PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. 1970 cutlass front headlight housings
  2. W&Z Exhaust Manifolds Wanted
  3. 1972 Cutlass Supreme rear windshield trim
  4. Aftermarket Need Not apply
  5. 67 442
  6. ISO 67 cutlass frame
  7. 69 442 Parts Needed.
  8. Looking for a good set of number 5 or 6 heads.
  9. Battery Tray
  10. 1970 Cutlass Rear Bumper Wanted
  11. 1970 442 fender braces + hardware
  12. 1967 442 4 speed
  13. 1965 or 1966 98 Gas Tank anyone?
  14. 68 or 9 442 left side (driverside) rear quarter peak moulding
  15. "Factory Spare Tire and Black Steel Wheel" - Needed...
  16. Heater Control/Cables for 68 Cutlass
  17. 74 442/HO Header Panel
  18. 73 cutlass supreme bumper parts
  19. 68-72 Vista Cruiser Deflector, Light Clusters
  20. 1972 DeLuxe Steering Wheel Cutlass 442 Hurst Olds Vista Cruiser
  21. 67 Cutlass gear selector pointer......
  22. 69 442 side mirror/emblems
  23. 84 Hurst Olds Spoiler Mounts
  24. 65 442 tube headers needed
  25. 69 442 rear side marker bezel
  26. 1975 cutlass supreme
  27. Steering column
  28. 1972 cutlass
  29. '72 H/O Vinyl Roof Trim
  30. WTB. 1970 442 / Cutlass Clip for A/C Hose
  31. 65 Cutlass bumper jack, tire iron set
  32. 1968 400 G Block for sale
  33. 1979 Toronado Tail light assembly
  34. Front Dash Speaker '70 442
  35. Quarter panel passenger side 1970 hard top
  36. 1964 330 pulley and bracket
  37. NOS RH OAI Hood Latch Bracket
  38. wanted flywheel diesel 5.7 manual trans
  39. 1972 Cutlass Supreme Fender “Eye Brows”
  40. WTB NOS or New Scuff Plates
  41. 68 Cutlass Holiday passenger arm rest.
  42. 1972 Cutlass kick panel with speaker
  43. Power Steering Pitman Arm
  44. 1973 cutlass 442 front turn signal lights
  45. WTB stainless trim for 1968 442 hardtop
  46. O type axle retainers
  47. 1966 Toronado Fuel / Gas Tank
  48. 69 cutlass back drive
  49. wiper arm retainer
  50. 1957 dash fuel gauge.
  51. 1963 air cleaner body
  52. 1963 B-Body engine parts
  53. WTB- power mirror switch for 1982 Custom Cruiser
  54. 1970 W30 heat riser tube needed
  55. WP Pulley- 81 Delta 88
  56. 1967 442 center dash vent
  57. Looking For Rear Door Panels for 68 442 Convertible
  58. WTB 1971-72 delta 88 Heater/AC control switch
  59. ISO '53turn signal steering wheel switch
  60. 69 S Bench Seat
  61. Glove Compartment and Console Locks with Keys
  62. 1965 Cutlass passenger fender and front bumper
  63. 1965 Jetstar 88 Convertible Hood Hinge
  64. 69 442 trunk molding
  65. WTB ‘77 vista cruiser gas tank
  66. 1968 442 taillights
  67. 1969 Oldsmobile Toronado Fuel Tank
  68. 68 442/cutlass tail lights
  69. Newby here looking for some help
  70. 1972 master cylinder
  71. 1970 442 Three Core Radiator Wanted
  72. "WANTED - Rear Trunk Emblem for a 1963 Oldsmobile F-85"...
