Cruise Control Set-up
Old Dec 14, 2016 | 09:45 AM
bardaw's Avatar
Seeking a Cruise Control Set up for a 67 cutlass/442
Thank you
Old Dec 14, 2016 | 01:45 PM
cdrod's Avatar
Rodney
Thank you
Are you looking for stock '67 parts or will later model parts work? I have a complete OEM cruise set-up for a '78 model - all new parts. If you're interested, I'll take some pics and post them.
Rodney
Old Dec 16, 2016 | 02:05 PM
cdrod's Avatar
Rodney
Dealer installed Cruise Kit
Bardaw:
Here's a link to the cruise kit I have for sale.
https://classicoldsmobile.com/forums...tml#post975911
Old Dec 16, 2016 | 04:38 PM
lemoldsnut's Avatar
That is a very different system.
I have owned over 30 66-67 cars and never have I seen a full factory cruise system. parts on one or another but never all of one.
It is a very unique set up.
Old Jan 2, 2017 | 11:09 AM
lauralynne's Avatar
if a setup out of a 64 will work then I have one - http://seattle.craigslist.org/sno/pts/5938027902.html
I can be contacted directly at dandlrestoration at gmail
Laura
Old Feb 19, 2017 | 01:18 PM
Roger60's Avatar
67 Cutlass Cruise Control
The cruise system on a 67 Cutlass comes in many parts. I have a 67 conv. with factory cruise that was mostly disassembled when I got it, but I have found all the parts in boxes. Check out these pictures from way before the car was mine, you can see the vacuum servo above the throttle linkage as well as an electric unit mounted on the left wheelhouse. http://www.442.com/vcs/oldsowners.html.
You also need the turn signal lever with the button and the separate wiring harness to hook it all up, as well as a brake switch which comes with a special bracket. 2 separate speedo cables. Right down to the special clip to hold the chain on the throttle control. Kind of a nightmare when you have all the parts, less trying to locate them all. And I don't even know if it works yet!
Sorry, on the link, go to 64-72 then scroll down to Mike Carpenters 67 Cutlass Conv.
Old Feb 20, 2017 | 10:25 AM
tdhill01's Avatar
Did the 67 have the chrome fluted lever without the word "cruise" on it or did it have it too like the 69-70 stem?
Old Feb 20, 2017 | 01:08 PM
Roger60's Avatar
67 Cruise Control
First, we should move this thread out of classified, I don't know how to do that. To answer your question, lever does say cruise on it. Here are some pics of the system I have installed already. If you go with an HEI dist., you may have to space out the linkage.
98 man
Jan 7, 2015 03:13 AM
mruders
Feb 4, 2014 08:15 AM
mbrae5
Aug 18, 2013 06:24 PM
oldsmobilia
Jan 12, 2009 03:21 AM
ztim
Dec 22, 2006 10:17 PM
