View Full Version : Parts Wanted
- Need Power Window Switches!
- 1966 Delta 88 2 Speed Wiper Switch
- Tach/Clock for 68 Cutlass
- Horn Relay
- 1969 442 conv need interior
- 68 442 RF Fender
- Rubber radiator mounts
- Inner fender liner bolts to radiator support
- Need black 69 dash pad
- 75 hurst t top seals
- WTB: '61 dynamic 88 F&R window Trim
- 70 cutlass supreme convertible
- Wanted: Driver or Better OLDSMOBILE W-29 Hood Emblem
- 1965 firewall plate
- WTB:Toronado snorkel air cleaner 66-67
- wtb: 66 olds Cutlass parts
- Looking for big block exhaust manifolds
- Steering Column Lower Bearing
- trans x-member 85 custom cruiser CNY
- excellent 69 a/c dash pad
- looking for AC condenser rubber mounts 1967 cutlass
- rims wanted 14x7 ssII wheels bolt on caps 1970
- Need Front fenders 70 Cutlass
- In need of a roto hydramatic slim jim 375, for 1962 olds 88. Catalina 61, 62, 63
- 1965 F-85 driver's side rear quarter
- 1970 cutlass S front bumper
- WTB: '61 dynamic 88 tail light lenses
- Front suspension parts for 57 Oldsmobile
- '67 Delta 88 pwr window motor!
- Distributor - 1968 Olds 350
- Sheet Metal
- WTB 455 ARP Rod Bolts
- 67 vista cruiser trim
- Two-Tone Vista trim
- 1965 Starfire N93 wheel or studs
- Wanted:1970 Cutlass Dash
- Wanted: Original 455 Engine fasteners
- seeking nice OEM or NOS '70 Cutlass trunk lock emblem
- 63 0lds 98
- Need 70 Cutlass Interior Parts
- 65 throttle bracket
- stock 16 in wheel 48 olds
- 425 dipstick
- 71-72 Cutlass Conv Trunk Torsion Rods
- 4BBL Carb for 74 SBO
- Brake Drums Needed
- 1972 Cutlass Supreme Steering Wheel
- trunk lid for 1972 Cutlass Supreme
- 72 T-44 rear cable wanted
- Glove Box Door 72 Cutlass
- 1968 Upper Cowl
- 1972 cutlass
- 12 bolt o axle 3.23 gears
- 67 c/s 2door
- 70-72 Fenderwells
- wanted.........4 Good 14" tires DFW TX
- Need trim that goes down the middle of the side of the car 1970 Olds Ninety Eight 98
- '66 Cutlass ignition bezel
- 68 Olds Full Size Side & Rear Mirrors
- m/t valve covers for olds 455
- 62 red seat belts wanted
- WTB: plastic rocker panel clips
- Looking for 63 Cutlass parts.
- '74-'75 Delta 88 Conv Top Switch (aka 74-76 Vista Cruiser window switch)
- Red inner fender wells wanted, 68 69 W30
- looking for msd distributor or other nice distributor for olds
- 1967 Cutlass Supreme/442 Rear Quarter Trim
- 1967 Olds Cutlass Fender
- Power window/seat relay-'67 Delta
- Looking for sail panels c-pillars for 70 cutlass
- 1966 olds 442 need a few parts
- Air Cleaner for Cutlass SX 455 4bbl
- 63 88 armrest wanted
- 69 cutlass/442 lower fenders sheet metal
- 65 Cutlass / 442 Passenger Door Window Glass
- 65 cutlass drivers side quarter panel needed
- 66 Cutlass
- Rear panel above arm rest
- Bucket Seats
- used 455 std piston
- Vacuum Tank - A/C to fit 67
- Differential bumpers
- 1972 cutlass front bench
- Quadrajet Dash Pot for 1970 350
- WTB Dual Snorkel Air Cleaner
- Partial quarters
- 55 taillights
- Rear Sway arm for 72 Cutlass
- 72 cutlass vinyl body molding clips
- Alternator bracket
- 1968 olds vert drivers side qtr mldg
- I need a set of w30 inner fender's.
- Lower dash black plastic vent needed - 72 Cutlass
- 1956 oldsmobile front outter wheel bearing
- need grill for 1979 cutlass supreme
- Drip Rail Molding '68 442
- Factory spoiler center studs needed
- 77 Cutlass parts needed
- Rear bumper fillers
- 72 cutlass supreme visor bracket
- Wanted stock 16in wheel 48 sedan
- Need trim for 1970 Olds 98
- 1965 Driver side 1/4 pannel... Anyone know where I can get one?
- finding fenders, (inner w30's)
- Wanted- 14 inch 5 on 5 wheels
- Throttle linkage for 65 cutlass - manual trans.
- Center wheel caps for 1989 Olds Delta 88
- Vinyl/body chrome trim molding 72 cutlass supreme
- 70-72 Cutlass 442 Rally Tach Clock
- 1956 jetaway transmission
- Steering Column Cover
- WTB: 1976 olds omega rear lens
- 65 or 66 Olds 98 gas tank wanted
- MI man needs 68 G400 MT eng/trans
- Windshield washer bottle for 62 Jetfire wanted
- Accelerator bracket quadrajet
- Passenger Side Alternator Brackets
- 75 Cutlass AM/FM Radio
- I need a couple of rebuildable 490 Holleys, carters or whatever
- '71 core support wanted (N.E.Wisconsin or the U.P.)
