PDA
View Full Version : Parts Wanted
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. Vacuum T for 1970 quadrajet air horn
  2. '68 442/Cutlass drivers door.
  3. 1967 Cutlass 442 tilt steering column
  4. 70-72 W30 Emblems - NOS (not reproductions)
  5. 1967 Oldsmobile quadrojet
  6. Wanted: NOS Upper Ball Joint
  7. Looking for a qjet for my 68 350
  8. '71 Taillight Buckets
  9. 1967 Delmont 88 Center Link (Drag Link)
  10. 77 Cutlass Supreme need engine and transmission
  11. olds distributor
  12. Rear Bumper 1961-62 F85
  13. Wanted ss2 14x7 wheels
  14. Need 67 Cutlass Lower Door Panel Molding
  15. Rear armrests for 1970 Rallye 350
  16. WTB 70-72 Fuel Gauge Circuit Board
  17. Looking for 1963/1964 LH rear exhaust pipe
  18. Need bumber for a 64 Super 88
  19. 66-67 Cutlass dash vent
  20. 1950 olds coupe
  21. 1970-72 T44 Hood Latch Cover
  22. 1964-66 console parts needed
  23. 1965 club coupe 442 misc parts
  24. Anyone have a 455 for sale/trade
  25. 1966 442 Pulleys- Crank and Water Pump
  26. D-cylinder heads
  27. 70 442 Non-HD cooling Water Pump
  28. Shot in the dark
  29. Vista cruiser inner tailgate stainless
  30. 66 A body parts
  31. 67-72 auto shifter knob
  32. Virgin 403 block needed.
  33. Stereo Radio Multiplexer Brackets
  34. Wanted !! 1967-70 3.42 gm ring & pinion !!
  35. 66 & 67 A-body supreme body trim
  36. ISO Rear view mirror, Left sport mirror, window guide
  37. 394 olds flywheel needed
  38. ISO: 80'-85' Delta 88 rear bumper
  39. 1970-72 shifter
  40. WTB 1965 Cutlass Conv Hold Down Brackets
  41. WTB 68 98 exaust manifold
  42. Need 55 parts
  43. 1972 cutlass supreme drip rails
  44. WTB: top A/C Bracket for '71 Cutlass V8
  45. WTB - 1965 442 AC Hoses, Hose Clamps etc
  46. PNW Need a BOP THM 350 to replace the THM 250C
  47. WTB 14x6 SSll Wheels
  48. WTB: 66 Toronado Fuel Line
  49. 68-72 convertible frame
  50. Wheels....
  51. Dual gate bent stick
  52. ‘72 cutlass drivers door glass
  53. 455 Block
  54. Speaker needed
  55. WANTED: NOS (or gently used) GM Start Shims
  56. Nos gas tank straps
  57. Looking a CI rad tank
  58. TH400 short tail shaft
  59. 70 cutlass split bench parts
  60. ‘54-‘56 heater core
  61. WTB: 70 coupe passenger quarter panel or pair
  62. WTB: 1970 cutlass b pillar post coupe molding
  63. 1948 oldsmobile 76 fender
  64. WTB. 1966 - 88 or 98 fan shroud
  65. Wanted one nice 15” SS1 rim for a spare
  66. BBO tunnel ram assembly
  67. WTB Alternator and PS brackets
  68. Kick down switch for 67 Cutlass 2spd auto
  69. 66-7 A - body P/W MECH
  70. 69 Tach clock circuit board
  71. 1953 303 water pump pulley
  72. 70-72 Cutlass quarter panels
  73. 1966 Starfire wheel well trim
  74. Set of 15 SS 3 wheels
  75. WTB 66 Antenna
  76. WTB Quadrajet
  77. Master Cylinder Secondary Power Piston
  78. 1970 442 W-30 Alternator 1100890 Wanted
  79. 66 cutlass hood nosing chromed potmetal trim....wtb
  80. wtb 66-7 ribbed 442 fan shroud