  73. rear defogger
  74. Wanted-1970 Door edge guard
  75. 1970 Oldsmobile Cutlass Control brake pedal switches and bracket
  76. WTB 1969 442 Original Gas Cap
  77. 1964 F85 wheel well molding
  78. Driver's side Dustcap for 1963 Dynamic 88
  79. 1970-72 Oldsmobile Cutlass Radiator
  80. wtb rochester 2 barrel carb
  81. 64 T handle shifter linkage (bracket)
  82. 77-79 Olds 403 Crank Pulley thats 7 3/16" x 2 1/4" deep
  83. 1966 A-Body Antenna Upper Spacer
  84. 1969 Deluxe Steering Wheel in Gold
  85. 1949 big 6
  86. 15” x 7 rims
  87. 65 Cutlass Clock
  88. Wanted L-69 tripower complete setup
  89. Looking for starter 1108333
  90. LF 73-77 console
  91. 1970 cutlass hot air tube
  92. ‘70 A Body Green Floor Mats
  93. Need rear suspension I-beam for 1995 Oldsmobile Achieva
  94. Parts Wanted: Innermost bumper braces (68 cutlass/442)
  95. 1972 Cutlass
  96. stereo 72 cutlass
  97. 1964 Cutlass Bullet Tachometer or Console
  98. 64,65 cutlass 4sp console parts
  99. 1969 Vista Cruiser C-Pillar Covers
  100. Looking for a 455
  101. 71 floor shifter bolt
  102. Window Crank
  103. Power Window regulators and motors for 72
  104. Looking for AC bracket for a 1976 Olds 98
  105. 66 Jetstar 88 1/4
  106. 1964 Cutlass hood
  107. SS2 wheel
  108. AC Cruise Master
  109. Help Brake Drums
  110. Wtb 71 delta 88 gas tank
  111. 14x6 steel wheel
  112. 1967 442 core support
  113. Looking or NOS Parts for a 1976 Olds 98 grilles and headlight surrounds
  114. 1994 Cutlass Supreme Conv. weatherstripping
  115. rocket 324
  116. Help! Need 1990 Custom Cruiser Headliner Clips
  117. 1968-69 rear window defogger
  118. WTB 1964/65 Cutlass Power Driver's Seat
  119. 1976 cutless dash
  120. 70-72 convertible right door
  121. WANTED - 1971 442 Rear Speakers
  122. 67 and 68 dash pads needed
  123. Parts Needed : 1969 Cutlass 442 Upper Bumper Braces
  124. Wanted: 65 -66 442 upper clutch push rod
  125. Rallye Pac tach shielded wire
  126. 1970 Cutlass alternator bracket bolt size?
  127. WTB: 1970 W-31 intake
  128. 1967 Cutlass Supreme Front End
  129. WTB 68/69 2 Barrel Carbs
  130. 1968-1972 convertible top boot- black? Other colors?
  131. WTB 1975 Olds 98 Front Clip or part car
  132. Need 1971 Cutlass S core support
  133. WANTED: 72 Cutlass Heater Blower Swith No A/C
  134. 70' BB OEM motor mounts
  135. 67, 68 cutlass horns
  136. WANTED: 72 Cutlass Wiper Motor
  137. 1960 convertible
  138. 1983 Hurst temp gage
  139. 76 delta 88 instrument cluster
  140. ARH Small Block Headers
  141. 1969 Delta 88 Both Bumpers
  142. Tall valve covers
  143. 5 piece rear side molding for 72 supreme
  144. 1970 Rallye 350 parts
  145. Wanted - 68 Cutlass Hood Hinge
  146. 1979 olds cutlass H/O parts?
  147. 68 cutlass front bumper
  148. 70 doors and trunk lid
  149. 66-67 cutlass/442 passenger rear, seat brace wanted.
