PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 [79] 80 81 82 83 84 85 86 87 88
  1. Cowl / windshield area patch panel - 68-72 Cutlass - See Pic
  2. 1971 Cutlass Service Manual Wanted
  3. 1970 Toronado Trim
  4. Olds 12 bolt posi with 3 or 4 series gears
  5. Anybody have a set of Olds 455 Pulleys and Brackets?
  6. 70 442 wing
  7. 455 exhaust manifolds
  8. 1965-67 power bench seat base
  9. 1972 Cutlass Supreme rear Vinyl top trim
  10. need 76 442 interior trim
  11. 62 Olds starfire
  12. looking for wiring harness
  13. serrated washers
  14. 66 Delta sun visors.
  15. 64 Cutlass rear end section
  16. 1967Toro comfortron power servo parts
  17. Pinion snubber
  18. Jack
  19. Looking #6 Heads and 4-Barrel intake
  20. Anybody have a cheap Intake / Carb for a 72 Olds Cutlass 350?
  21. 1973 olds 98 rocker moldings
  22. 72 cutlass power seat unit
  23. WTB Milled SBO intake
  24. Toronado '66 needs some parts!
  25. 68 Steering wheel
  26. WTB: Tailpipe hanger bracket
  27. 1972 Cutlass front bumper guards
  28. Trunk/Deck Lid Molding
  29. Wanted: Hydra-Matic Transmission Tool Set
  30. 1970 w-31 carburator
  31. Hydra-Matic Transmission Tool Set Wanted
  32. TRADE 70 am/fm radio for a 70 am radio
  33. 70 Cutlass Sport Mirrors wanted
  34. 68 442 Front fender plastic clips
  35. Looking for wheel opening mouldings for 68
  36. 69 Toronado gas tank wanted
  37. 455 Valve covers
  38. 1986 Olds Regency
  39. 73 Cutlass interior
  40. vista wagon mldgs
  41. Seeking 1970 Cutlass Side Marker Light (amber)
  42. Parking Brake lense for a 67 Cutlass
  43. 68 442 shifter
  44. 1972 olds 88 misc parts wanted
  45. for 1948 Futuramatic 98
  46. 1964-66 Steel Wheel
  47. 73 delta 88 bumper
  48. Dash for 76 Cutlass
  49. WANTED 72 Cutlass blower motor & resistor
  50. gas pedal ball studs ('65 cutlass)
  51. Need an HEI distributor with VAC ADV for S.B.O.
  52. 65cutlass rt front park lamp assy
  53. Omega Sx shifter and console
  54. 79 Trans Am 403 frame motor mounts
  55. Looking for 65 cutlass,442 or f85 parts
  56. Looking for Black Interior pieces for a 72 Cutlass S
  57. Looking for a 4 barrel intake manifold for 62 dynamic
  58. Letter "A" Exhaust Manifold
  59. 425 Pistons
  60. Need a 1966 Tripower Oil Fill Tube
  61. 1973 Cutlass a/c controls
  62. A/c reciever/dryer sight glass cover
  63. A/C hoses and brackets 72 Cutlass
  64. Wanted mirror
  65. Olds Ebrock Rpm Intake
  66. w-31 carb 7040255
  67. 68 vert "s"
