1972 Cutlass bolt in axle shafts
Old Jul 6, 2019 | 12:11 PM
Jguer's Avatar
Hi Guys...I’ve looked all over the internet searching for new axle shafts for my 1972 Cutlass
i have the 8.5 / 28 spline carrier with bolt in axles. All I can find are c clips axle shafts. Can any guide me
to where I can find new axle shafts that fit.
Thanks, Jim
Old Jul 6, 2019 | 12:54 PM
Contact member monzaz.
https://classicoldsmobile.com/forums...rs/monzaz.html
Old Jul 6, 2019 | 01:51 PM
ROCKETMAN269V's Avatar
I have numerous used axles down here in sunny South Florida, if you're interested. Email me direct: drolds1@bellsouth.net. Thanks, Bob.
Old Jul 6, 2019 | 02:15 PM
Jguer's Avatar
Thanks...but I’m looking for new bolt in axle shafts.
Old Jul 7, 2019 | 07:09 AM
The only NOS axles I have are the 31-spline for the 8.5" type "O" rear end.
Old Jul 7, 2019 | 09:01 AM
You should be able to source those from any of the major axle manufacturers. Or just check with monzazz.
Old Jul 7, 2019 | 03:03 PM
Jguer's Avatar
Are they the bolt in axle shafts? If so...how much?
Old Jul 7, 2019 | 03:37 PM
Yes bolt in shafts. For the price you would have to ask them, not me.
Old Jul 8, 2019 | 07:34 AM
Jguer's Avatar
I didn’t think they made 31 spline bolt in axle shafts for the 1971-72 Cutlass’s as a oem item.
Are you sure that the ones you have are a fit for these years?
Old Jul 8, 2019 | 07:40 AM
There are no 31 spline shafts for the 1971-1972 corporate 10 bolt rears; those were only for the 1967-1968 heavy duty O-Type.
There are 30 spline axle shafts for the corporate 10 bolt rear, though.
Old Jul 8, 2019 | 02:04 PM
These are for the 8.5" type "O" rear end, as mentioned above; however, they fit up to '69. This is the rear, sometimes mistakenly referred to as an Olds "12-bolt", because it has 12 bolts in the rear end cover, but only ten holding the ring gear on. They will not work with a '71 or newer rear end.
Natedawg
Drivetrain/Differentials
Jun 3, 2019 04:20 PM
knighthawk
Sep 19, 2014 11:49 AM
cletusvandamme
28
May 18, 2014 07:51 PM
raw442
Jun 2, 2013 04:08 PM
1968ragtop
Feb 7, 2011 04:50 AM