  150. 1970 power steering pump brace - P/n 398669
  151. WANTED - 76 Cutlass Front Bumper
  152. 1970 Bench seat tracks
  153. 67 cutlass 442 tail lenses
  154. 71 Toronado parts
  155. 1960 98 trim piece
  156. Radio Faceplate
  157. W or X Left Side Exhaust Manifold
  158. 97 Cutlass Supreme driver door lock switch
  159. 70-72 Flat top wagon two tone trim
  160. 1938 Oldsmobile trunk mount license plate holder and lamp
  161. 1970 and 1965 Olds Parts
  162. W Right Side Exhaust Manifold
  163. Rally Wheels
  164. 1970 TCS switch bracket - intake bolt and nut
  165. WANTED - "1963 Oldsmobile F-85 & Cutlass Poverty / Dog Dish Hub Caps"...
  166. Wanted: 69 98 8 track housing
  167. Wanted KK water pump pulley
  168. WTB Rallye Pack Gauges & Cruise Control Kit for 72 cutlass supreme
  169. Olds Parts & Accessories Catalogue
  170. WTB 68 W30 Parts
  171. 70-72 Cutlass AC dash feed duct for left vent
  172. Tail lights
  173. 1973 steering wheel wanted
  174. WTB O65 BBO Dual Quad Intake
  175. 1957 Olds frame
  176. 70-72 Cutlass/442 front bumper guard rubber
  177. Wanted 1970 71 72 drivers door edge guard
  178. WANTED: 45 Deg cam new or w/lifters
  179. Left Side Exhaust Manifold 394 Duals
  180. 1964 `98 driver's tail lens assembly wanted
  181. 1972 Cruise Control brake switch bracket
  182. WTB: master cylinder
  183. 15x8 or 15x10 Aftermarket Wheels
  184. tail lights
  185. Looking for right fender script for 1957 Olds 98. If anyone has one please contact me
  186. Scuff Plates
  187. 1966 Ninety Eight
  188. Looking for a 1969 quadrajet for a 1969 442 7029250
  189. 71 cutlass s/sienna bucket seats
  190. Wanted 70-72 442 lower front fenders
  191. 1972 Ninety Eight rear window moldings wanted
  192. 1984 Oldsmobile Cutlass Calais
  193. 1970 cutlass 442 moldings needed
  194. Edelbrock Victor Manifold
  195. Upper door rail 1966 Cutlass Coupe
  196. '71 Cutlass convertible sun visors
  197. 1969 Oldsmobile Cutlass convertible frame
  198. Late 60's big Block Exhaust Manifold LH, casting #384785
  199. 1969 cutlass or 442 passenger headlight door
  200. 1970 Oldsmobile Cutlass TH400 driveshaft
  201. Radio faceplate and sport wheel horn mounting parts
  202. BBO Offenhauser Turbo-Thrust Tunnel Ram Intake
  203. Looking for front light bezels 64-66 Cutlass auto console.
  204. Parts for '70 442 convertible wanted - various
  205. 1969 442 or cutlass front bumper braces
  206. Windlace
  207. 1968 olds 98 Grille
  208. 15 x 7 olds SSII rally
  209. "WANTED - Set of Factory Floor Mats for my 1963 Oldsmobile F-85 Deluxe 4-Door Sedan".
  210. SS 442 Exhaust Tips
  211. WTB 64/65 ignition cylinder bezel (F85)
  212. Wanted 1972 cutlass supreme wiper motor
  213. 1979 camel steering wheel
  214. 1979 98 Regency Coupe Chrome rocker panels
  215. Steering wheel
  216. 3 speed manual
  217. WTB Complete Posi Unit
  218. ‘68 4-4-2 Original Wood Steering Wheel
  219. Steering Coupler BOLT
  220. Door panels- door panel trim 1966 Cutlass
  221. '65 Cutlass trunk letter "S"
  222. Fan shroud 1962 olds dynamic 88
  223. 1969 H/O back drive rod
  224. Set of 15 x 7 Rally SSIII Rims
  225. ISO 70-72 A/C Duct Hose
  226. Looking for one air bag
  227. 1963 215 Alternator Brackets
  228. Edelbrock 04B Intake
  229. Exterior Mirrors for 1972 Delta 88
  230. Wanted: 1990 Olds Custom Cruiser Bumper and Trim Parts
  231. License plate frame Chesrown Olds - Newark wanted
  232. 69 Cutlass original black bucket seat cover
  233. 455
  234. 55 Oldsmobile Power Steering Part needed
  235. 1100880 Alternator
  236. w / z exhaust manifolds
  237. 54-56 Convertible
  238. 1100552 Delco Alternator - '71
  239. Parts Needed: 75 Hurst Olds
  240. WANTED: 1964 Cutlass throttle linkage
  241. 1970 442 console redo
  242. 71-72 delta 88 rear bumper
  243. 1964 394 lower alternator bracket
  244. Wanted 408329 water pump
  245. Center driver floor support section, 72 D-88
  246. 1970 Oldsmobile trunk script 8700909
  247. Wtb/Advice on buying a 1972 olds cutlass supreme trunk cylinder lock
  248. 1969 442 bumper core
  249. Quarter extension moldings
  250. Need lower hood latch for 1940 Olds
