Wanted: '68 - '72 4 Dr Power Window Regulator
Looking for a power window regulator, Passenger front door, for my '71 VC. The books say any 68 - 73 A body 4dr closed sedan / wagon uses the same part. I don't need the motor, but the arm pivot needs to be "tight". The pivot on mine is excessively worn. Would be nice if the 3 rollers were in good shape too, but not essential. Thanks.
Thanks, I'll contact Roy. I also may try to rebuild the shaft / arm/ bushing, luckily I have a yard about 30 miles away that has a lot of older GM cars so I can get a manual regulator from an A body 4door sedan and use it to see how to disassemble it. I've already rebuilt the motor and replaced one of the rollers on mine so this next step might not be that bad.
CrazedCountryRebel
Jan 12, 2011 09:06 AM
