Brake Drums Needed
Old Aug 14, 2012 | 06:16 PM
briane's Avatar
Brake Drums Needed
Looking for new rear brake drums, 9788681.
Thanks,
Brian 315-677-7813
bedward@dreamscape.com
Old Aug 14, 2012 | 08:16 PM
67442HT's Avatar
Smile
Napa has them, part number 4401136
Old Aug 15, 2012 | 03:44 AM
briane's Avatar
Thanks for sharing that with me. I'm in need of ones that match the originals. I'll stop by the NAPA distribution center here and check out what their's looks like.
Old Aug 15, 2012 | 05:45 AM
507OLDS's Avatar
What car are they for?
Old Aug 15, 2012 | 06:14 PM
briane's Avatar
These are the 9 1/2 X 2" rear drums. They're called out for 64-72 Cutlass, and 67-9 Lemans and Firebird.
Old Aug 15, 2012 | 06:45 PM
jeffsims's Avatar
1967 442
Inlinetube.com has replacements.
Old Aug 15, 2012 | 07:02 PM
briane's Avatar
Thanks, however I'm in need of the original style which doess not have the cast fins around the periphery.
Old Aug 15, 2012 | 07:59 PM
copper128's Avatar
Lt. Buzzkill (ret.)
Are you looking for the Olds bell shaped multi-piece welded drums?
If so, I suspect they may be very hard to find in NOS condition. Used ones are fairly common still.
I have a pair off my '67 442.
Old Aug 15, 2012 | 08:03 PM
briane's Avatar
Yes, I believe that is their construction. NOS condition would be ideal, I would like to locate an excellent pair. Do you have some available?
Old Aug 15, 2012 | 09:09 PM
Rutger34's Avatar
68 Delmont 88 Convertible
I found mine at Kanter Automotive.
Old Aug 16, 2012 | 03:41 AM
briane's Avatar
Thanks, I'll take a look at what Kanter has available also.
Old Aug 16, 2012 | 05:06 AM
507OLDS's Avatar
That is why I asked.The 71-72 did not come with that style of drum.Those had the fins.The 69 & 70 had the smooth bell or lampshade appearance for sure.These drums are steel,not cast.There is also a smooth,non-finned drum,that is cast,but I think those came on the Chevys.
Old Aug 16, 2012 | 03:31 PM
briane's Avatar
Thanks for sharing the additional information. I have a couple of photos of the correct ones but I haven't had the opportunity to check out an actual drum. I was hoping to find a nice pair here. I believe the non-finned cast drums are found on Chevys through perhaps the mid sixties.
A somewhat related question, when did Cutlass change from the 2-piece to 1-piece front rotors? I know for Chevelle it was in April 1970, probably assembly plant dependent. I had one person suggest it was around November 1969 for Oldsmobile.
Old Aug 17, 2012 | 06:05 AM
507OLDS's Avatar
I have an October/69-built car that has the 2-piece.They have never been off.Everything that I have owned that was built in December/69 and later,had the 1-piece rotor.
Old Aug 17, 2012 | 04:44 PM
briane's Avatar
Thanks, that very useful information on the rotors. My car is December 1969--I'll use the one-peice.
coppercutlass
Brakes/Hydraulic Systems
18
Dec 6, 2011 01:00 PM
bigblockfan
Jul 28, 2011 04:44 PM
my69olz
Jul 2, 2009 08:27 AM
skaboy 40
Apr 12, 2007 08:22 AM
jskosk919
Jul 4, 2006 08:31 PM
