View Full Version : Parts Wanted
- Wanted to buy PS PULLEY
- 1967 "HB" code 14" disc brake wheels
- 90 Degree trans adaptor
- 1976 Cutlass fan shroud
- Wheel covers
- Wanted: 1970 Door VIN Tag with Correct Font
- 10 Bolt 3.23 Posi Rear Differential
- Wanted: Starter 1108348 with date code 8J, 8K, or 8L.
- Front bench seat cover white
- '70 W30 Radiator Tag Needed
- 72 Delta 88, or 98 gas tank
- Wanted 1969 442 4 row radiator top plate
- 1970 Cutlass/442 Sport Mirrors
- WTB: NOS 1972 Olsmobile grille script
- 68-72 Power Trunk And Power Locks Wanted.
- Lower air dam for 68 toronado
- Bumper jack box and foam insert for 68 toronado
- 68 Fenders and 442/S hood in good shape and willing to ship
- ISO 69 4 speed shifter pattern plate
- 70-72 cutlass/442 Driver side Air Vent box
- R4 AC Compressor Super Heat Switch
- 67-70 Neutral Safety Switch
- WTB 65-66 Cutlass park brake switch
- ISO misc olds 98 parts
- '70 Cutlass radiator overflow tank and bracket
- Looking for tan or saddle in color kick panels for a 69 F85 AC
- Looking for 455 engine near San Antonio.
- Wanted- 1970 remote mirror interior door panel escutcheon
- Flat top 403 pistons
- NOS 1972 442 Taillight Lenses
- 1971-1972 NOS 442 Rear Bumper
- Looking for 7111
- 69 olds cutlass shell
- Who wanted '880-'890 OFA & starter J-K-L '69 _??
- A/C Distribution Vent
- 70 sport mirror escuthcheon/bezel
- Ported BBO heads
- 66 Cutlass Auto Shifter
- Quadrajet 7042251
- Interior Rear Mirror with Light for 72, restored/nos
- Needed for a 1968 Vista Cruiser
- WTB 69 Cutlass front bumper
- 67 pulleys
- '70 OAI under hood bracket needed
- 1967 Toronado 2-Speed Wiper Motor & Pump
- 1967 330 #4 head
- 90 degree transmission adaptor
- 67 Power steering bracket
- 69 Cutlass Quadrajet carb
- wanted pass lower trim supreme quarter
- 1970 F heads wanted
- Driver side wiper arm 71 a body cutlas
- 1971 underhood engine sticker WANTED
- ‘71 455 Power Steering Bracket
- Steering wheel
- 1967 442 radiator shroud
- 71 cutlass parts needed
- Need Chrome trim guard for gas door
- Under Hood Firewall Mounted Accelerator Assembly
- 1969 NOS Bumper
- Wanted 56 Olds '98' side trim!
- Muncie cover
- 69 washer bottle
- cruse control bracket
- 64-65 Cutlass 2 dr. "post car" passenger door glass run channel
- Wanted 1979 Cutlass Pair Tail light Bezels
- 68-69 automatic console mounting brackets
- Cruise Control Parts
- Wanted 1979 Cutlass Passenger side Tail light Bezel
- Wanted headliner bows for 57 Oldsmobile wagon.
- Cutlass hood trim
- New Guy Bizeeman1959
- In search of 65 Vista cruiser passenger side roof glass.
- Passenger Inner Fender for 80s Era Full-size
- 303 rocket
- Solid 350 wanted
- A body upper rear seat
- Cruise control parts
- Anyone Got a Good 323 8.2 Ring and Pinion Need ASAP
- Parts needed: 65 cutlass convertible hood, driver fender, core support and trunk.
- WANTED: 1961 88/98 windshield, near Ohio
- 68 Cutlass A Pillars in Black
- ‘72 Supreme dash center speaker bracket
- 1969 Tornado NOS door edge guards
- 1964 88 Trunk Cardboard
- 1966 F85 Rear Bumper
- Wiring Harness 67-69 Cutlass Console Manual Transmission
- 75 Old/GM door latches needed & other parts
- Power bench seat tracks
- Defrost duct
- One year only
- 1968-72 Olds 442/Cutlass AC brackets
- 66 Cutlass bucket seats
- Anyone parting a 1968-1972 non-air Cutlass/ 442?
- 455 Block
- 1971 442 OG TH400 transmission
- 1968 442 Grill Cover Plate
- Looking for A4 manifold
- '73 98 Coolant Overflow Bottle
- 1967 cutlass sedan window track and sill plate
- Upper Rear seat 71 cutlass convertable
- ISO 1965 Starfire console shift indicator lens
- 48 Olds 98 Convertible Sill Plates
- Alternator 1100890 55amp
- Rear seat frame 71 Cutlass
- Wanted 67 cutlass/442 fenders
- Wanted: NOS 1970 3 prong door jamb switch
- Donor metal and lense's
- 1962 oldsmobile 88 gas tank
- 350 aluminum intake
- 1969 gold cutlass front bench seat
- 75 Cutlass Supreme vinyl roof trim
- '73 98 Cruise Control Servo
- miner stuff for my 71
- Inner Fender to Frame Bumper
- High note 9000 horn wanted
- Need passenger door and trim 1966 442 holiday coupe
- Wanted 66 442 rear bumper
- Convertible boot 1970 Cutlass (Black)
- 1965 330-425 rocker arm studs
- Looking for Thermo Quad carb 850
- Pull Strap
- ISO Water pump 400296
- Dash Pad 1975 Omega with AC
- nos 402926 ssII bolt on centers
- 200 4r chrome trans pan & inspection cover wanted
- Wanted 66 - 67 Vista Cruiser Right Rear Door
- ISO starter # 1108348 pre May 68 date
- 1967 cutlass 442 auto floor shift cable...
