Need help with source for interior parts and bumper fillers 1975 Cutlass
Old May 16, 2020 | 07:41 PM
Eman75's Avatar
Been awhile since I've been on the forums, slowly restoring a 75 olds cutlass. Just wondering where you guys get the inside moldings? Mine are very brittle and I'm sure the Arizona heat doest help. Is there a good site to get new ones? I'm looking for inside moldings and the moldings around the bumpers. Thanks
Old May 16, 2020 | 08:06 PM
2blu442's Avatar
The 1973-77 cars don't have as much reproduced as earlier years. In the past I had some nice interior parts and I suspect the guys in the Northern states where the sun doesn't cook things will have nice used parts too. If you'd consider used you might try creating a parts wanted post. Let me change your title to try and help get comments from the member who have your vintage of cars. And I'll move it to the parts wanted forum. John
Old May 16, 2020 | 10:09 PM
rocketscientis's Avatar
Most if not all of that is in LANSING Michigan
...just pulled front rubber fillers & grills for man that did not buy them...rear center & gas door is for certain & sides are possibilities.. These are off an S ...have other fillers that are 75 A body as well
email most preffered..PM is broken
Omishjon4@gmail.com
by chance have you any front plate mounts you could part with ?
thess are available & piece between them as well if indeed you actualy are in need...​​​​​​
Old May 17, 2020 | 05:32 AM
Bill G's Avatar
A specific list of parts needed , along with your exact model , would help..especially with interior parts, as parts varied with models.
Also, a lot of 74 Cutlass parts were the same, or will work.
Some interior panels were shared with other GMs.. some aftermarket interior door panels, etc are out there too.
Joining your local Olds club, if possible, can also help.
Good Luck.
Bill G
74 Salon
Old May 17, 2020 | 10:55 AM
What your body style ??
S or supreme ?& interior colors first two prefrences or requirements please n
thanks
Old May 21, 2020 | 07:59 PM
Eman75's Avatar
Good Luck.
Bill G
74 Salon
Been a very long time I worked on or even messed with a cutlass. How would I find out my exact model. As far as I know it's a supreme...pointed back window not rounded. I'm looking for all the inside moldings around the windows, doors and back windows, and seat belt moldings.
Old May 21, 2020 | 08:00 PM
Eman75's Avatar
Forgot, also looking for the rubber moldings behind the front and rear bumpers
Old May 21, 2020 | 08:23 PM
crimsoncolby's Avatar
Your body tag info will tell you which model you have. Pointed back window is the Supreme body style. I've got some nice used upper plastic pcs; i.e. above the windshield, above the back window, above the door glass, "A" pillars. No sail panels (people will need to know if you have side courtesy lights). No door jamb edge moldings. What type of seats do you have for the seat belt moldings?
Old May 21, 2020 | 08:44 PM
Eman75's Avatar
Courtesy lights inside the car in the back? I do have those in the car. The front seats I do not have bucket swivel seats but the whole seat with the armrest in the middle.
Old May 22, 2020 | 06:52 AM
I'm sure your interior "B" pillar courtesy light lenses are broken. I believe OPGI has repros.
I'm assuming with the seat belt moldings, you are referring to the protective casings around the front floor retractors and inner belts? Or, are you referring to the shoulder strap retractor covers against the headliner? Or, all of the above?
Old May 22, 2020 | 11:00 AM
Way back in th olden days
Before th turn of th century.....I used to assume EVERYONE had a two door A body
either 67 or 68 that needed parts. ..after hunting parts down for no other reason than to know what I got n where its at.... I wised up
Have upper & lower seat belts plastics as well as an S parts car with black interior
You should email me if actualy in need & wish to procure items listed here under parts wanted
Omishjon4@gmail.com
74 + 75 rear rubber outer body Fellers that currently are attached to tail lights removed personally from 74 Supreme Bodied 442 I have a few of a center fillers as well as the gas doors as well in Lansing Michigan where we don't cook rubber in the sun 365 days a year until it's brittle and crumbles into dust but actually maintains elasticity and therefore is most useful for its intended application if you're into that sort of thing
Not only do every rubber body filler for 75 A body , I like many here am in need of parts for my current 73-77 S bodie...seems my hole for 1/4 windows shrunk considderably...so I am in need of both exterior & interior trim for rear/quarter windows...burgundy preffered but all color options offered will recieve th utmost consideration
thanks
Certainly is strange how window hole shrunk into a quadralateral from a triangle & nothin else seems out of proportion.....unless ya hava Y option...then your probly thinkin another thing altogether is strange...
Old May 22, 2020 | 03:00 PM
Be advised that some of the interior plastic trims are not the same between the "S" body style and your Supreme; such as the headliner trims that go above the door glass, the trim above the back window, the sail panel trims that surround the qtr windows and the door jamb edging.
Old May 23, 2020 | 02:40 AM
while you are at it
you might as well continue and explain the rest of the parts that are different in correlation with the two different 2-door body styles
Old May 25, 2020 | 01:58 AM
Or not
Clues available if needed
Old May 25, 2020 | 08:29 AM
I pretty much covered the differences in interior pcs that the OP was asking about. Kick panels the same..."A" pillars the same...Upper windshield molding the same.
mclark68442
Dec 5, 2025 05:17 AM
66-3X2 442
Apr 1, 2015 03:32 PM
KirkALurk
Dec 18, 2014 04:01 PM
demex69
Feb 6, 2013 06:08 PM
