which axle ?
Old Sep 17, 2014 | 09:38 AM
knighthawk's Avatar
From: from Wisc, then Texas, then Kansas, now back to Texas,
which axle ?
1969 Cutlass S , has a bent axle ( right rear) RockAuto refers to 2 different ones, a ring gear size ; 8.2 and a 8.87 , (or something like that ) so , how do I tell which, without opening up the diff and measureing the gear ??thanks
Old Sep 17, 2014 | 10:07 AM
oldsmobiledave's Avatar
Fyi
If you have a Type 12 bolt then neither of those axles. The 1st one you list is for an 8.2" rear end & the other is for the Chevy 12 bolt. On top of that you will have bolt in axles & both of the ones listed above utilize C clip axle retentions.
Old Sep 17, 2014 | 12:02 PM
knighthawk's Avatar
the cover does have 12 bolts, and thet are bolt in axles, so , where is the best place to get one ?? thanks
Old Sep 17, 2014 | 01:17 PM
I got a couple used ones from Brian Trick (507olds) several years ago. I'd contact either him or monzaz if you want a good quality used one.
FYI, there are different versions of axle shafts for the O-Type rear. The early ones (67-69) use a sealed axle bearing with the oil seal pressed into the end of the housing tube, and the late (70) version uses an open bearing with the oil seal sandwiched on the axle shaft between the bearing and the retainer (same parts as the '71-up 8.5" 10 bolt rear). The axles are not interchangeable, so be sure you get the one that fits your rearend.
Old Sep 17, 2014 | 01:31 PM
knighthawk's Avatar
I had it out, it has the seal in the tube
Old Sep 17, 2014 | 04:20 PM
Yep, that's the '69 style, original to your car.
Old Sep 18, 2014 | 03:30 PM
knighthawk's Avatar
so, can I tell Rock Auto, I want an axle with the seal in the tube, bolt in flange, and it'll be the right one ?
Old Sep 18, 2014 | 05:28 PM
You can tell Rock Auto that and they should tell you that they don't have an axle shaft for an O-Type 12 bolt rear.
Old Sep 18, 2014 | 07:17 PM
knighthawk's Avatar
okay, I got it now. SO, where can I get one, other than OPGI for $200 ?
Old Sep 18, 2014 | 07:47 PM
Fyi
Supercars unlimited has new ones.
http://www.supercarsunlimited.com/Axle-Shafts-i279.aspx
Old Sep 19, 2014 | 07:54 AM
knighthawk's Avatar
thanks
Old Sep 19, 2014 | 11:49 AM
monzaz:
Home Page
http://www.jdrace.com
This Page
https://classicoldsmobile.com//forum...rs/monzaz.html
507olds:
Brian Trick
thetrickfamily@yahoo.com
814-440-3553
This Page
https://classicoldsmobile.com//forum...s/507olds.html
JPMDaddy
Jan 14, 2019 08:41 PM
rustycragars
Dec 25, 2016 06:06 PM
papaya
Dec 25, 2012 04:51 AM
cutlasssupreme71
Drivetrain/Differentials
Feb 22, 2011 11:40 AM
thomaswatk
Mar 22, 2007 01:31 PM
