68 442 axel
Old May 14, 2014 | 07:27 PM
jordan845's Avatar
Question 68 442 axel
I put new bearings and seals on the axel shafts . I put the axel shafts in the house but axel seal stick out . Should I take the inter seals out?
Old May 14, 2014 | 07:52 PM
dnmfranco's Avatar
pm sent
Old May 15, 2014 | 11:43 AM
jordan845's Avatar
Here are some pic of it .
Old May 15, 2014 | 01:28 PM
Um, is that an OUTER seal I see between the bearing and the axle flange?
That would be your problem, as there is no outer seal used, only the inner seal. You don't have the bearing pressed all the way onto the axle, since that seal is in the way. It also appears that you've bent the retainer flanges trying to get this to seat. Sorry, but time to take it all apart, flatten the retainer, and reassemble it correctly. This is where the Chassis Service Manual would have saved you the time and money.
Old May 15, 2014 | 03:43 PM
BlackGold's Avatar
Pshaw!!! Who needs knowledge when you've got a hydraulic press to compensate?
Old May 15, 2014 | 04:20 PM
Agreed. The early O-Type rears ('67-'69) used the 8594S seal that presses into the end of the axle tube. The '70 used the 712146 seal that presses onto the axle shaft, same as the corporate 8.5" 10 bolt rear.
Now my question is do you have the correct bearing for the early O-Type? The early ones use a RW507C sealed bearing (sealed because there is no gear oil going to the bearing due to the inner oil seal) and the later ones use the Timken Set9 tapered roller bearing (open bearing gets oiled by the diff fluid).
Old May 15, 2014 | 05:09 PM
jordan845's Avatar
Yes I do now but when I put the axel back in with the right bearing how hard is it to get it in the axel housing?
Old May 15, 2014 | 06:16 PM
Not too hard. You have to get the splines on the end of the shaft aligned with the side gear in the diff, then the bearing is a slightly tight fit going into the end of the axle tube. It should go in at least partway, then the retaining flange will push it in the rest of the way when the nuts are tightened. Make sure there isn't any crud or any dings in the end of the tube where the bearing sits.
Old May 15, 2014 | 06:21 PM
jordan845's Avatar
Thanks for the help
swampjuice117
Jun 25, 2015 07:23 PM
jankyrre
Drivetrain/Differentials
Apr 13, 2012 07:37 PM
D Appeldorn
Jan 7, 2010 11:41 PM
redvettemike
Jun 3, 2009 06:52 PM
kaptmikey
Feb 25, 2009 04:45 PM
