looking for rear brake drums 1962 dynamic
can't seem to find these drums any where are there any other cars like an plymoth that can be used as a crossover part or does someone have any other sorces that i may have overlooked been to kanter
Another option for 62 Dynamic drums
Before spending big bucks with Fusick, here's another thought. The 62 D88 uses the same 11" x 2" rear brakes that have been used by GM forever on full size cars and half ton trucks. All of these have the 5 x 5" bolt circle. If function matters more than absolute correctness, I'd snag the rear drums off an 80-90 B-body wagon in a wrecking yard and try it for size. If it works, great, and if not you're only out $10-$15. Note that only the wagons and police/taxi four doors use the 11" brakes and 5 x 5" circle.
Really? Where'd you find that? I'm not doubting you, I'd just like to know, 'cuz I don't want to be giving people the wrong information.
My '63 parts book shows the same number (583112) being used from '59 through '62. '63 is a different number (588142). My newer books are at work. That's why I posted the numbers, so I can refer to them when I get to work tomorrow. But they could all very well supercede to one number.
Paul
Paul
As I noted before, given the way GM uses common parts, I'm willing to bet a cold adult beverage that almost any 11" x 2" GM drum with the right bolt circle will work. That covers the 80-90 B-body wagons, Astro vans, and 88-91 half ton pickups with the 5 x 5" bolt circle.
Well..... I admit I HAVE found errors in Hollanders, though usually they err on the conservative side. For example, the show unique front spindles for 69-72 442s with disc brakes with no changeover to the equivalent Chevy/Pontiac/Buick A-body cars. I have personally done disc swaps onto Cutlii using Chevy and Pontiac donor cars with no problems.
Rocket Richard
Brakes/Hydraulic Systems
Nov 4, 2010 01:27 PM
