View Full Version : Parts Wanted
- Wanted 1971-76 Oldsmobile 88 RH side rocker trim, LH and RH rear wheel trim
- cast low height aluminium covers for 455
- WTB 72 delta 88 rear bumper brackets
- 67 442
- 1972 Supreme Rear Arch Sections of Quarter
- Wanted: 84 Cutlass Supreme AC Lines
- WTB OEM wood grain inserts for a 70-442 4 speed console
- WTB 1968 Cutlass/442 dash bezel
- 1970-1972 Cutlass Cruise Control lighted dash switch
- License Plate Door Opener
- '71 442 'O-W' Trans
- Iso big block alternator and ps brackets
- Wanted: Weatherstrip/felts for 1970 442 with B85 molding
- Wanted: Correct looking new fan clutch for 1970 455
- W-27 Wanted
- Seeking NOS RH Qtr Panel Extension Molding - 8700877
- Valve lifters Toronado 1966
- 64 65 cutlass , lemans post trim "A" piller molding wanted
- 67 442 j-52
- 1973 98 front facia
- Carburator Toronado 66
- 67 Cutlass blower switch. (non A/C)
- 66,67,68,69 manual antennas
- 1955 Oldsmobile Super 88 Headlight buckets
- Qjet Secondary Hangers “D” / “E”
- 1969 hardtop 2 dr frame needed
- 1975 Delta Royale 88 Tail light
- 2004rR after market pan
- 70 Cutlass Column Shift Indicator Assembly
- 7111 intake
- WTB: 1957-58 Olds lower ball joint cores
- 72 Cutlass Power Trunk Setup
- 1963 Oldsmobile dynamic quarter panel upper chrome clips
- 1973 Delta 88 Royale parts needed
- Need New Glove Compartment switch for 73 Olds 88
- 1966 oldsmobile delta 88 convertible interior parts
- WTB: 1949-62 Olds water pump cores
- 1965 cutlass hood hinges
- 1972 442 cut out rear bumper..driver quality or better
- 1972 Column Shifter
- 1978 - 1980 Cutlass Rear Bumper
- WTB Roof Rail Channels - Oregon
- 1965 442 Rear Tail Panel
- 1972 cutlass main dash panel needed
- 68 oldsmobile delmont help
- Intake
- Pass. Side Inner Fender…?
- 64 cutlass covertible crossmember and trottle linkage
- Need a set of 350 motor mounts
- drivers side quarter window regulator post car
- 442 numbers needed
- 1972 Cutlass Supreme convertible passenger door needed
- Master Window switch Needed for 1973 Olds Delta 88
- Looking for a cast oil pan for a th400
- Wanted 68 Cutlass Convertible Decklid
- Wanted 69-70 Deluxe Steering Wheel
- 67 Cutlass Hood
- 73 Delta Convertible Driver Mirror Cable
- 1973 cutlass S or 442 grilles
- 1966 330/320 PCV valve
- 1957 Olds fender script
- A Pillar weather strip holder- Drivers side
- NOS Passenger lower Door panel - Maple
- NOS 1984 Cutlass Passenger PW woodgrain
- 1970 OAI flapper door Wanted
- 1970-72 4 speed Bench / non console handle
- TH400 Kickdown Switch
- 1972 442/cutlass supreme convertible door panels
- Looking for 1972 t3 low beam bullbs
- Door hinge for driver's side 1970 cutlass
- * Wanted - 1977 Delta 88 Pass. Door Glass
- 58 olds cylinder head
- 14"ss2 wheel
- 1975 H/O parts
- 8.2 posi unit 2- series
- 65 442
- 57 Olds front bumper guard
- 57 olds grill stainless
- 1969 cutlass 442 front bumper
- 1948 Olds 78 fender skirts and grille
- Looking for rear coil springs
- 455 Core for Mild Street Rebuild
- window sash for a 65 post car
- 49 98 rear axle
- Gas Tank Needed - '27 Model 30e Landau
- 1968-1972 drive shaft
- 1984 cutlass trunk lock retainer
- 1968 Olds 98 front bumper
- Positive Stud Rubber Cap
- WTB 1968 442 Convertible Trunk Trim
- 1984 Cutlass V8 front wiring harness
- Wanted: '68 - '72 4 Dr Power Window Regulator
- SS1 Center Cap
- Horn Relay
- 1976 toronado drivers door glass
- 69-70 black 98 steering wheel
- Thermostat 404632 #5
- Plastic washer fluid reservoir for a 1963 88/98
- WTB License plate frame from Pioneer Oldsmobile of Abingdon Virginia
- 1969 442 hood latch clips
- 71' blower motor switch
- WTB 1972 hood
- WTB center trunk lip trim 70-72 supreme
- WTB 1980-85 Delta front pass door
- 1111042 67 distributor
- 67 olds 442 J-52 Master
- Quadrajet parts
- th400 short tail shaft and housing
- SBO distributor
- W-30 Red Inner Fender Wells
- Kick down switch for '67 442
- 73 cutlass supreme parts
- 350 olds Motor wanted
- 1949 hood latch cable
- Hold down bracket for jack - 61 Olds 88
- 69 442 Radiator support
- 1964 F85 rocker molding parts
- Bench Seat Track Bracket Passenger side
- 1970 455 TCS solenoid bracket
- 69 442 blue deluxe steering wheel
- 68 442 drivers wheel well molding
- Heater hose clamp
- Alternator Brackets for 1979 F-Body 403
- NOS Blue Rear Floor Mats
- Wanted TRW Springs CS532 or CS5403
- Need LH fender filler baffle
- TH 350 Detent / Kick down cable needed.
