PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. WTB 1966 battery cable tube & bracket
  2. WTB: '75 (or thereabout) OEM, Full-Size Exhaust Components
  3. 1970 factory pistons
  4. Sport Steering Wheell
  5. Torque converter
  6. 64 cutlass 2 door interior thing?
  7. Edelbrock Performer RPM 350
  8. 69 Vacuum tank for power door locks wanted
  9. 72 350 4bbl idle stop solenoid bracket
  10. SBO 350,403 wanted.
  11. Power steering pump lower block spacer & mounting studs
  12. vent frame post wanted
  13. 1970 TH400 transmission Slip Yoke
  14. 1972 Cutlass Supreme Ash Tray Door
  15. 1968-9 Cutlass Fender Molding - NOS
  16. 1968 ninety eight cruise control panel?
  17. 72 Cutlass Driver’s Side Fender
  18. 1964 Cutlass parts needed, hood, fender, dash. South Florida
  19. 1970 TCV and TCS with bracket for 455
  20. Trunk seal
  21. pair of 15x8 wheels
  22. 66/67 cutlass manual trans throttle linkage
  23. 64-67 VC Wagon Roof
  24. Choke hosing for 7027036 rochester 4 barrel
  25. Deluxe Steering Wheel
  26. Cutlass rear hood bump stop oem
  27. Need hurst shifter #3759 for 68 Cutlass 4 speed convertible
  28. Need Peak Mouldings for a 68 442 convertible.
  29. Engine wanted 303/324
  30. 61 Olds Starfire
  31. 15” trim rings
  32. 68 442 body parts needed
  33. 68 442 right door needed.
  34. 1966-67 Cutlass Deck Filler Panel
  35. 1972 Cutlass Supreme Lower Dash
  36. Door Hardware Pieces 69 442
  37. 1972 Cutlass Supreme Dash Wood Grain
  38. stock 68-70 455 piston/ rod
  39. 403 Rods
  40. Need one 14" SSII, SSIII chrome trim ring
  41. Engine Block Heater #1386059
  42. WTB 68/69 vista cruiser C pillar trim and rear window trim
  43. ISO 66 Dearborn/Phord 3 Speed Toploader Transmission
  44. 2GC Carb 7029156
  45. Rear End
  46. 70 cutlass 455 intake
  47. 67 442 th400
  48. 72 350 pulleys
  49. 1962 starfire
  50. Shifter Ball For Automatic Floor Shifter Handle
  51. 1958 Left Hand Chrome Tail Fin
  52. 1968 cutlass bumper braces
  53. 73 cutlass supreme seat belts
  54. 1965 cutlass from tbumoer
  55. wanted: Waterpump 408329 (71 455)
  56. Looking for a clock knob
  57. 68 Cutlass rear bumper
  58. Delta 88 holiday 1967 Rear extensions
  59. 1965 F-85 frame
  60. Oldsmobile Script Valve Cover Chrome
  61. ‘80 Cutlass Supreme Driver Side headlight surround
  62. 350 main caps
  63. Need door pulls and some other things
  64. Rust Free Pass Side '70 Cutlass Fender
  65. 70 f85 trunk script "Oldsmobile"
