1965 firewall plate
Old Aug 23, 2012 | 08:47 PM
Hal's Avatar
Hal
1965 firewall plate
I'm looking for the metal plate (?) at the firewall where the steering column passes through it. It's for a 1965 Cutlass (VC). Let me know what you have, Thanks,Hal
Old Aug 24, 2012 | 09:49 PM
oldolds88's Avatar
i believe i have one. ill look tomorrow. your talking about the plate that is held on with the big washered bolts,correct?
Old Aug 24, 2012 | 10:12 PM
Hal's Avatar
Hal
plate
It's the plate that bolts to the firewall and I think has a clamp that holds the column. I don't have one to compare it to and really don't know how it attaches to the car.I have been offered one for a 1967 but I'm trying to determine if they are the same. I think 64-66 are the same but I'm not sure but don't know about the 67. Let me know, Thanks, Hal
Old Aug 27, 2012 | 07:57 PM
musicars's Avatar
There are at least two versions of that plate. One is pretty solid and the other has a large hole going through it for the clutch pedal rod to go through. There is not a clamp on it. It is basically shoved over a rubber sleeve on the column. If this is a column shift automatic it should use the solid plate. Many automatic floor shift models use the one with the hole and then block the hole.
If the person that previously replied didn't find one for you let me know. I have both styles still on extra '65 columns. Can also supply pictures if you want to verify the part or application.
Old Aug 27, 2012 | 09:19 PM
Hal's Avatar
Hal
Plate
Thanks for the information. I figured that was the way they were made after a number of member's replies and pictures they sent. I've made a deal and sent the money for an automatic plate. I'll keep you in mind if the other deal goes south. Thanks,Hal
88hurstolds
Apr 15, 2014 04:32 PM
jstrits
Jan 10, 2014 08:05 PM
1k442
Feb 2, 2012 10:45 AM
Want-A-Vert
Jan 15, 2007 12:02 PM