- 70 Cutlass Supreme Tail light lens
- ISO 80's Delta 88 parts
- 68 cutlass headlight molding drivers side- 66 door handle
- 66 round motor windshield washer pump cover
- 1965 442 Coil on Engine Bracket
- 71 72 Carb dash pot
- 68 442 Interior Rear seat side panel, Fan shroud
- Radio for 1963 Cutlass
- Cowl Section / Windshield Channel
- Need 1955 Rochester 4gc carburetor 7007000
- 1980 Regency Rear driver side window
- Help! 71 cutlass supreme rear quarter panel Extension
- 455 Crank in Central NY State area?
- ‘65 radiator support
- ‘65 Drivers side wheel well
- 68-69 Auto Floor Shifter Pin
- cutlass parts needed
- Spacers Needed. Power Steering Pump, Hood Hinge, and Convertible Door Wedge.
- 92 trofeo
- Wanted: 1968 Cutlass horns
- 7
- # 673 posi unit
- Big block a/c bracket
- 1968 442 front drum brake plate pass side
- WANTED - 70 Cutlass S RH NOS Quarter Panel
- Jetaway Trans.
- 1965 cutlassw left side windshield washer nozzle
- manual antenna lead in assy for cutlass
- Horn Button F85 69-72
- Original Dual-Gate shifter knob
- Hood Light
- Need Nice 70 Radiator Support
- WANTED, Prefer alive.
- WTB, ISO, Wanted
- 1967 Cruise Servo/bracket with adjustable rod
- Olds oil filter adaptor
- Wanted interior rear view mirror 1965 F85
- 1969 442 convertible quarter glass
- 1970 SS1 Stainless Wheel Trims (14x7)
- Delmont88 bumpers 1968
- Mounting for litter buckets on 98s and toros
- Hubs for 3 & 4 spoked steering wheels
- 65 cutlass passengers side mirror bracket
- SS1 14x7 wheel for 70
- WTB Snap On Center Caps
- 70 Cutlass Convertible upper piston panel
- 350-455 Olds (rubber) pan gasket
- WANTED: 68 wood wheel screws
- 1968 drum brake plate needed
- 1969 glovebox / console lock cylinder
- 1966 Cutlass Fender Patch Panel
- carter WCFB carburator
- 68 442 upper control arms wanted
- 1968 Oldsmobile 442/S hood
- WTB Shifter Rods
- 1955 88 2dht
- SS1 Center Caps - 4/5
- Wanted ...66 or 67 442 crankcase breather
- 65 side view mirror mounting bracket
- 70-72 ? Cutlass fuel/warning pod WITHOUT seatbelt light
- WTB: strong running or rebuilt 324 engine.
- 68-69 Dual Inlet Air Cleaner
- WTB: radio speaker/power supply
- 69 88 driver door skin
- 1968 Delmont parts needed
- 70-71 Tic Toc Tach
- 70 455 cutlass supreme power steering pump brackets
- ISO 80-84 307 exhaust manifolds
- 72 T-3 headlamps
- WTB SS2 rims
- 1965 Cutlass tilt wheel turn signal switch
- wtb : 61 /62 F85 tank neck shield / baffle
- 1966-67 Cutlass Fan Shroud Bracket
- New or Used Rear Coil Springs - 68 Cutlass Supreme Coupe
- 1970 442 air inlet vacuum actuator
- '73 98 2 Door Headlight Dash Knob
- '73 98 2 Door Headlight Bezel
- Type o gears
- Iso transmition line 90°street elbow
- Door Panel Molding Wanted
- Back Drive cost?
- 400 E crank wanted
- 1964 cutlass f85 convertible
- wanted 1967 delta 88 lights molding clips
- '70 Hot Air Pipe
- Hood trim and latch
- Lug wrench trunk mounting clip installation
- 70-71-72 Tire Tool Trunk Mounting Clips
- Looking for 66-68 4bbl Intake BB Stock Iron
- Wanted: OEM Motor Mounts for a 1990 Custom Cruiser with the Olds 307 V8
- WTB 1972 Delta 88 Convertible Top Switch
- WTB-70W30 Carb 7040258
- Valve Cover Baffle/Breather
- Inside under dash heater box non ac
- Looking for 66 Cutlass P/S Parking Lamp Fixture
- 4 Speed Bell Housing
- 330 flywheel
- 72 front backing plate wanted
- Factory 70-72 rally pack
- Factory 4 barrel air cleaner
- wire harness
- 72 quadrajet 7042250
- Looking for 71 Oldsmobile 98 sending unit
- Red lens for 8 Track Player
- Reverse housings and lens
- 68 cutlass wheel well trim, headlight trim
- 1970 Blue steering wheel
- Looking for 350 gas block.
- 1976 Oldsmobile Rear bumper
- WTB '68 Inner Fender Panels - Locally sourced preferred
- 65 steering column plate screws
- Wtb: 1957 a/c compressor bracket
- 70 cruise control
- 1972 Tilt Column
- 67 Engine Brackets for P.S. and Alt. for A/C setup
- Need help with source for interior parts and bumper fillers 1975 Cutlass
- 1954 olds 98 trim
- Fiberglass mounting studs
- 1970 442 Hot Air Pipe
- 1968 455 Air cleaner lid 2 bbl