  66. WANTED: Original or NOS 405031 Lower Hose
  67. Big Block Headers for 1979 A body
  68. mid 80's throttle/TV cable bracket for Q-jet
  69. 69 442 Passenger Door
  70. WTB small block dual quad intake
  71. 69 442 Convertible Top Frame
  72. WTB bumper jack for 1965 oldsmobile starfire
  73. Looking for 5469245 Brake Cylinders
  74. Part and Part Number Wanted
  75. WTB 67 442 Louvered hood.
  76. 1968 Cutlass Dash A/C or Heat only Control Panel w/Switch
  77. Wheel center caps
  78. Rochester 4 barrel Carburetor
  79. Camshaft
  80. 1971 442 Tilt Steering Column
  81. 65 olds starfire
  82. 1970 442 W30 gas tank cap
  83. 1968 Delta Front drums
  84. 70 4 speed handle
  85. Need rear lower control arms for 75 442
  86. 350dx Diesel
  87. 1965 tilt column levers
  88. Exhaust Valves needed 1.562 .342 by 7.728
  89. Wanted: ‘66 Dynamic 88 Holiday Rear Left Trim
  90. 63 Cutlass Front Subframe to Body Bushings
  91. Wanted: starter 1108387
  92. New to this Forum - Looking for an intake/carb
  93. roller rockers
  94. 1967 Cutlass Factory Cruise Control
  95. 1964 Cutlass/F85 cruse control wanted
  96. 31 spline axles 1968 supreme
  97. 71 442 Rear View Mirror
  98. Valve covers
  99. 1988 Toronado parts
  100. 1968 442 cutlass H/O jack
  101. 1970 442 Parts
  102. 1970 f85 batman steering wheel
  103. wanted 1970 f85 3speed steering column
  104. 15x7 SS1 Wheels
  105. 1968-72 Hardtop Frame - Powdercoated Preferred
  106. 1965 olds f85 club coupe rear tail panel rocket emblem
  107. 66/67 cutlass inside ac box assembly
  108. 1970 72 front fender lower inner fender brace cutlass
  109. Swivel seat Tracks/Sliders needed
  110. 1962 Starfire passenger side rocker molding wanted
  111. 1969 Cutlass reverse light wanted NOS only
  112. window felts 72 Supreme
  113. 67 400 flywheel
  114. ported small block intake
  115. 71 blue steering column
  116. Wanted : W31 Carb 7040255
  117. 303 or 324 Valley pan
  118. NOS '70 to '72 Muffler #1236982 - Cutlass / 442
  119. Starter
  120. 1970 f85 rear bumper
  121. wtb 7040017 monojet carb
  122. NOS 1970 Rocket Trunk Emblem for Cutlass #8704069
  123. SBO aftermarket connececting rods
  124. 67 vista cruiser
  125. Wanted 71 442 carb buy or trade
  126. Fabricated rear end for 1979 A body
  127. 68-72 Rear Control Arm Reinforcement Braces
  128. Need a new or used parking brake return spring
  129. 1963 F85 Cutlass Center Link
  130. 71/72 Carb dashpot
  131. **nos grilles wanted '79 cutlass supreme***
  132. 1964 non tilt turn signal switch dynamic 88
  133. Edelbraock 7111 Performer RPM SBO
  134. 1970 to 1972 Turbo 350 Transmission Core Needed
  135. Wanted: Sensor, a/cl thermo #8995654
  136. 307 engine swap harder then I thought
  137. W27 repro diff cover 10 bolt
  138. Gonna need it!
  139. Convertible Rear Door Panel Uppers 1972
  140. 66 cutlass front wheel well trim
  141. 1937 Olds Coupe Parts
  142. 64 Cutlass 330 Lower Bellhousing cover
  143. Dash pot wanted-'70 442
  144. 68 Tail panel needed!
  145. 1970 AM Radio Fader/Balance Control Knob
  146. Wanted- a1970 Gas Cap
  147. 1970 442 Hardtop seat covers in white
  148. WTB - Twilight Sentinel Photo Cell and '75 98 Regency Dash Plate
  149. 67/68 fender skirts wanted
  150. 68 olds power steering
  151. 68 Cutlass S Hood Release
  152. 70 Cutlass Parts Wanted
  153. 1964 Cutlass / F-85 Turn Signal Assembly & lens - passenger side
  154. 1969 37A Alternator
  155. WTB 64 442 Air Cleaner
  156. dash
  157. Blue deluxe shoulder belt(s)
  158. Toronado ( GMC Motorhome) ball joints
  159. 73 supreme sail panels wanted
  160. SBO American Racing Headers for my 66 Cutlass
