1964 330 pulley and bracket
1964 330 non air alter brackets
Absolutely correct Joe! If all else dead ends on the 1964 330 non air alternator brackets, I can probably dig one out. Have 1964 330 non air water pumps as good rebuildable if necessary.
i should have realized that.i dont understand why it doesnt work tho.i have one(style you need) on my car (455) using an extension bracket and have been meaning to swap it out for the right one which i have.
Got a 64 non air / non power steering singe groove water pump pulley or if you want a 66 67 double groove for power steering and you can use that 66 67 alt bracket.
i would see what you have in a crank pulley because they should match .
