PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. 72 Cutlass Fender Script
  2. looking for a water pump: OEM GM # 382188 W/AIR
  3. 64 Starfire driver side window assembly needed!
  4. A/C bracket- head bolt with stud
  5. 67 odds n ends
  6. WTB 70 non-console shifter
  7. 1974 Delta 88 Convertible- seeking headrests, side mirrors exact fit
  8. 54olds 98
  9. Wanted: 1970 NOS LH Hockey stick
  10. Alternator and Power Steering Bracket for 400 with a/c
  11. 1967 Cutlass AC DUCT DISTRIBUTOR
  12. Turbo 350
  13. 1983 Custom Cruiser
  14. Wtb: PS pump mounting brackets
  15. ISO Wiring Cover Bracket Located Under Rear Seat for 1968 Cutlass/442
  16. WTB: 1966-72 4 way power bucket seat switch
  17. Wanted 1108386 Dated April-May 1971 Starter
  18. Toronado Floor Mat
  19. bendix treadle vac
  20. 1970 Toronado carb 7040252
  21. 61-62 Cutlass NOS parts wanted
  22. 1961-63 f85 cutlass convertible fenders and door
  23. 1968 442/Cutlass red interior parts
  24. 455 intake
  25. Parts Needed
  26. 1987 olds 442
  27. 64 Cutlass F-85 Trim Molding
  28. "70 442 OEM Grilles (would consider damaged)
  29. 76 toronado trim
  30. 1977 Olds 350 Valve Covers (3A Smog) Needed
  31. #398890 hose clip and disc brake hose tabs
  32. big block olds dual quad
  33. 70-72 package tray
  34. 71/72 Cutlass/442 blue ash tray door
  35. 1112036 dist 1971/72
  36. 330 rocker arm shaft assembly
  37. 73 cutlass s fender emblems
  38. Part needed 410410
  39. 1965 442 air cleaner
  40. Toro pan pan parts
  41. Passenger door for 56 88 post car
  42. Bucket Seats/Console
  43. Rocket 350 2BBL Intake Wanted for 73 D88
  44. Wanted Gold "Oldsmobile" Floor Mats
  45. 66' 442 lower air deflector & horns..
  46. Straight A/c Bracket for 350
  47. 72 Cutlass Supreme Trunk Lid
  48. 68-72 rear seat floor
  49. 70-72 Cutlass Back-Up Light Lens
  50. WTB 1967 Toronado Carburetor
  51. Hod hinges for 1965 88
  52. Seat belt for 1970 cutlass supreme
  53. 1967 442 W30 air cleaner
  54. Seeking ORIGINAL 1971 Oldsmobile 442 ram air hood
  55. 455 Performer intake
  56. '69-'72 hood hinges
  57. Looking for '42 mouldings
  58. Looking for......
  59. 66 442 Washer cam
  60. 70-72 supreme exterior sail panels
  61. 1965 Cutlass manual drum master cylinder push rod/15” steel wheels
  62. 1967 442
  63. Toro pan
  64. where to buy fwd toronado oil pan?
