can anyone tell me how to remove this bolt from the intake
Old January 15th, 2017, 01:01 PM
richkidd24's Avatar
can anyone tell me what to use to get it out
richkidd24 is offline
Old January 15th, 2017, 01:27 PM
Lotsa luck...
Unfortunately, whoever installed that didn't think about taking it out. I'm sure they used an open end wrench at an angle, which explains the apparent rounded corners. I suspect you won't be that successful backing it out.
Failing the open end, you can try a flare nut wrench or even a box end. Consider sacrificing one to the cause and grind the wrench to fit. Once out, throw that bolt as far as you can and replace it with an allen head bolt.
joe_padavano is offline
Old January 15th, 2017, 01:41 PM
richkidd24's Avatar
can you tell me where i can get the allen head bolts from
Old January 15th, 2017, 01:43 PM
Hardware store
Fastenal
McMaster Carr
MSC
Bolt Depot
Earls Supply
Pretty much if you type allen head bolts into Google, you'll get a list of sources.
Old January 15th, 2017, 02:06 PM
72 Olds CS
RetroRanger's Avatar
Even an Allen head may not fit that location, I ground down the perimeter of an Allen head to fit there and it still rubbed on the intake runner.
If you can't get a wrench in there at all I would try a dremel or angle grinder w thin blade and cut a slot in the top of the bolt then use a big flathead screw driver or tire iron depending on the slot size and then turn it out, I don't think it will be in there that tight based on the access to it.
RetroRanger is offline
Old January 15th, 2017, 03:00 PM
Rocketguy's Avatar
Lotsa luck... Once out, throw that bolt as far as you can and replace it with an allen head bolt.
LOL
At least the bolt has correct markings. You could always weld a bolt or some provision onto it for a grip if all else fails.
Once your finished exercising your pitching arm grind yourself some clearance around it.
Rocketguy is offline
Old January 15th, 2017, 04:40 PM
Hookers under Hood
76olds's Avatar
You could drill a 3/16 hole in the centre of that bolt down as far as possible. At least 3/8 deep, then use a screw extractor bit if all else fails. As others mentioned spin the SHCS down to a diameter that will make the next bolt install much easier.
You'll get it out, just be patient.
Eric
76olds is offline
Old January 15th, 2017, 09:15 PM
cjsdad's Avatar
Open-end wrench used straight down from the top. Use a screwdriver or dowel of some type as a T handle through the boxed end. Turn the bolt head one flat at a time. Works fine, takes long time!
cjsdad is offline
Old January 15th, 2017, 09:35 PM
shiftbyear's Avatar
another possible replacement fastener is a 12 point, good luck
http://www.clydefasteners.com/produc...nt-ring-bolts/
shiftbyear is offline
Old January 16th, 2017, 05:44 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Edelbrock supplies a shrunk down 12 point bolt for a reason.
olds 307 and 403 is offline
Old January 16th, 2017, 12:54 PM
brownbomber77's Avatar
I ground down the two runners that run close and then sandblasted my intake to make some space on my RPM. Try a propane torch to heat that thing up, then try turning with an open ended wrench.
brownbomber77 is offline
Old January 16th, 2017, 12:55 PM
Looks like ya got another broken bolt inside that intake, too...
Old January 16th, 2017, 01:07 PM
Chesrown 67 OAI's Avatar
thats the reason they sell those special small 12-point headed inake bolts. Allen cap screws are just as wide and wont work any better than a std hex head bolt. You may even have to dremel it out down there for a decent fit or if you want to use a washer.
Chesrown 67 OAI is offline
wcourt3010
June 6th, 2014 08:37 AM
rootney
May 11th, 2014 05:11 PM
salmonmike
February 6th, 2012 07:41 AM
TRW
August 29th, 2010 05:20 PM
mscofer
April 4th, 2010 06:35 PM
Quick Reply: can anyone tell me how to remove this bolt from the intake
