View Full Version : Parts Wanted
- Outside mirror, passenger side
- ISO 1970 Cutlass S Exterior trim
- Deck lid, 68 Cutlass convertible
- ISO 69 Cutlass parts
- Small block 350 edelbrock performer RPM
- 1970 Cutlass Supreme - Hood Spear Molding
- Wanted rust and damage free 69 Right side cutlass quarter
- 1967 Delta 88 4 door
- Used Headers 455
- Wanted 1971 OK Transmission Tag
- Wanted rear 1/4 windows 68 cutlass s conv.
- Wanted 8 track wiring connectors to radio
- Wanted 1970 W-31 intake,carb, and air filter assby
- Split Timing Cover Wanted
- 70-72 Bucket Headrest (1) and Bucket Seat Plastic Back
- TH400 or 350
- 68-72 arm rest bases and pads
- T44 Hood Lock
- Wanted 72 cutlass supreme signal/multifunction switch
- Wanted good 70-72 console lid/hinge
- Wanted 1965 442 side scoops
- 70-72 front marker Lights
- 55 super 88 ignition bezel
- 1955 88/98 speedometer needed
- Wanted, 1969 Hurst Olds parts
- Oklahoma Dealer Deck Lid Emblem
- Wanted: '66 F-85/Cutlass/4-4-2 Rear Bumper
- 1975 delta 88 Royale convertible
- Black Floor Mats 70 442
- Wanted: 1971 Cutlass Convertible Full Frame
- Wanted for 1970 cutlass
- Wanted: Hyd Roller Lifters
- NOS 68-69 Cutlass fender emblem
- 1957 olds dash ac vents wanted
- 1941 Fender Skirt Trims & Badges Wanted
- Want To Buy - Power Steering Setup For An Olds 455
- 1965 442 4 speed complete console
- Need carb #7041312 for '66 Toronado
- 1966 cutlass 442 parts
- Wanted - 1972 Olds 98 Front Signal Cover
- 64 or 67 front end.
- Wanted 1972 Cruise bellows, rod and linkage
- 15x6 wheels
- looking for window regulator for 1971 cutlass
- looking for 1971 cutlass convertible rear seat
- 1970 sport mirrors
- Radiator Overflow Hose Clip
- Seeking Unrestored Carb - 7040257
- 1957 bumpers
- '66 Toronado parts wanted
- Wanted 1941-1948 Turn Signal Switch for Steering Column
- Need 1964 Olds 98 Transmission Roto-Hydramatic 375
- wanted 66 toro passenger exhaust manifold
- 68-69 vista/cutlass cruiser tailgate / 3rd row seat
- Coolant Recovery Tank
- Looking for 1968 Front Grille Cover
- 1967 Cutlass 3 sp floor shifter
- wanted 1965 442 side scoops
- 455 N crank
- WANTED 68 POST Coupe Doors...2dr post car
- 65 442 Engine - Parts wanted
- 1965 Starfire - Parts wanted
- 70-72 console lid and hinge
- 14 Steel wheels needed
- 70-72 cutlass convertible white upper rear piston cover panels
- Looking for a right front Frame Horn
- 1970 14" SSI wheel trim rings wanted
- Choke stove pipe
- 1961 Starfire or 1961 98
- Cruise Control Set-up
- 72 front seat belt retractor covers
- Tail light harness protective sleeve
- In need of new hub assembly, 1972 Delta 88
- 1970 Cutlass Parts
- Iso ss2 wheel
- Wanted GM P/N 5973631 for '80 Delta 88
- WTB '77 Delta 88 coupe Driver's Side Door
- 1972 Plain Supreme hood
- Fuel sending unit for 62 Dynamic
- ISO cragar sst wheels
- 1964 cutlass passenger side exhaust pipe NOS or NORS
- 1965 442 rearend SJ Code
- In search of a rear defogger switch
- Oil tube AC compressor
- WTB: 1972 HO Sunroof Parts
- 1949 88 lower driver side moulding
- WTB: Center caps for Olds Delta 88 SS-IV wheels
- 1972 cutlass frame
- Need inner rocker panels
- Wanted: 1967 442 parts needed
- need a 1966 442 fender
- 70-72 Headlight Switch Light housing
- modulator line for t350 70 Supreme
- Looking for Interior 77 Cutlass Supreme
- 69 cutlass/442 hood molding needed
- D heads wanted
- Looking for choke tube
- 1967 442 Alternator bracket (AC CAR)
- Wagon Roof Rack
- WTB: 70-72 Cutlass S/442 RH Quarter Panel
- 70 442 alternator brackets for 455 no AC
- Looking for a 4 bbl intake for a 394
- Early olds valve covers and oil pan
- Looking for a hi performance 350 rocket ASAP
- 64-65 two tone roof molding
- 442 parts?
- 1957 J2 Manifold Thermostat Housing
- 62 Oldsmobile 98 convertible
- 1965 442 Cutlass bumper filler metal clips
- 70 Cutlass air dam bolts
- Type O 3.42:1 Ring and Pinion Wanted
- 1972 Cutlass Supreme Parts Wanted
- 1974 Oldsmobile CS
- 1965 442 4 speed parts
- 1966-67 Cutlass/F-85 Lower Quarters
- 425 engine
- Center wheel hub 1987-1990 15" alloy
- 68-70 door opening windlace
- Power Steering pulley wanted..3791943
- WTB 1966-67 A/C Compressor Bracket
- WTB 1962 Jetfire emblems
- WTB passenger side spotlight
- 1970 Cutlass 442 front LH Bumper Bracket + Bolts for both sides
- '73 Delta 88 Convertible
- caliper brackets for '69 and up disc brakes
- 4 Speed Console Rocket Emblem
- 1965 dynamic seat belts
- 73 delta 88 convertible trim
- 1964 hardtop window stop
- Wanted: 71 Cutlass Supreme right front fender
- 455
- Wanted 455 04b aluminum intake
- 1967 442 air cleaner bottom
- Urgently looking for an 1933 oldsmobile straight 8 block or complete engine!