  161. 69 cutlass convertible seatbelts
  162. '48 Door Lock Keeper
  163. 1968 cutlass trunk pan
  164. Front Windsheild, Rear Window (Soft Ray) for A Body Coupe
  165. 1980-84 Air Duct for 307
  166. 69 Toro RH taillight lense wanted
  167. 1966 oldsmobile f85 4 door
  168. 1970 Cutlass Column shift indicator bracket
  169. 1973 - 1977 Cutlass / 442 supreme etc 3.42 posi rear end needed
  170. 69 Bumper Bracket
  171. 61-63 f85 olds bell housing wanted
  172. 68 Cutlass Driver's Door trim
  173. Looking for olds 350
  174. 69 cutlass glove box lock
  175. 72 cutlass vinyl top trim driver side
  176. 1967 Oldsmobile cutlass
  177. 70-72 AC Kick Panel Block Off Plate/Cover
  178. Olds valve cover
  179. Need Bottom Chrome Trim Back Window 72 Cutlass Supreme
  180. 1953 Oldsmobile Super 88 Windshield
  181. WTB G70 14 tire
  182. 72 Cutlass S
  183. NOS 1973 Cutlass S Chrome Trim
  184. NEW 4.33 gear set for 12 bolt chevy
  185. WTB: 307 or 350 Oldsmobile engine or block 1985 or older. Los Angeles
  186. window regulator
  187. Taillight Assemly
  188. Disc brake steering arms for 72 Cutlass
  189. 72 cutlass supreme vinyl top chrome trim
  190. 69 Cutty convertible or coupe door Window & Parts
  191. Looking for: good SS IV hubs; good 72 Toro headlight bezels & rest taillight chrome
  192. ISO 69 Cruise Engine Components
  193. Wanted. Dr Oldsmobiles 442 And W-Machines Brochure
  194. Looking for type o 2:78 ring and pinion gear set
  195. 403 Alternator Bracket T/A
  196. WTB: NOS Wheel Well Trim
  197. 1966 Cutlass Parts Wanted
  198. WTB: 1969 TM rear diff
  199. 1970 Notched Valve Covers
  200. ‘67 Side Mirrors
  201. 66 F85 Deluxe rocker panel trim
  202. Looking for some n98 rims and a r codes rim
  203. 1964 oldsmobile dynamic 88 convertible under dash harness
  204. 63-64 Full size Oldsmobile Clock
  205. 1970 Ninety Eight speedometer drive / wheel bearing cap
  206. Wanted disc brake spindles for 67 - 70 88 or 98
  207. In search of...
  208. A/C vents 69 Cutlass S
  209. Tail panel
  210. Recomendations
  211. Sun Visor
  212. Paul Hertz
  213. original red wheel well piece
  214. 83/84 Hurst Olds Hood scoop wanted
  215. 64 cutlass dash
  216. 1970 Cutlass Console Lock Assembly Wanted
  217. 1100880 non A/C alternator
  218. 92 Toranado parts
  219. ISO 1968 two door hardtop doors.
  220. G body accelerator cable bracket and Qjet bolts
  221. 1970 72 console bottom
  222. 1984 Delta 88 Coupe Vinyl top molding
  223. ‘70 Rally Pack tic tach tock and gauges
  224. 1958 371 Harmonic Balancer
  225. 69 cutlass vert
  226. Small block Victor intake
  227. 1961-1962 NOS Cutlass parking light assemblies wanted
  228. final drive
  229. 1968-1970 H/O & 442 oil pan
  230. 1950 Oldsmobile 88 Deluxe Coupe tail light assembly’s
  231. Turbo 400 shifter cable bracket 72 cutlass
  232. [WTB] '72-'75 Thermal "Relay" / Switch
  233. 67 4spd air cleaner
  234. 1970 442 (non-OAI) Air Cleaner Base and Lid
  235. Brake Calipers
  236. Injectors for Sniper Stealth 4150
  237. 324 needed.
  238. 1970 Front Bench Seat
  239. Fair warning all recent posts
  240. 66-67 front bench seat
  241. Wanted - 69-70 full size disc brakes
  242. 98 or Starfire
  243. who has pre 71 hub/rotors for B - bodies??
  244. ISO pre 71 B - body Delco- Moraine hubs & rotors
  245. 71 W-30 fuel pump & 76 442 grills
  246. Wtb: 1964 dynamic 88 printed circuit, parking brake pedal,heater vacuum actuators
  247. WTB: 1956 Olds 88 Cowl to Fender Support rods.
  248. 66 442 Tail Light Bezels
  249. 1969/70 98/Delta 88 Deluxe Wheel Cover Retaining Clips
  250. 67 442 fuel pump needed
