View Full Version : Parts Wanted
- '67 425 dipstick and tube
- 1968 Oldsmobile 442 2dr coupe HOOD
- Quadrajet 7040257
- 67 88 Headlight trim rings
- 70 cutlass rear patch panel
- 62 Super 88 Transmission dipstick tube needed
- Looking for rear fender lip
- power antenna
- 1970 standard size pistons
- Needed, LEFT wheel opening moldings for 76-77 2dr
- Quadrajet 'CC' Secondary Metering Rods
- 1967 442 Window Sweeps
- OEM Catalytic Converter 76 Cutlass 350
- Wanted: For 2dr 76-77 right inside upper upper door panel
- neutral switch
- '66-'67 Toronado 8-track mounting bracket
- 1967 Toronado radio knobs
- Need camshaft for 57 Super 88, 371
- 1978 Cutlass Lyon Series Steering Wheel
- Can you tell me what this in dash tach is from and where one can be located??
- W a n t e d : 1970 350 motor
- Exhaust manifolds for 371
- KA Heads Needed
- 455 Crank
- 81-88 2dr cutlass finger glass tag bracket rear
- 1967 442 horn parts
- 66 Cutlass dash insert
- 1967 Cutlass dash brake warning light
- 69 center console repair piece needed
- WTB 71-72 Cutlass 350-455 19.5” fan
- 1964 olds Cutlass auto trans JT floor shifter
- 1970 Cutlass S Passenger side Grille
- 1965 442 bumper braces
- Power steering pulley 382418 JO
- ISO 70-72 OAI Hood Lock Pin Springs
- 67 Cutlass/442 stock steering wheel
- Hood louvers
- ISO 1100890 Alternator
- 71-72 LH front bumper turn signal lens
- 70 442 Throttle Cable
- 1966 67 442 air cleaner
- T3 low beam headlights
- ISO 7040253 70 MT Q-Jet
- Road Draft Tube for '55
- Distributor Hold Down
- 1970 442 Alternator 1100880
- 68 cutlass supreme interior sail panel lens
- 1986 oldsmobile custom cruiser vent shades wanted
- Water pump pulley '71-up A/C application
- 1969 olds 442 front floor mats
- Heads #4,5,6
- 1968 442 passenger front fender
- transmision cable bracket
- 1963/64 Oldsmobile 394 Timing Cover
- Single speed wiper crank arm
- 1966 f 85 deluxe holiday coupe square upholstery buttons
- 1938 Olds
- WTB- cooling fan w/clutch 7 blade 19-19.5
- Olds 350 heads
- 1937 F37 Hood
- 3/4-16 Spindle Nut, Left Hand Thread
- 68 442 trunk trim
- Wanted--69-72 GM TILT Steering Column Lock-Plate Cover
- 1975 Cutlass 4D Need Passenger Front And Rear Doors
- 2002 Intrigue Final 500 interior door parts.
- Vent Window Handle & Turn Signal Lever
- 67 cutlass clutch linkage
- 65 cutlass bumpers and console
- chrome a/c vents
- 1973 Cutlass NOS Dash Applique and Side Window Clips
- Need a 1964 oldsmobile 394 v8 oil pan
- 65 cutlass passenger low beam bucket
- Glove Box For F-85
- 70 442 Air Cleane4r Base, 455
- Tailgate torque rod retainer 1964-1967
- 69 Cutlass 442 NOS only rear marker light bezel needed
- Wanted 1970 Cutlass rear bumper, left quarter panel, trunk deck.
- Need Wiper arm, Finland
- 1969 - 72 Cutlass Roof Weatherstrip
- 68 442 coupe trunk lid
- blower switch
- Blower switch for my 65
- 1967 (1966?) front center bumper
- Wanted: Sports Mirror pedestal RH 1970 442
- Wanted: Sport Mirror, RH side 1970 442
- 1957 Super 88 371 Pulleys Wanted
- 1970 442 Master Cylinder Lid
- 1973 Heater Control Valve
- 1968 Oldsmobile 442 Hood Hinge
- 1978 1979 1980 Cutlass SALON coupe (2 door) interior
- 66 F85 club coupe front and rear interior panels and trim
- WANTED: Shift indicator Column Bracket
- WANTED: 79 Holiday88 Rear Window Glass
- Heads wanted #5 or #7
- 1960 Fiesta wagon gas tank
- WANTED: an unrusted or NOS rear Impact bar for my teal 1994 Cutlass Supreme 2 door.
- 67-68 Briggs and Stratton key blanks
- WTB: Clips #20076165 79-80 Cutlass/Regal
- Dust cover for the torque converter - 442 1971
- 69 Cutlass tail light panel
- Wanted, front bucket seat cover for 1968 Cutlass/442
- 1983 hurst olds alternator adjuster bolt
- Wanted 1966 Olds 442 Parts
- 1968 Oldsmobile 442 Hood Hinges
- Rear Wing
- Power door lock
- 1966 4 speed shifter hump
- Parts for 67 442 and/or 68 Cutlass
- 1975 Cutlass Salon 15” wheel cover plastic center caps
- Parts needed 1970 Olds 98
- 72 sport steering wheel hub
- 68' Cutlass Convertible RH rear quarter
- wtb used valve covers near naperville
- selector cluster gear
- 1987
- 1969 NOS Headlamp Assembly
- Quadrajet 7040250
- Wanted 1970 w30 pulleys
- Wheel cover key
- Door Handle Mechanism
- In Search Of! Olds 260 Engine Chicagoland
- 1960 Olds 371 Lifters (NOS)
- Flywheel and Bellhousing needed
- BOP 10 bolt
- 1964 F85 power steering pump
- Tic Toc Tach
- g-body wing
- 455 Dual Quad Tunnel Ram
- '68 to '72 VC tailgate belt trim clip needed
- 57-58 Lower control arm
- 1971 Cutlass Door Panels Needed
- 71 cutlass ac padded dash black
- Want 1970 cutlass carb for 350 small block
- Rear Bullet shaped side chrome molding
- 1967 Tilt Steering Wheel
- '65 A-Body Right Low-Beam Headlight Surround
- Anyone with an extra pair of engine mounts?
