trans? Thanks, Bob.
Old May 28, 2011 | 02:55 PM
allyolds68's Avatar
Bob,
I sent you an e-mail back
Thanks,
Mike
Old Jun 2, 2011 | 12:47 PM
allyolds68's Avatar
In case anyone else ever goes through this I ended up having it done at Fleet Pride. It cost $77 to shorten it which included balancing. We have a corporate account so I'm sure that helped but it's hardly worth the effort to find a used one.
Thanks everyone for your help.
Old Jun 2, 2011 | 03:37 PM
projectheaven's Avatar
This may be a help to me in the future. I have a m22 I've been sitting on for a while. I'll eventually throw it in my 72 convertible cutlass. So the proper drive shaft length is 54.5 inches?
Old Jun 2, 2011 | 05:49 PM
allyolds68's Avatar
The length depends on the yoke and rear end you have. I have 2 different yokes that fit the M20 and they are differnt by 1/4". Your length may not be 54.5".
Old Jun 2, 2011 | 06:32 PM
Got it.
Thank you
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
Kennybill
Ninety-Eight
Jan 28, 2009 03:51 AM
Swed Olds
Nov 18, 2007 04:51 PM
Ryhelio
Jul 7, 2007 11:49 AM