  81. 69 vista SS trim wanted
  82. 71 headlight surround right side
  83. More parts for GBody needed
  84. 1969-72 NOS Hood Hinges
  85. C heads
  86. 1964 F-85 Deluxe 4 door
  87. 1971 442 Transmission
  88. 1970 olds 98 convertible
  89. 1970 442 Bumper Jack
  90. Exhaust Manifold needed
  91. 66-67 3 groove crank and water pump pulleys needed
  92. 1977 Cutlass Supreme Brougham Dash Clock
  93. 69 radiator support
  94. 1967 442 Alternator Mounting Hardware
  95. Wanted: 1970 442 Alternator - 1100890
  96. '65 Right Rear Door Latch
  97. radiator top plate insulator rubbers
  98. 1987 Ninety Eight
  99. 1967 Oldsmobile Wiring Harness
  100. 66 442 grille bars
  101. wanted 394 rocket flywheel manual
  102. 72 Cutlass Supreme Deck Lid
  103. 67 442 14x6 steel wheels
  104. 1986 Cutlass Supreme Tail Light Assembly
  105. 1970 cutlass bumper
  106. WTB 1970 Cutlass Coupe RT quarter panel
  107. 8 Track Bracket
  108. Diesel camshaft
  109. 48 Olds 98 4-door fender skirts
  110. 48 257 exhaust and intake assembly
  111. 1968 Cutlass/442 driver side hood hinge
  112. 68 Cutlass deck lid trim
  113. Speedometer
  114. 1970 cutlass oem 14 inch trim rings
  115. WTB a set - NOS 70 442 coupe quarter panels
  116. 1968 Cutlass Hood Hinge
  117. Bucket Seats
  118. WTB - 1997 Olds 88/LSS Parts
  119. 71 72 455 1112033 distributor
  120. 66 cutlass fender extensions
  121. 1969 bench seat
  122. Edelbrock 065 Dual quad intake for 455
  123. Delta 88 air cleaner hose
  124. 65-69 4 speed console light
  125. Pedal Pads
  126. 65 Cutlass E wanted
  127. 216 Ignition Coil
  128. WTB notched valve covers
  129. WTB : 1961 / 62 F85 / cutlass baffle
  130. Vista Cruiser Interior Piece
  131. #8 head in DFW
  132. 70-72 deck wing pedestals
  133. Wtb
  134. 73 Olds 98 rear bumper filler panels
  135. 72 convertible top 2nd bow fabric retainer
  136. Wanted Vintage GEIS 12 bolt Chevy diff girdle
  137. tilt and telescopic column
  138. 1965/66 442 body mouldings
  139. 72 Cutlass seat belts tan/brown
  140. Front Coil springs
  141. 57 Shroud
  142. 1977-78 Toronado door panels
  143. Drivers fender for 66 442
  144. NOS 4432791 power window switch
  145. WTB>70 OAI HOOD-W-30 INTAKE & Dual Gate Shifter
  146. WTB Valve Cover Spacers
  147. 1968 cutlass vent window crank spring
  148. Wanted 1970 w30 intake
  149. 365 HEI centerplate
  150. NOS OAI Vacuum Motor
  151. Alliance,Ohio car show need 67 442 bumpers
  152. WTB 1970 442 bypass clamps
  153. 1971 cutlass quadrajet
  154. WTB SS III snap on center cap
  155. WTB 350 Heads, intake, cam for 403 build
  156. Power Steering Pump Pulley - '69
  157. 1969 442 Rear Bumper Brackets
  158. 67 442 bumper cores
  159. 1964 or 65 f85 2 door sedan rear side window channels
  160. ISO Set of Front Upper Control Arms For 1968 Cutlass
  161. 1969 442 reverse light
  162. 69 Heater and AC flex ducts
  163. Rear Window
  164. 70 Rear backup lights and license plate
  165. 65 442 mouldings
