Camshaft
Camshaft
Looking for an NOS or unused aftermarket camshaft cut to either of the following factory advertised specifications:
#400165 70-71 automatic 442, 71 air conditioned W30, 70 W30 automatic with or w/o air conditioning, 68-70 Toronado W34
285/287 duration, .472/.472 lift, 57 degrees overlap
#393859 70 350 manual Cutlass, 69 W32 442, 67/68 400 manual 442
286/286 duration, .472/.472 lift, 58 degrees overlap
Automotive Performance Camshaft Production Manufacturer | Camcraft Cams
A while back they made a camshaft for a workmate's son's Pontiac GTO. Ran like a scalded ape. Sorry, it's only thirdhand info, but it's all I got. If I needed a cam that these guys could do, I wouldn't hesitate to try them.
I would recommend CamCraft Cams also. A friend who had a cam ground for a 57 Olds J-2 is very happy with them. I will be having them grind cams for my 57 Olds J-2's. I am sure they can grind a #400165 cam or something close to that.
I have talked to "Hunter" and he is very helpful. I think they are also fussy about the cam blanks they use. With the flat tappet cam and lifter failures from a "big name" cam grinder, camshaft blanks is something to think about.
Sent a message to Camcraft Cams asking if a camshaft could be cut to factory specifications, with advertised durations. Waiting to hear back.
Supercars Unlimited, which sells factory spec camshafts, has a long delay supposedly due to their supplier having problems obtaining US manufactured blanks.