- WTB 70-72 Black Console, do not need shifter
- 1974 Cutlass S interior back seat window molding
- 67 cutlass thm 400 oil filler tube
- Wanted:1970-72 RH lower A arm
- 1942 98 parts wanted
- Wanted>64 Olds Rochester 4 gc Carb
- 1972 2 door coupe rear vinyl top trim
- Wanted - Alternator (1100890) for 1970 442 W30
- wtd 455 alum intake
- WTB 68-72 Vista Cruiser Rear Speaker and Grille
- WTB '55 Olds Hood
- 1969 Cutlass Trunk Lock Retainer
- Front license plate bracket
- 7a heads for a 403
- WANTED: 1971-72 Cutlass driver side front fender
- 53 olds super 88 parts needed
- Newb looking for 7a heads
- Wth a 442 spoiler
- Instrument cluster for 87-90 Ninety Eight Touring Sedan
- 1947 Front Bumper brackets WTB
- 72 supreme door sill plates wtb
- 72 cutlass supreme
- WTB lower left "Futurmatic" emblem '49 88.
- Hood latch handle retainer # 392703
- 455 Dipstick tube
- Need 90,91,92 Headliner Trofeo/Toronado
- 70 conv passenger door
- 1970 442 rear bumper
- 1965 Delta 88 wiper/ washer motor needed
- Wtb>66 cutlass 442 dash bezel
- Seat Belts
- 1970 ninety eight parts wanted
- Olds Emblem Wanted
- Wanted - Carlson Olds (St Louis) License Plate Frame
- '69 Cutlass 442 front bumper OEM not re-pop
- 1975 455 Quadrajet throttle bracket.
- 67-68 black steering wheel
- Vintage or new aftermarket oil pressure and water temp gauge
- 69 Cutlass blower motor speed switch needed
- WTB 1970 442 Headliner Bows
- Automatic trans to Manual
- Wanted: 1967 442 bumpers-front and rear
- headlight bezel
- Wanted To Buy: Complete 4 Speed Set-Up 70-72 Cutlass/442
- Wanted: 1967 Cutlass Q-jet in driving condition
- 46-48 Hood Trim
- 64 cutlass
- 67 442 exhaust manifolds
- 1969-72 Cutlass Bucket Seats
- 1971 Cutlass S Rear window moldings
- 72 cutlass supreme package tray end caps
- 70 442 Drip Rail Molding
- 1970 Vista Cruiser Axle Retainer Plate
- 70 parts needed
- 1974 Delta 88 windshield washer reservoir
- 64 cutlass doors
- 350 heads
- WTB 7/32" ID Ribbed Vacuum hose
- NASCAR Block
- WTB: Steering wheel for 84 Hurst Olds/442
- WTB: SBO intake manifold A4 #22504068
- victor
- 1974 Delta 88 Coolant tank cap
- 1972 cutlass supreme ROOF SKIN wanted original
- All four knobs for 8 track radio
- Wanted: 455 Olds Main Cap Bolts
- 1957 oldsmobile hood ornament
- Edelbrock Performer RPM Intake 7111
- Original roof top
- ISO Black '72 Convertible Interior
- 70-72 Supreme roof wanted
- Jetaway Trans. Slip Yoke
- WTB: 404847 Water Pump for 1970 W-31
- 70-72 OAI Plastic Top with Flapper
- 65 starfire hubcaps
- 1950 mirrors, brackets, and horn parts
- Ground clips
- 1972 center console automatic
- 1988 Oldsmobile Custom Cruiser Station Wagon
- 71 supreme horn pad
- 1970 Oldsmobile Colors & Fabrics Album
- I need one chrome stainless wiper blade 15 in
- 1970 442 Alternator P/N 1100890 - Wanted
- 1973 delta 88 parts needed
- Need 70412 OEM fuel pump
- 72 supreme needing the following
- Looking for deck lid asap!
- 455 4 speed crank
- 70 442 Trans Cover
- Current 64 F-85 Bits wish list - Help appreciated
- Complete Posi Rear End
- WTB 4 core rad tanks 70-72 442
- Rochester 4 bbl. base plate.
- 68-72 cowl weatherstrip
- 67 Cutlass tail light
- 70-72 Cutlass Side Marker Light Housings
- wtb 70 71 72 dash bezel
- 1966-67 Toronado wheel center cap beauty rings
- 77 442 int pieces
- Wanted: 1984 Delta 88 factory gauge pack
- 72 Cutlass Flywheel cover
- WANTED: 15" Wheels
- Cragar SS
- Hood Spear?
- 72 Cutlass Interior Door Handle Spring(s)
- Wanted: 1971/72 disc brake distribution block
- Wanted: 1967 Cutlass Left lower door hinge- good condition
- NOS SS1 Trim Ring
- Wanted: Parts for 73-77 Cutlass
- Serpentine Water pump pulley
- 1970 oldsmobile product selling information Manual
- Parts wanted NOS only
- 1968 Oldsmobile A/C Comp. Hold In Relay GM Part # 401700
- Need upper door trim for my 72.cutlass supreme hardtop coupe