- 70 Ragtop Pinch Weld molding
- Quadrajet carb wanted 1970 455
- 1966 delta 88 grill
- disc brakes
- 1959 98 stainless,seat switch
- Needed Turbo 350/400 Inspection Cover - Flywheel Cover
- looking foe GM/ NOS 1970 olds 442 grills
- 68 cutlass radio delete plate
- front bench seat belts (black) 67 cutlass
- Looking for a short shaft 400 trans
- 1969 hood leuvers
- rear axle 1964 jetstar 88
- 74 or earlier 350 PS exhaust manifolds
- Floater for 1959 Rochester 4Jet Carburateur wanted
- Uniroyal Tiger Paw CTS 225/70/14
- 66 442 4spd valve cover breather
- Water Pump Pulley
- 67 cutlass dash
- 70 front bumper
- Tailgate for Wagon
- 455 air cleaner assembly wanted
- 70-72 rally pack & NOS control arm bushings wanted
- Help me find this trim piece please!
- Trade Olds 215 4-barrel intake/carb for stock 2 barrel
- Need SBO heads for 403 project
- 63 Olds
- Early Hydramatic Shift Lever (for '51 98)
- Tires Goodyear Eagle GT II
- 64 passenger door window tacks
- Left Front Wheel Hub for 1957 Oldsmobile Wanted!
- 69 Cutlass Neutral start switch
- 275/ 60/ 15 BFG Drag Radial
- Need 1 axel for my 68 Cutlass
- wood grain vinyl that matches original
- Rochester carb
- For 68 442
- Fuel Gas Tank
- 70-72 license plate door
- 330 dipstick
- need 67 fender ext.
- 1969 F85 bench seat hinge covers
- collum parts
- 1974 Cutlass Supreme Vinyl top molding
- 1954 Oldsmobile hood "L"
- parts needed
- Parts Wanted
- 700R4 Dual Exhausr Crossmember
- need center f. bumper braket 67 cutlass
- Defrost Duct Needed
- Parts NEEDED for 1969 OLDS 98
- 403 Cruise Control Vacuum Servo
- WTB: exhaust manifold 350 Cutlass
- Looking for Rocker Chrome trim for 81-88 Cutlass
- WTB '56 88 1/4 patches
- 1970 442 455 carb needed auto or stick
- 425 rods
- CAN SOMEONE HELP ME !!! 68-69 442/cutlass
- Convertible Top Motor
- 72 Cutlass Bucket seats wanted
- parts wanted: f.bumper braket 67 cutlass
- Wanted Radio Knobs, Fan or Blower Knob 1970-72 Cutlass
- Wanted: Rear bumper for 1969 cutlass
- Seat Tracks 68 Cutlass Rag Top
- 1970 Toronado oil pan
- Can't find: 67 cutlass f. center bumper braket
- 68-72 A Body front seat
- Looking for Dash Radio Face Plate for 66 442
- Interior light lenses needed
- posi-chuck
- HEI or parts
- 1970 442 fender fillers
- 75 H/O Hood Decals
- Wanted/Trade 4bbl intake for 324
- WTB - 66 Cutlass Body Parts in TX
- Manual conversion parts G3 73-77
- 57' Olds 2dr Sedan trim
- 1966 cutlass
- 69 F85 Hood & glove box parts wanted
- 73 supreme power window motor
- Fender Brace and Bumper Braces 71-72 442
- Wanted 3.91 ring and pinion gear set
- 72 cutlas s grills
- 64-67 battery tray or hold down
- Seeking 1970 quadrajet for 455 cid - 7040251
- a few 68 parts needed
- SSII or SSIII Trim Bezels
- 70 Cutlass Parts/Cars in Alberta??
- Chrome tail panel for '65
- wanted engine pulleys
- Muncie M21
- Delco Remy - Horn Relay 1968 Cutlass
- Cutlass Convertible Top Frame Pivot Bushing
- WTB 70-72 console top plate.
- 1969 Cutlass Steering Wheel
- don't want to cut my hood
- 81-87 cutlass console
- 69 Cutlass 2dr parts needed.
- Need alternator bottom bracket no a/c
- 68 toro fuel sending unit
- Where can i get one of these from???
- 1968 Cutlass A/C Dash Red
- Looking for Window Channels
- trim
- 61-63 special, f85, tempest 15" steel wheels
- 1965 F85 shift lever
- 1952 Olds headlight bezels wanted
- 87 442 doors
- tri-carb intake
- Passenger Side 1970 Bullet Mirror
- NOS Trofeo parts...
- 400 or 455 motor and heads for a 69' 442
- Looking for 69 Cutlass/442 Grille.
- Chrome trim - right front fender
- 1966 toro wheel opening molding
- Quadrajet
- 1970 Supreme Door Panels
- Sheet metal
- In search of vinyl top molding for 72 s/442
- Wtb '70 442 rear of front fender brace
- Electric Idle stop or idle speed up solenoid bracket
- 79' Hurst/olds cutlass calais parts?
- 65 cutlass right and left quarter panels
- 65 cutlass
- looking for steering wheel button
- Door strikers wanted
- door panel
- Looking for 1970 Cutlass Conv Deck Lid and RH Door
- Looking for an "A4" intake for my 330 driver...