  65. 1970 Cutlass Supreme driver's side grill
  66. Vista Cruiser Quarter Panel
  67. 67 Cutlass Supreme 442 lower taillight lenses
  68. 61/62 f85 front turn signal
  69. 1972 Cutlass bolt in axle shafts
  70. 68 cutlass hood hinges
  71. WTB: Olds 350
  72. 1970 cutlass ashtray lid and springs wanted
  73. 1971 Cutlass Tranny Tunnel
  74. Wanted - '36 radio head set
  75. 40712 Fuel Pump NOS wanted
  76. Wanted 1968 442 frame stiffeners
  77. Th350 and gas pedal assembly
  78. WTB : 1961 f85 front body parts
  79. 65 cutlass or Jetstar 88 fuel tank outlet
  80. 403 Block
  81. 70 NOS Or Excellent Used Arm Rest Pad
  82. 66 Cutlass 442 Seat Buttons
  83. 1971 Cutlass Supreme horn button
  84. 1940-1948 hood release knob
  85. WTB 1970 442 ram air hood
  86. 921 lifters
  87. 69 bell drum
  88. Hurst 3760 handle wanted
  89. 70-72 power window harness
  90. oil tube and dip stick
  91. Wtb>1987/1988 g-body right taillight assy.
  92. 1969 442 B Post Moulding
  93. WANTED: In search of floor shifter for automatic.
  94. Rear wing support
  95. Cigerette lighter housing for my 1964 Ninety Eight
  96. Th350
  97. Roof Replacement
  98. Bucket seats
  99. 1970 Seat Belts
  100. 1964 Cutlass Hood leading edge moulding
  101. 1971 Cutlass 350 Front A/c Bracket
  102. 1964-65 Jestar Emblems Wanted
  103. ZK radiator tag wanted
  104. looking for electrical connectors
  105. 1965 Cutlass fuse box/ DASH HARNESS
  106. 1970 Cutlass Supreme Wheel Opening Chrome Trim
  107. 63 f85 14" wheel and control panel trim pieces
  108. cutlass door
  109. 78 Cutlass Supreme upper rear window molding
  110. 1965 425 intake manifold
  111. L6 (250) power steering pump brackets
  112. Flywheel/Inspection Cover for '65 Jetaway
  113. 70 Olds Cutlss SX
  114. 1957 window channels
  115. 1975 Oldmobile Cutlass Salon 4 Door Sedan Windshield
  116. Edelbrock Al Intake 04B or Performer 2151
  117. Nos hood hinges 1971 olds 442
  118. 4 door Cutlass Wheel Opening Trim
  119. Fuel Sending Unit Help
  120. Bell housing
  121. Dash Clock 1974 Cutlass Supreme
  122. Need a straight '70 Cutlass front bumper core NE Ohio
  123. Edelbrock 065
  124. 1970 442 wheel opening moldings
  125. Tail light cross bar '65 Cutlass/442
  126. 1965 Cutlass bumpers
  127. Wanted stock 65 442 driveshaft
  128. 1965 Non-AC Alt bracket 400-425 BBO
  129. 71 w30 distributor
  130. Starter 1108387 1108389
  131. Wanted #2 or #3 water pump
  132. 70 Hockey Sticks
  133. 1972 cutless convertible Wrecked
  134. Need 68 BBO brackets and pulleys.
  135. WTB 15" 8" & 10" SSI's for 1970 Cutlass
  136. 77 Omega Sport Gauges
  137. 1966-1967 cutlass rear window chrome
  138. 350 engine dipstick
  139. 1959 Ninety-Eight - Driver Wiper Escutcheon / Bezel
  140. Air cleaner Flapper
  141. 1967 cutlass circut board
  142. 70-72 442 Wheel Arch Mouldings
  143. Toronado Floor Mat
  144. Wanted 70-72 flywheel inspection cover
  145. 67 Buckets
  146. Wanted 1971 w30 distributor 1112034
  147. Rocket 88
  148. 69 TM rearend
  149. 1973 Delta 88 Parts?
