3 speed manual
Old Mar 18, 2021 | 04:21 PM
edzolz's Avatar
3 speed manual
Anybody have a 3 speed with shifter to fit Olds bellhousing? Must be close to Red Oak, TX. Will trade other parts.
Old Mar 18, 2021 | 05:51 PM
442crzy's Avatar
I have the 3 speed shifter with rods, lmk via PM if interested.
Old Mar 18, 2021 | 07:46 PM
2blu442's Avatar
I've got a couple 3 speed transmissions in Oregon if you don't find something closer.
Old Mar 19, 2021 | 03:41 AM
ROCKETMAN269V's Avatar
3 speed manual
Are you looking for the Saginaw (standard GM bolt pattern) or the Dearborn (Ford pattern)? Your bellhousing may have both bolt patterns.
Old Mar 19, 2021 | 04:39 AM
newmexguy's Avatar
Have an "ITM' three speed shifter, with rods, and plate, to mount to the tail shaft of a Saginaw transmission. Pulled a three speed IRON saginaw out of an oddball '71 Impala years ago, it had 49K miles, may? still have that, also.
Dave S southern new mexico 88012
Old Mar 19, 2021 | 07:33 AM
edzolz's Avatar
Standard GM bolt pattern. The bell is from an X body with cable pull clutch release. I'm not sure but I don't think it has the Ford pattern.
Old Mar 19, 2021 | 07:55 AM
lemoldsnut's Avatar
I have a complete 3 speed set up in a 66 in Oregon that has been road tested.
lemoldsnut@aol.com
Larry
541-815-4363
Old Mar 19, 2021 | 04:02 PM
edzolz's Avatar
Thanks for the replys from far away, but I think I can find one closer. Even a Chevy pickup transmission will work for me.
Old Mar 23, 2021 | 07:54 AM
edzolz's Avatar
TTT
Old Mar 30, 2021 | 03:52 PM
Ed, did you ever find a three speed? This Saginaw just popped up on FB marketplace. Of course, it's in PA.
https://www.facebook.com/marketplace...Anull%7D%22%7D
Old Mar 30, 2021 | 05:12 PM
RAG's Avatar
RAG
I have a 3 speed saginaw, came in my '65 Cutlass from the factory. Are you close to Ft. Wayne to pick up at the Pate Swap meet next month?
Old Mar 30, 2021 | 09:14 PM
edzolz's Avatar
I'm close enough and normally would go to the Pate, but this year I have to pass.
friesjh
Jan 14, 2021 12:03 PM
Chris6542
Apr 23, 2020 09:52 PM
oldsmoboogie
Oct 21, 2019 06:04 AM
1968ragtop
45
Mar 27, 2015 05:43 PM
cheffernan
Aug 30, 2013 07:06 AM
