Rochester 4 bbl. base plate.
Old Oct 23, 2016 | 05:12 PM
tru-blue 442's Avatar
Old School Olds
Looking for 1 or 2 plates like this one. Thanks guys.
Old Oct 23, 2016 | 08:31 PM
Quadrajet Power's Avatar
What year is that from? I may have one, and I'm not far from you. I can probably repair that one also, so it could be utilized without any problems.
Old Oct 24, 2016 | 05:17 AM
Old School Olds
This one is for a 72 455, 7042251. I have another I need also. It's a 7042250 for
a 72 350. Thanks.
Old Oct 25, 2016 | 02:10 PM
Old School Olds
Bump.
Old Oct 26, 2016 | 06:08 AM
edzolz's Avatar
I've never seen one crack in the throttle shaft like that, or is that a crack?
Old Oct 26, 2016 | 07:22 AM
oldspackrat's Avatar
Adam,
I have a complete 7042251, I'll check my others for the other number.
Old Oct 26, 2016 | 07:46 AM
ROCKETMAN269V's Avatar
It could be the result of someone bushing the baseplate to correct a sloppy throttle shaft.
Old Oct 26, 2016 | 10:05 AM
garage goat 67's Avatar
Yes, That is a crack!
Old Oct 26, 2016 | 10:54 AM
Old School Olds
And a nasty one too. When shipping these bastids through the mail, whether it
be UPS, USPS, fed-ex, doesn't matter. They are horrible and just throw them around. I purchased this unit and it came single boxed and the throttle shaft was bent bad. I have straightened them before without disassembly with good luck but not this time...Crack. I have found that stuffed in a medium USPS box, inserted into the large flat rate, with some padding they will usually go unhurt.
Old Oct 26, 2016 | 11:10 AM
Old School Olds
Originally Posted by oldspackrat
Adam,
Thanks Scott.
Old Oct 26, 2016 | 04:46 PM
Dave Siltman's Avatar
I may have a core carb if Scott can't help.
Old Oct 26, 2016 | 05:02 PM
Old School Olds
Thanks Dave. Just need a couple of bases if I can find them.
Old Oct 26, 2016 | 09:06 PM
I will try to remember to look tomorrow also. I have piles of base plates sorted by GM make.
I see many cracked like that in shipping. I receive many each week sent to me to build, and many times there is no packing at all. And every carrier will try to destroy them.
Old Oct 27, 2016 | 05:13 AM
Old School Olds
Thanks Q power.
Old Oct 28, 2016 | 02:58 PM
I have some 2250 and 2251 cores, but they are complete and I use those to build from. I have some base plates, but only have 1 similar to the 72, but it has the EGR port so it must be 74 or so.
I can fix that one you have if you would like.
I will also keep my eyes open for some others for you.
Old Feb 4, 2017 | 07:19 PM
Old School Olds
Bump for Scott.
Old Feb 8, 2017 | 10:43 AM
70W30Jim's Avatar
Hello, I have a complete 7042251 RE 3121, stored away, needs complete rebuild, no damage in that specific area of concern on the base plate shown in your picture. I'll part with it, not sure what these are worth, but willing to help a fellow Oldsmobile enthusiast. Let me know if you have an interest and I will gladly provide photos.
Old Feb 8, 2017 | 12:39 PM
Old School Olds
Thank you for the kind offer Jim. PM sent.
Old Feb 9, 2017 | 06:29 AM
4R5's Avatar
4R5
I have 2 7042251 carbs, dates 2301 and 2891. Both in good shape, I can send pictures. Thanks.
ohiocutlassparts
Sep 13, 2017 09:29 PM
griffey57
Sep 8, 2015 12:31 PM
griffey57
Aug 3, 2015 12:19 PM
Uncle Hulka
Dec 28, 2011 08:17 PM