  150. Speedo cable 69 delta 88
  151. 1968 Delmont 88 rear tail light chrome inserts
  152. '69 H/O - A/C Condenser Mounting Studs
  153. 72 CS Cruise Control Regulator
  154. Air Cleaner Assembly single 4bbl carb
  155. 71 Cutlass S roof panel/vinyl top 'S' emblem
  156. Starter 1108387
  157. ISO Kick Panel Clip for 1968 Cutlass
  158. WTB: 1972 Cutlass 442 Dark Blue drivers side OEM factory seat covers
  159. Oldsmobile grille script
  160. Fuel pump to 2 barrel carb fuel line for 67 f85
  161. 67 cutlass/442 fuse block
  162. WTB 1970 OEM Ram Air hood
  163. rear differential
  164. 2 spoke wire wheel covers
  165. 1967 big block intake
  166. 70-72 right cutlass door
  167. 66 ignition lock cylinder
  168. 1965 442 Convertible Frame Wanted (potentially)
  169. 1967 Gold Seat belts
  170. Exhaust hangers 63-64 full size
  171. Peak Moldings for 69 convertible
  172. 65 442 valve covers
  173. 65 442 chrome air cleaner
  174. harmonic balancer bolt and washer for olds 455
  175. 404584 Water pump needed
  176. Rear Sail Panel Courtesy Light Housing, 1959-68 Oldsmobile, Buick and Cadillac
  177. 455 oil pan, pickup, dipstick
  178. NOS Gas Tank Straps
  179. 1965 Cutlass Backup Lights Delete Plates
  180. Holiday Trim
  181. PW: Parts for 1970 Cutlass console
  182. Oil filter mount
  183. 70 Toronado dog dish and trim rings
  184. 1970 Cutlass hood tongue/nose/extension
  185. 1970 S fender emblems
  186. Door latch '88' or '98'.
  187. Wtb muncie trans case 3885010
  188. 1969 Hurst/Olds tires
  189. 68 Cutlass Supreme Rear Interior Metal Moldings
  190. Climatic combustion control
  191. Top Switch
  192. WTB 1965 "B" body(Starfire) seatbelt assembly
  193. 3 spoke wood grain
  194. 455 Engine
  195. 67 442 right-left side
  196. OAI hood brackets & retainers
  197. Sunvisors for full size hardtop
  198. 65 442 A/C Brackets - Still looking
  199. 350 water pump divider plate
  200. Searching for 3 wire turn signal switch tilt steering
  201. 1970 A body am fm
  202. WTB 455 Alternator brackets
  203. WANTED: 64 Cutlass
  204. WTB 1970 3.42 rear end TM code
  205. 65 cutlass bumpers
  206. 1970 442 fenders
  207. "EB master cylinder 1970 442
  208. 1972 Delta 88 Radio Bracket
  209. On the hunt for parts
  210. Looking for Scripted Oldsmobile tall valve covers
  211. 70 442/cutlass rear window defogger switch & harness
  212. Alternator Harness Clip
  213. NOS or Mint Windshield Motor Cover #4918070
  214. 1964 Dynamic 88 Holiday fuel tank
  215. WTB 65 Cutlass radio and bezel knobs
  216. 1964-65 Cutlass Dash Ash tray insert
  217. 1967 Cutlass Rear Wheel Trim
  218. WTB 70-72 cutlass doors
  219. Aurora headlight assemblies
  220. SSII wheels needed
  221. Rear Wheel Well Trim
  222. 1- piece Driveshaft for '70 Cutlass 4-speed
  223. 1965 Cutlass Axle
  224. 1971 Cutlass Supreme grilles
  225. Breather FB53
  226. 1971 Standard Blue steering wheel
  227. Wtb 3203hkr headers or gbody 455 long tubes
  228. Trim Rings 15x7 SSIII
  229. Want to buy.
  230. Wtb 70 m21
  231. Edelbrock performer 2711 wanted
  232. 1965 Cutlass Trunk Lid Letters
  233. 1972 Delta 88 AM or AM/FM radio wanted
  234. SSIV wheels wanted
  235. 66/67 442 Fan shroud
  236. 1964/65 Center Console automatic 2 speed shifter
  237. 1970 cutlass headlight housings
  238. Repop Notched Valve Covers - Any good!
  239. Complete A/C system for 1960 88
  240. Wanted 1971-72 Olds 442 bumpers
  241. Wanted NOS 65 Cutlass dog dish hub caps
  242. 1967 442
  243. 69 Cutlass brake pedal assembly
  244. wanted 12 bolt carrier #588
  245. Nicer / newer looking oil filler cap?
  246. 1970 - 1972 Super Stock II Rims
  247. WTB 1991 Olds Custom Cruiser Alloy Wheel
  248. 1970 Cutlass Front Bumper
  249. Rear seat base for a 58 Super 88 needed
  250. ‘70 Steering to trans linkage