- 1970 442 Exhaust Manifolds Wanted
- 65-67 #384678 power steering pulley
- 64 F-85 hood
- 67 442
- 66 442 door panel trim
- 425 Crank for stoked diesel
- Need 72 442 grills
- Need 72 442 passenger side sport mirror - flame orange
- 1933 grill
- Wanted 1970 drivers side cutlass 442 non a/c kick panel
- TRADE ME - '71-'72 8 track wood grain for '70
- 1970 Windows sweeps.
- Seeking 455+ci short block
- 67 saffron top and window, 4 speed air cleaner
- 400 Lifters
- 67 yellow interior
- Wanted 1959-61 Front Brake Drum
- chrome center caps 92-95 cutlass supreme convertible
- 67 400
- 66 442 hood
- 70 Rallye fan and shroud
- 67 442 j-52
- New to the forum from Massachusetts
- WTB: Edelbrock 2711 Performer 350 intake
- hood
- 1968 Olds 98 hood hinges
- WTB Deck lid trim
- Water Pump Pulley KM 405461
- 56 Olds 88 Conv
- 1970-72 driver side door for A body
- Sbo crank
- ‘70 442 Fan Clutch
- Wanted: 1970 98LS stock 455 Distributor
- Used Crankshaft and Connecting rods needed!
- Jetfire Display Sign Wanted
- 1968 Ninety Eight Rear Bumper
- 200R4 Console Part from 1983-1988 Cutlass for a 1979 Cutlass
- hope in the correct place, 70, 97 rear bumper
- 1970 vista cruiser center roof glass and tilt column wanted
- 1967 Oldsmobile Vista Cruiser - Headrests
- 71 a body 8.5 rear bolt in axles
- 1967 442
- console hinge spring
- 7308173 fader knob
- Connsole door
- 67 442
- 67 442 master cylinder
- Rear window exterior trim pieces
- 70-72 Fenderwells wanted
- WANTED: 1964 V8 Emblem
- M20 4 speed
- 394 Thermostat Housing Wanted
- AC Compressor needed
- PCV Filter Valve
- ISO of 7111
- 400-425 Crankshaft Wanted
- 1111042 Distributor Wanted
- Looking for set of front fender support brackets for 1968 442.
- Olds tach
- Rear Speaker Hardware
- 1966 Cutlass Convertible Radiator Core Support-
- 70 350 manifolds OE
- Gas Tank 67 Delmont 88
- 71 supreme tach
- WTB hanger bolts for dash on 1968 442
- Seeking NOS 1972 Cutlass/442 Hood Molding
- 1956 oldsmobile super 88 drive shaft wanted
- 14 x 7 SS1 - all Chrome
- Tilt column
- Looking for Harness
- 68-72 4 barrel intake wanted
- headrest escutcheon
- Looking for a 1967 Cutlass Supreme Type "O" rear axel housing
- B90 trim for Driver Quarter window.
- Front Brake Drum 63 Dynamic 88
- WTB 400-455 Intake Manifold
- 71-72 tail lights housings
- Master cylinder EB - 250 -300 Julian date
- 1976 Cutlass Parts Needed
- 1970-72 Cutlass 4 speed trans tunnel
- 57 j2 brass vacuum tee
- 1965 starfire power driver seat
- 1972 Supreme Quarter Section
- Dash Gauge Circuit Board Pins
- '70 Floor Mats
- 1969 442 window stops.
- 1968 olds 442 hood
- Wanted: LH 84-85 and RH 86-88 Cutlass 2 door Taillights
- 68 442 Spark plug retainers for brackets.
- 70 Cutlass S/442 Black Front Seat Covers
- 68 Hardtop vent window assembly
- 1973 oldsmobile custom cruiser axel bearings/all of bearings for axel for the end of
- 1965 442 rear seat belts
- "Wanted to buy" Performer RPM for 350 Oldsmobile
- WTB: 64 olds 98 parts
- Wtb - 1957 thru 1964 371/394 a/c rear bracket to manifold sleeve nut
- 1984 Cutlass Supreme Taillight needed
- WTB Blue NOS/Good used cutlass rear floor mats
- 1965 Jetstar 88: drum brake spindle wanted
- 1964 cutlass front bumper
- 68 442 manual console map case parts wanted.
- 68 Oldsmobile 88 driver side bumper trim piece
- 394 intake
- 71 350 rebuild
- 69 442 cutlass front lens, rear view mirror
- 69 cutlass door jamb vent
- 63 & 64 taillights for 98 wanted
- Needed, for 67 442
- Wtb front bumper for a 65 cutlass/f85
- 1967 442 Hood.
- Oldsmobile 402295 402294 w z manifolds
- 1967 Cutlass Bucket Seats
- Ss2 rim
- 1970 Cutlass wagon door panels
- Mr. Gasket 6400 wanted
- 1967 442 4 speed
- 1969 442 front grill
- White bucket seat headrest (69-72) needed
- GM 90 degree Speedo adapter 396338
- 1973 Oldsmobile Omega bumpers
- 1969 cutlass 442 radiator overflow bottle
- Wanted: REAR SPIRAL SHOCKS
