Wanted: '68 - '72 4 Dr Power Window Regulator
Old Jul 22, 2021 | 05:08 PM
4R5's Avatar
4R5
Looking for a power window regulator, Passenger front door, for my '71 VC. The books say any 68 - 73 A body 4dr closed sedan / wagon uses the same part. I don't need the motor, but the arm pivot needs to be "tight". The pivot on mine is excessively worn. Would be nice if the 3 rollers were in good shape too, but not essential. Thanks.
Old Jul 23, 2021 | 06:03 AM
newmexguy's Avatar
Maybe a hinge rebuilder can fix yours. May be quite hard to find a single regulator suspect most will be marketed as sets.
”Regulator Roy” in NJ might be another option.
Old Jul 24, 2021 | 07:59 AM
4R5's Avatar
4R5
Thanks, I'll contact Roy. I also may try to rebuild the shaft / arm/ bushing, luckily I have a yard about 30 miles away that has a lot of older GM cars so I can get a manual regulator from an A body 4door sedan and use it to see how to disassemble it. I've already rebuilt the motor and replaced one of the rollers on mine so this next step might not be that bad.
Old Jul 24, 2021 | 09:51 AM
I assume you mean 68-72, but yes that is correct. P/N 9716738
72455442RA
Mar 19, 2020 10:32 PM
ezman604
Aug 18, 2015 11:23 AM
70vista
Dec 3, 2014 03:33 AM
vinny c
Nov 7, 2011 09:08 PM
CrazedCountryRebel
Jan 12, 2011 09:06 AM