- 5210 seat belt retractor covers
- Broken '70 Cutlass 'S' grille pieces
- 88 Custom Cruiser parts
- 62 Cutlass Heater control valve
- 1965 Delta 88 coupe LH Driver rear quarter trim (before tire)
- Wanted 1970 cutlass hood.
- 70 Cutlass Convertible Complete Dash
- 1970 Driver door latch
- 66/67 cutlass lower rear 1/4’s
- WTB GM B Body Wagon Rear Speaker Harness
- 61 dash
- Ash Tray inserts for Rear Seats
- 1986 to 1989 toronado lower front valance
- 1968-1970 door panel clips needed...
- 68 Headrest
- 57/58 371 oil pan
- 1970-72 NOS Remote Door Mirror
- 72 Cutlass Supreme NOS Decklid
- 70 #5 thermostat housing 71 bittersweet parts
- 1964 oldsmobile rear motor mounts
- 1970 radio delete plate wtb or a picture of one?
- 1972 350 4bbl Intake
- 61 Dynamic 88
- ISO N78 Rims
- Wanted for 1966 Vista Cruiser
- 1965 f85 rear quarters
- 1975 Cutlass (442) Front Bumper Stud
- 72 Olds Cutlass Supreme 15 inch trim ring
- 1968 Oldsmobile Delmont 88 right front fender trim
- ISO rods & pistons
- 394 Distributor
- 1970 98 Demand Washer Pump and Relay
- 1969 cutlass LF bumper bracket wanted
- 57 Olds 98 convertible frame
- Rear bumper 64 jetstar
- Parts wanted 1971 Cutlass
- '72 Windshield Header Trim
- Original new front exhaust pipes wanted 1968 442 convertible
- Original new rh muffler wanted
- Original size 1968 442 convertible front pipes wanted
- WTB 1 SS2 bolt on center cap
- 70 olds hood L shaped eyebrow wanted
- 58 olds engine parts
- Custom Cruiser Wheel Opening Trim
- Olds 455 parts
- 69 driver side seat belt retractor
- Looking for 455 Heads Near North Florida
- WTB NOS Starter for 1972 Cutlass Supreme 350 4bbl/Th350
- 72 Supreme Passenger drip rail molding
- 1970 Oldsmobile Bucket seat strap.
- 69 Post Quarter glass trim
- Wiper Switch Hardware
- Door hinges 1965 cutlass convertible
- ISO 63 Starfire Rear Glass
- ISO 1965 Cutlass front bumper
- 65 Jetstar 1 (Back Glass)
- 69 Cutlass Trunk face molding, peak molding
- Right door outer belt molding
- 1967 Oldsmobile Cutlass Convertible Front Door Panels
- Center Link for 1963 F-85
- Wanted -- R12 Freon, bring to Dayton Nationals
- 1965 B-Body Brake Pedal and E Brake Rubbers
- 1972 olds 98 gas tank
- 66 cutlass wire harness brackets
- Bench seat armrest bolt finishing covers
- 1965 Cutlass Backup Lights
- 72 D88 trunk lock cover/emblem
- R12 wanted
- 65 Cutlass hood
- 1965 442 clutch fork extension
- WTB - VC Front door armrest pads '68-'72
- 76 s
- Exhaust Manifold - GM #417754RH
- 66 cutlass “ Oldsmobile “ front hood molding
- 76 Cutlass S header panel
- Need new side mirror for Olds 1956
- 65 442 non-AC upper alternator bracket
- 92 Toronado
- Wheel opening trim 71 vista
- 1970 4 core radiator side tank
- ISO 66 F85 Deluxe Holiday Rocker Molding Clips
- 69 headlight and wiper switch bezels
- 1969 Ninety-Eight Rear Drums 2267
- 1969 Cutlass 2 Dr vacuum door lock actuators Nos preferred
- Help I need a dip stick
- Oil Sender Unit 6462137
- 71 Vista trim
- 1970 8 track wood grain faceplate
- Wanted 1956 Olds front windshield
- Rear Brace 1970-1972 8 track Cutlass 442 Hurst Olds
- ‘69 convertible ash trays
- 1972 Cutlass Door Pull Straps
- Wanted, 1968 88 or 98 front bumper in the NE states.
- WTB - plastic "pockets" for splash shields
- Bumpers for a '72 98
- Wheel center caps 10180878
- Quadrajet Primary Throttle Plates
- Olds 350, 403, central ky
- 1972 Intake Manifold for 350 4BB
- 66 Cutlass Front Fender Extension
- 67 442 Wire wheel cover center cap
- Wanted: White Headrests 442
- Choke tube setup
- 66 Cutlass Washer Fluid Cap
- ISO 66-69 OEM 4 Speed shift rods/arms
- 1970 Cutlass Parts needed
- Rochester 2 Jet
- 1968 Woodgrain Steering Wheel
- 68 cutlass engine and ac harness
- Trunk lid
- wanted 394 intake and or carb too.