  68. 72 Olds Cutlass S Parts Needed
  69. 74 olds 442
  70. Rocker Arm Bolt
  71. 76 cutlas 442
  72. 69 Cutlass frt bumper
  73. M/T valve covers
  74. W25 screen
  75. 61 215 v8
  76. Wanted - '56 Fender Skirts
  77. 64 dynamic 88 parts wanted
  78. 69 Olds parts needed
  79. 53 Olds backuplight bezel
  80. Carpet needed for 1965 Delta 88
  81. SF rear end
  82. 1974 cutlass hood hinges
  83. Need front bumper and front lower control arms for 70 Olds 98
  84. trade 2 carbs 4 one or buy a 7040251
  85. Need a 4bbl Air Cleaner Assy for a 69 Cutlass
  86. Charcol canister
  87. LH front fender 66 Cutlas
  88. Need some radiator core support bushings
  89. 71 Cutlass Need Choke Pull Off Bracket
  90. 1975 Cutlass Supreme
  91. 1968 Olds 98 455 heat riser
  92. Looking for a complete cruise control kit 67
  93. Anyone in Seattle have a Starter i could TRY?
  94. Black rear seat back cover. 1971 Cutlass S
  95. Looking for Alt/P/S Bracket's
  96. Need wheelwell trim for a 71 Cutlass S
  97. 70 442 disk brakes
  98. 394 driverside duel exhaust mainifold and:
  99. Wanted: KM 1970 W-car water pump pulley
  100. 1961 Oldsmobile 4-door Dynamic 88 interior door panel...
  101. 3 line fuel sending unit for 80's Olds
  102. looking for a clean winshield washer fluid container
  103. WTB turn signal lever
  104. '67 88 Custom Coupe Wheel Trim
  105. Parts Needed for a 1978 Cutlass Supreme
  106. olds script valve covers/455 aluminum intake
  107. 66 delta 98
  108. 1965 Cutlass backup lamps
  109. Need 57 Olds Backup Light Lens
  110. 15" trim ring
  111. Back seat outside window trim for '74 Hurst
  112. 66 Toro:Desperately need green door panels and dashsurround
  113. 1970 cutlass hood hinges,hood tongue,and hood latch
  114. 70 Cutlass LH or RH Front Fender/71 Trade.
  115. any1 here rebuilt tic toc tachs??
  116. SBO "A" body headers
  117. Desparately Seeking Small Parts
  118. Wire harness connecter for convertible top switch on '70 Cutlass
  119. 68-69 Radio Faceplate
  120. 1952 olds 98 frt seat wanted
  121. heater/ac controls for 85 delta 88
  122. Throttle spring
  123. need rear window trim for 72 supreme
  124. Trunk lid needed.
  125. Wanted: Bench seat that will fit my starfire
  126. 73 delta 88 convertible
  127. 76 Cutlass Door Pull Trim cap insert needed
  128. 70 442 fenders
  129. Toro Oil Pan?
  130. 68 Cutlass map light lens
  131. A/C Compressor 1966 Dynamic 88
  132. WTB clutch and brake pedal for 65 Jetstar 88
  133. 1971 cutlass s missing unknown part please help
  134. 70 w-31 carb 7040255
  135. Trunk lid and drivers side fender needed 72 Supreme!
  136. wanted: complete set of 69/70 blue seat belts
  137. i need a back bumper 72 98 and int
  138. Intake manifold
  139. BBO Head Cores
  140. Looking for a carb
  141. Wanted- Steel wheels & misc. parts for a '68 Toro
  142. wanted some1 2 rebuild my carb RIGHT!
  143. 64 F-85 post car doors
  144. wtb 70 cutlass core support
  145. wtb manual transmission
  146. Medium Blue dashboard for '75 Cutlass
  147. 12 bolt olds 3 series open or posi carriers
  148. Power window motor
  149. 77 Cutlass Supreme Brougham
  150. 77 Cutlass Supreme Brougham
  151. 1978-81 Delta 88 Holiday Coupe horn button
  152. gbody olds cutlass rear bumper
  153. 72 Cutlass S Sports Coupe Chrome Parts
  154. 66 Cutlass Wiper Arms
  155. 3.42 ring & pinion for 7.5 GM rear
  156. 1986 Olds Full Size Power Antenna
  157. 75 Granville parts
  158. 1970 big E 442 heads or entire engine
  159. Help Brake parts needed-62 Super 88
  160. 65 cutlass parts wanted!!!
