I am looking for 2 bolts, both need to be the same. These are used to pinch the steering coupler and hold it tight on the shaft of steering boxes, and some columns need the same bolt to hold the coupler there. Some other columns have the flange for the coupler welded on. The bolts are 1.75" overall, from top to bottom. They are 1.5" from under the head/washer to the end of the threads. They are a 5/16", fine thread bolt with a 12 point head and take a 7/16 socket or boxed end wrench to tighten/loosen it.
I am no expert here. But I think they were used on older GM cars and then they changed the bolts to a larger 3/8" bolt which looks the same but needs a 1/2" wrench. I believe the the 3/8" was used later and I have another coupler which uses the 3/8.
I'll put up a picture of the bolt.
Thanks, Mike
Let me go look and see if I have any. I had some when I restored my car and may have them. Sit tight.
Bare with me as my power is out after the storms yesterday. Should be back on today.
Mike
Sure, I hope you are ok after after the storm.
We are having some thunder storms today but I don't think we will have any problems.
I appreciate you taking time to check, these are something I need but there is absolutely no hurry.
Besides, after I finally found my big blunder about the size of the bolts, These are available in that size from every vendor for A body parts. I feel like an idiot!
Take it easy buddy,
Mike
Mike
Yes I have the bolts. Do you need a really nice original coupler? I have one but not sure it's it's P/S or manual. Send me your info and I'll send the bolts and coupler if you need it.
