1964 330 pulley and bracket
Old May 19, 2021 | 07:02 PM
oldsmoboogie's Avatar
I am looking for a non AC water pump pulley and the alt bracket that mounts to the water pump and intake. Thank you
Old May 19, 2021 | 11:00 PM
Gerald Nickels's Avatar
Did you mean intake and side of head ? Pass. side does not bolt to water pump.
Old May 20, 2021 | 08:34 AM
lunaboy's Avatar
The Rocket Astronomer
i have the complete water pump pully single groove and complete alternator brackets for 64 still mounted on 330
125.00
Old May 20, 2021 | 09:39 AM
The 1964 non-A/C alternator bracket looks like this.
Old May 20, 2021 | 10:11 AM
oldswizkid's Avatar
1964 330 non air alter brackets
Absolutely correct Joe! If all else dead ends on the 1964 330 non air alternator brackets, I can probably dig one out. Have 1964 330 non air water pumps as good rebuildable if necessary.
Old May 20, 2021 | 06:21 PM
The passenger side bolts to the head, intake, and the block by the water pump.
Old May 21, 2021 | 04:30 AM
jcdynamic88's Avatar
the last pic is not a 64 bracket,at least 1966 with 2 holes
Old May 23, 2021 | 06:43 AM
It is the bracket from my 72 350. I was hoping it would work but it doesn’t, that is why i am looking for one.
Old May 23, 2021 | 06:51 AM
i should have realized that.i dont understand why it doesnt work tho.i have one(style you need) on my car (455) using an extension bracket and have been meaning to swap it out for the right one which i have.
Old May 23, 2021 | 07:06 AM
The 66-up bracket puts the alternator in the same place as the 64-65 bracket. If that one doesn't work, the correct one won't either. What isn't working about it?
Old May 23, 2021 | 01:14 PM
i'm wondering if it's the intake manifold,it doesn't look stock
Old May 23, 2021 | 03:47 PM
lunaboy's Avatar
Got a 64 non air / non power steering singe groove water pump pulley or if you want a 66 67 double groove for power steering and you can use that 66 67 alt bracket.
i would see what you have in a crank pulley because they should match .
Bremer
Jul 7, 2019 12:03 PM
HWYSTR455
Feb 14, 2018 04:30 PM
442scotty
Oct 24, 2013 06:20 PM
crazy'boutOlds
Jul 6, 2013 04:14 PM
ihengineer76
Oct 9, 2012 05:00 PM
