1967 442 radiator shroud
Old Jul 5, 2020 | 01:03 PM
Need a factory shroud for a 67 442, automatic with air. Shipped to Spiro Ok, 74959. Is the Cutlass 330 shroud the same?
Old Jul 5, 2020 | 01:56 PM
nicks1966's Avatar
Shroud is listed in the parts book as v8 with CAC or hd cool so a 330 would be the same, Same part number is listed for 66.
Old Jul 5, 2020 | 02:04 PM
Thanks for the info
Old Jul 8, 2020 | 02:24 AM
rocketscientis's Avatar
66-7 A body fan shroud
after conductin thorough search for this item & narrowly missed 1my buddy bought..having determined repos are crap & dont believe I want 1 around my fan near 4 core under a louvered hood
was fortunate to have located this nice 1 ...just not a fortunate 1 no
My budget was inadequate & inventory available to swap fell short as well
When nothin can be done....I 'm at my best
...if I cant do nothin...it can be done
Guy has hemi & all kinds of items knows volumes
If you are intrested...wil give you th ball & let ya run with it...
Do you need lower mounts as well ?
Old Jul 8, 2020 | 06:43 AM
Johnse31's Avatar
Help
Would your 67 442 happen to be a automatic on the floor ? If so is there anyway you could measure from where the firewall meets the floor back to the shifter front and back bolts and also measure where the console front and back mounting brackets are for the console.? Thank you very much.
Old Jul 8, 2020 | 07:25 AM
The 442 is a friends, cannot answer your question without popping the console. Post your question in the open forums to get an answer from one of the other members.
Old Jul 8, 2020 | 08:09 AM
therobski's Avatar
Eric what is the matter with the one you have? I had to repair a few cracks in mine, and what I did was I got a piece of plastic and used my soldering gun and actually "plastic welded-melted" the cracks with the piece of plastic. works like a charm and strong too.
Old Jul 8, 2020 | 08:20 AM
Its not for me its a for a friend. I asked him if it could be repaired, but I have not seen it.
Old Jul 8, 2020 | 08:44 AM
therobski's Avatar
A mechanical engineer showed me that technique. Simple but it works and the better you get the smoother the repair and less sanding. I used a piece of black plastic and worked out just great. Most of the shrouds left for these cars are damaged somewhat anyway. From my experience 8-9 years ago the fiberglass repos were junk in my opinion and sent mine back...
Old Jul 8, 2020 | 09:14 AM
I've got one of those plastic welders and used it to fix the bumper cover on my sons Mustang. It turned out pretty good.
Old Jul 11, 2020 | 09:26 AM
Never mind on this. Apparently these are hard to come by.
Old Jul 11, 2020 | 09:31 AM
Contact
Info of man that has 67 shroud
phil thompson
989-224 4639
Old Jul 11, 2020 | 11:05 AM
They were rare, not on all of them, they're desirable, and they break. I've got two of them and wouldn't turn one loose for under 250.
Old Jul 11, 2020 | 02:07 PM
Wow Koda, are you becoming a capitalist?
Old Jul 12, 2020 | 09:31 AM
Not for my hobbies, no. I play the stock market. I don't sell Olds parts, although I may after my project gets done.
Old Aug 6, 2020 | 04:48 PM
w30brad's Avatar
What option is CAC ?
Old Aug 6, 2020 | 05:02 PM
w30brad's Avatar
I just found an older post that says C.A.C. is "Car Air Conditioning".
Old Aug 6, 2020 | 08:21 PM
jollyolds's Avatar
climatic air control
Old Aug 6, 2020 | 11:50 PM
The option is not CAC, it's CCC, climatic combustion control, and refers to that years "heat riser" air cleaner that had vacuum valves for air temp.
Old Aug 7, 2020 | 02:43 AM
w30brad's Avatar
Thanks Jolly
The option CAC is referenced on many parts in the Oldsmobile Parts Books.
CAC - Climatic Air Control (Air Conditioning) makes perfect sense for the part numbers it's referenced on
For example, Dashpot 401159
Old Aug 7, 2020 | 03:06 AM
ignachuck's Avatar
Frank Ignachuck
Every parts book I've ever seen calls it Car Air Conditioning:
Old Aug 7, 2020 | 03:20 AM
w30brad's Avatar
Wow, interesting find. Is that from a an earlier book?
Old Aug 7, 2020 | 03:30 AM
ignachuck's Avatar
Frank Ignachuck
1957 Master Chassis Parts Book.
Old Aug 7, 2020 | 03:38 AM
w30brad's Avatar
So maybe they changed it to a more technical term "Climatic Air Control" in the late 60's? Either way, it looks like it means the same thing - Air Conditioning.
Old Aug 7, 2020 | 08:32 AM
I don't see that term in any 1967 literature. The A body line could receive something called C60, Air-Conditioning, Four Season. There was no C.A.C for a 67 A body.
What you're seeing is C61 Comfortron Air Conditioning, available on the bigger cars. This was an early attempt at thermostat regulated AC.
Old Aug 7, 2020 | 09:23 AM
w30brad's Avatar
Not
lunaboy
Jul 11, 2021 04:57 AM
bob provost
May 30, 2020 01:53 PM
phukinartie
Mar 3, 2014 02:16 AM
mcutlass1969
Jul 7, 2009 01:23 PM
Hairy Olds
Jan 9, 2009 06:26 PM
