Need Help Power steering bolt
Old Mar 29, 2008 | 02:36 PM
marzgtp1's Avatar
Olds-Can
I just went out to start my cutlass and found the power steering bracket was just hanging there, I went to auto parts stores and they have no clue what I am talking about I need a bolt that has threads on both sides and a nut in the center it holds the timing cover on and the other side holds the power steering bracket with a nut. I took them the old one and the have no clue can anybody help me please. it looks like a regular bolt with thread on the head part Where can I get one?
Old Mar 29, 2008 | 03:30 PM
71 delta88guy's Avatar
That's the problem with old engines. either pulling them appart or just the occasional surprise, the bolts break. 2 choices. 1 find someone parting out an engine and get the specific bolt you need. 2 make it from threaded rod. But a long piece,cut it to length and there you go.Good luck.
Old Mar 30, 2008 | 02:04 PM
Bluevista's Avatar
Registered
I will check my nut and bolt stash, those old coffee cans full of pieces-parts are priceless sometimes. Try moving your post to the parts wanted section, I'm sure a bunch of guys have one laying around they would part with, for a small fee.
Allan.
Old Mar 30, 2008 | 03:29 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I just looked at my 72 Cutlass and I think I saw the bolt you are looking for. The one I am looking at is about 1 1/4 inches in the middle part that is not threaded. If you can't find the bolt (you probably) or as a temporary measure, I would take some threaded stock which you can get at any auto parts store or hardware store. Take a small piece of pipe and cut a sleve the length of the unthreaded portion, slide it on and then put the pump and nut on. I don't have mine apart but from what I can see, this should work. I hope it makes sense. Good luck.
Old Mar 31, 2008 | 06:29 AM
marzgtp1's Avatar
Olds-Can
Thanks to all, I'll give it a shot but if any finds one laying around let me know.
jjokrm
Jan 14, 2026 06:46 PM
nicks1966
Jan 12, 2014 01:46 PM
johns65442
Jan 9, 2014 09:57 AM
72442conv
Mar 19, 2012 07:14 AM
1971viking
May 21, 2011 12:56 PM
