1968 442 rear axel ratio
Old Apr 12, 2012 | 12:21 PM
jankyrre's Avatar
Hello.
New member from Norway.
I am working on a 1968 442.The rear axel is stamped R2,no date code.I know this correspond to a 2,56:1 ratio,but was this axel ever an option on the 442 or has it been installed later?
Old Apr 12, 2012 | 12:32 PM
GAOldsman's Avatar
"Car"mudgeon
It was standard in the '68 442 with automatic transmission either M-31 or M-40 unless ordered with an upgrade.
Old Apr 12, 2012 | 12:33 PM
GAOldsman's Avatar
"Car"mudgeon
Oh and welcome aboard the CO
Scot
Old Apr 13, 2012 | 05:08 AM
jankyrre's Avatar
I looked in a -68 salesman guide or whatever the called the book,and the way I understood it the 2,56:1 ratio was the standard axel on a 442 with the L65 option.
Other than this unavailable as an option on a 442.
Is this right or wrong?
Old Apr 13, 2012 | 06:06 AM
72 w29 all green's Avatar
Not sure jankyrre but other '68 guys will chime in. I will add that about a quarter century ago, I was second owner of an original-condition Saffron '68 442 with automatic for a short while and it had a 3.08 rear.
Old Apr 13, 2012 | 06:57 AM
copper128's Avatar
Lt. Buzzkill (ret.)
I think the 2.56 was standard on the 442 with Turnpike Cruiser option.
3.08 would be standard with the regular 442 & automatic trans.
You are correct Jankyrre
Old Apr 13, 2012 | 08:15 AM
allyolds68's Avatar
Like Copper128 says above. According to the assembly manual the 2.56 was ONLY available on the Turnpike Cruiser Option for a 442. It was not available on any other 442 tranny combinations
(Look at the Assembly Manual, Section 4, Page 104)
Old Apr 13, 2012 | 02:17 PM
jankyrre's Avatar
Thank you guys.
Do I actually have a TC.
Is there any way to find out?The car still have the original engine and transmission.The trans.is marked OH.
And yes it have a 2bbl.carb.,but I am certain this was install later.
Carb.from a 69 350.The number is 7029156
The intake is marked H casting nr.388625
The aircleaner also seems to be from a 350.
I know about the sticker on the oil filler tube,but that is gone.
Old Apr 13, 2012 | 06:43 PM
allyolds68's Avatar
Thank you guys.
OH was only used on the Turnpike Cruiser. Does the partial VIN on the tranny match the car VIN? If so you have a documented TC.
The air cleaner has OE silk screened on it and it is the same air cleaner as the 350 2 bbl.
Old Apr 13, 2012 | 07:37 PM
Octania's Avatar
Thank you guys.
A TC 442 is nothing to be bummed about.
Enjoy it
Should be more economical to operate
swampjuice117
Jun 25, 2015 07:23 PM
jordan845
Drivetrain/Differentials
May 15, 2014 06:21 PM
monzaspyder79
Jan 27, 2010 05:19 PM
D Appeldorn
Jan 7, 2010 11:41 PM
redvettemike
Jun 3, 2009 06:52 PM
