Need 1 axel for my 68 Cutlass
Old Jul 23, 2012 | 04:29 PM
boese1978's Avatar
I had a spun bearing......anyone ????? I am in Minnesota.
Type "O", non posi.
Thanks!
Old Jul 23, 2012 | 04:55 PM
Rickman48's Avatar
Which side?
I believe there's a small difference.
Old Jul 23, 2012 | 05:01 PM
boese1978's Avatar
No difference to the best of my knowledge....can anyone confirm?
Old Jul 24, 2012 | 05:04 AM
507OLDS's Avatar
They are the same for either/both sides.I don't think I have any spares,but I will look.
Old Jul 24, 2012 | 05:07 AM
boese1978's Avatar
Appreciate it! I need it!
Old Jul 24, 2012 | 05:35 AM
ROCKETMAN269V's Avatar
Smile Need 1 axel for my 68 Cutlass
I should have one; I'll have to check. Thanks, Bob.
Old Jul 24, 2012 | 06:14 AM
boese1978's Avatar
Anyhelp is appreciated guys!! Not having much luck finding one locally.
Old Jul 24, 2012 | 06:27 AM
Aron Nance's Avatar
Tears ago Big Red did the same thing with an "O" type. The tech removed the axle and I took it to a machine shop that specialized in turning crankshafts. He welded up the worn part where the bearing "went", then turned it on his lathe to the correct size (as I recall). Then got a new bearing pressed in, and it worked fine. The only problem: machine shop owner said it would hold up very well, BUT (don't you just hate that), if you were drag racing it a lot, it would probably break. Sorry, I don't have an extra good one, and that was my problem, then.
Old Jul 24, 2012 | 06:34 AM
boese1978's Avatar
My machinst had heard of that being done too but it is a pretty expensive thing to do, he says, he also mentioned the "iffy" part of the process too....so, still looking for a useable one....
Old Jul 24, 2012 | 06:36 AM
11971four4two's Avatar
MOTORHEAD
Hey Steve
Got your message. The last time anyone asked me for an axle shaft B.Trick squared them away. Did you try monzaz here on classicO???
I will ask the few loco , I mean local , 68 guys I know about finding you one.
Good luck in the search
Old Jul 24, 2012 | 08:49 AM
jensenracing77's Avatar
side question? are all O type axles the same other than the heavy duty O type. i have several O type single track rear ends that i would be willing to part out.
Old Jul 24, 2012 | 09:09 AM
boese1978's Avatar
Can anyone else chime in here as I am not sure......to recap, I have a non posi, type "O" 2.73 gear, 12 bolt cover ( I know it is actually called a 10 bolt inside).....
Old Jul 25, 2012 | 05:37 AM
Bob Kelso's Avatar
It should be a 28 spline axle with that gear ratio and a sealed bearing ./ I have some spares . I am located on the Wisconsin - Illinois border and can ship it to you . Asking $50 plus UPS shipping . Let me know if that works for you . BOB .
Old Jul 25, 2012 | 06:44 AM
boese1978's Avatar
Hi Bob, thanks......I am a bit concerned that I could possibly end up with another with a spun bearing. Mine was spun by only a few 1000'ths of an inch and it was not obvious until I had the bearing removed and the shaft measured. Does the one you are offering have the bearing on it? If not, could you measure the shaft where the bearing sits?
Thanks!!
Old Jul 25, 2012 | 06:47 AM
507OLDS's Avatar
67-69 Cutlass/442 had the same 28-spline shaft,with sealed bearing.
68-69 Vista Cruiser is different
70 Cutlass/442 is different
70 Vista is different
I found one that will work,but if someone else has one closer,great.I would never weld & turn one.Usually,the person doing that repair will talk you out of it.If you end up breaking the axle,you will now have to find a new 1/4 panel & do some bodywork,from the wheel coming off your car.
Old Jul 25, 2012 | 07:09 AM
507OLDS's Avatar
You need to have the bearing off to confirm that the surface is perfect.Those shafts were made of a softer material,and the shaft would actually shrink under the bearing,causing it to spin,and therefore turn the journal down even more.
Old Jul 25, 2012 | 08:00 AM
Aron Nance's Avatar
Guess I was lucky, worked well for about 12 years, until the idiot in the Beemer deided to total Big Red for me......................
Old Jul 25, 2012 | 09:11 AM
boese1978's Avatar
Yea, I would not do the welding either, I guess they are also heat treated so that would need to be "re-done". I ordered one from opgi so I should be good as long as it fits.....
Old Jul 25, 2012 | 11:55 AM
Bob Kelso's Avatar
I removed the old bearing which popped when i pressed it off , it was on there very solid . The axle shaft measures with my dial caliper and it was 1.378 od where the bearing and lock ring sit . The bearing i have here is a BCA - RW 507 BR . It measures 1.377 ID and the lock ring measures 1.370 ID . I can clean the axle and bearing retainer plate and install the bearing for just the price of the bearing if you want . Let me know . Thanks BOB
Old Jul 25, 2012 | 12:52 PM
507OLDS's Avatar
I sell new ones by the pair,for about $280.00-$300.00 shipped. 1541 material. Far better than stock.
Old Jul 27, 2012 | 03:14 AM
Yellowstatue's Avatar
I had my 31 spline welded and it broke a couple years later (from a 1-2 shift) and bent my quarter panel
jankyrre
Drivetrain/Differentials
Apr 13, 2012 07:37 PM
monzaspyder79
Jan 27, 2010 05:19 PM
D Appeldorn
Jan 7, 2010 11:41 PM
redvettemike
Jun 3, 2009 06:52 PM
kaptmikey
Feb 25, 2009 04:45 PM