  161. Rubber seal on heater core
  162. DS header for g-body
  163. Voltage regulator
  164. 73 Cutlass S Parts wanted
  165. 70 71 72 center console box insert and chrome
  166. TH400 Slip Yoke
  167. Wanted: 70-71-72 Floor shifter
  168. 1963 radiator support assembly
  169. 64-65 Cutlass Passenger side DOOR
  170. WTB oversize 403 pistons
  171. 1963-64 Starfire LH duel exhaust manifold
  172. 1967 delta 88 air cleaner
  173. Still need GT trans
  174. Need Rocker Panel Stainless Trim for 1975 Delta 88 Convert or 2Dr
  175. 6 way seat adjuster
  176. 1966 ninety eight Passanger Exh. Manifold
  177. 69 Cutlass Fuse Panel
  178. 1957 371 engine Road draft tube
  179. Steering wheel
  180. gbody posi rearend
  181. mirror for 67 Delmont 88
  182. 72 quadrajet
  183. 55 98 holiday steering wheel wanted
  184. rear bumper
  185. Bracket Needed
  186. Vista tailgate trim
  187. 200r4
  188. Need 1965 or 1966 Windshield Washer Parts
  189. Looking for a 425ci
  190. flywheel cover (also called inspection cover ?)
  191. NEED 75-77 cutlass interior parts!!!
  192. 1988 FWD Cutlass Indy Pace Car Fascia
  193. looking for a 1956 steering column
  194. big car rally wheels
  195. Muncie M20
  196. 73 delta 88
  197. 1976 Delta 88 grilles
  198. 1968 442 hood
  199. Wanted: 1963 Olds Cutlass F85 Parts
  200. Looking for '68-'70 engine oil filler cap
  201. 1972 Cutlass fender emblem
  202. dash bezel for 80-85 delta 88
  203. 1950 '88 Hood crossmember and hinges needed
  204. 1971 "G" heads & manifold
  205. "The" 1970 455
  206. 1970 Olds 98 seatbelt retractor cover
  207. clock for a 67 delta 88
  208. Need 5 x 5, 14 inch wheels for 1965 88
  209. 1968 68 Cutlass S Passenger front fender Two piece molding
  210. 67 del mont 88
  211. 68 h/o axle housing,steerin column, whl rings
  212. 68 delta custom trim wanted
  213. door panels any condition that can be refabric
  214. 1964 Olds Dynamic 88
  215. Need parts for '69 442
  216. WTB 1972 Cutlass White Front Door Pulls
  217. Hurst repro wheels 4 3/4 GM pattern wanted
  218. 71 Cutlass Rad Support
  219. Wanted: Rear Axle 1964-1967 F-85 for 10 bolt.
  220. 68 Cutlass Supreme Curtesy Light Lens
  221. '73 Custom Cruiser license plate light
  222. Need 1968 442 deflector, stone guard
  223. 1972 442 Steering wheel
  224. Need QJ parts
  225. relay
  226. Weber injection style intake for 455
  227. 1968 Cutlass Parts, quarters, outters, etc
  228. For 66 442
  229. NEEDED;gt om case
  230. 71-72 cutlass S driver chrome door edge guard
  231. 1970 443 455 vacuum tree
  232. Rear Defogger Switch
  233. Head Rests
  234. Frame Mounts
  235. door pull strap
  236. Alternator Brackets for '68 455
  237. 71-72 W-25 ram air hood wanted...
  238. 394 cylinder head
  239. Parts needed for my 72 442 W30
  240. 1970 Olds 98 radiator overflow tank
  241. WTB: 1965-67 AM FM Mono Radio
  242. Wanting SSII Rims
  243. '73 to '76 455 & Toronado final drive wanted in southeast Fla
  244. 74 HURST Hood Ornament Script
  245. Auto shifter - detent pin
  246. 1966 Delta 88
  247. quadrajet carb
  248. grommet (bushing) for trans cable-Chicago
  249. fan schroud 69'delta
  250. big dog 455