  166. Black 455 valve covers
  167. Flexplate,exhaust manifold
  168. 1970 olds 442 with 455
  169. washer fluid level switch
  170. Wanted! A1970 1972 very clean uses sport wheel
  171. 1969 Cutlass convertable booboo
  172. 59 Oldsmobile Dynamic 88
  173. 65 F-85/Cutlass Front Bumper, F-Left Turn Signal Housing
  174. WTB 1980-85 Delta 88/98 coupe doors
  175. 1969 Cutlass console neutral safety switch
  176. Looking for an N.O.S. 4 spoke wheel for my71 w 30
  177. Short list
  178. 65/66 B body Steering wheel
  179. 455 N Crank (Auto) / Edelbrock Performer 2151 Intake
  180. 59-62 Spin on oil filter adapter/housing
  181. 62-63 f85, cutlass, Jetfire Trim rings
  182. 57 olds 98 rocker mouldings
  183. Original 1972 Cutlass Supreme Trunk Lid
  184. Hot Gas Bypass Valve - 58
  185. 70/72 Clear washer fluid container
  186. 455/th400
  187. 71 442 NOS Front Bumper
  188. Wanted ZR radiator tag
  189. T 3 Bulbs
  190. OEM 12-Bolt Posi Carrier
  191. Oil Filler Tube Cap - '69 H/O
  192. 1971 cutlass quadrajet
  193. Trunk Torsion Rods Wanted
  194. 65 bell crank
  195. Hurst lighting rod shifter parts needed
  196. NOS 71 442 Right Inner Fender
  197. ISO rear seat for a 1966
  198. 1969 Hood Latch Pin
  199. 1968 floor shift Speedometer wanted
  200. '48 olds 98 sill plates
  201. NO BS I Still need Olds Frame Mounts to GBody!!
  202. 1968 Cutlass/442 AC/Heater fan control switch
  203. Power Steering Pulley KA 399406
  204. 69,70,71,72 retainers for backup switch on column
  205. 74 hurst olds parts car wanted
  206. WTB : 1961/62 F85/cutlass Left trun signal light
  207. 1964 Olds Cutlass Back up Lens
  208. Seat Belt Bolts
  209. Short List of Parts sought!
  210. Rear Brake Backing Plates
  211. WTB Original 71 OAI Hood
  212. 65 442 PCV assembly from Air Cleaner to valve cover
  213. 65 442 chrome trim
  214. WTB passenger mirror for 69 delta 88
  215. 1969 conv door shell patch
  216. Looking for 74 am/fm 8 track Cutlass radio
  217. 1964 Starfire console and console box
  218. 66 Toro parts needed.
  219. Cruise Control
  220. Need left/right rear wheel well mouldings.
  221. Spiral Shocks
  222. evaporator case wanted
  223. 70’ Supreme Hood
  224. ISO Power Antenna Bushing for 1968 Cutlass
  225. Edelbrock 2711
  226. 1965 Starfire Convertible trim needed
  227. 64-66 shift indicator
  228. 8track
  229. 1970 cruise control 4bbl threaded rod
  230. looking for a 1972 gas pedal
  231. Rear Bumper for 1969 442 or H/O
  232. 1969 cutlass
  233. Rochester BB 2 barrel carbuetor...
  234. Tcs
  235. NOS interior window cranks
  236. Looking for a quick fuel carb
  237. KH, KO, KB Pulleys
  238. 74 Cutlass parts needed
  239. Back seat for a 1966 A
  240. Wheel for 69 Olds
  241. Looking for a running olds 215
  242. 74 cutlass drive shaft
  243. Power Steering Pump Pulley
  244. WTB 403 Trans Am thermostat housing .
  245. 1970 4 Core Radiator Top Plate
  246. GA Heads & OE LH Black Arm Rest Pad
  247. 69 cutlass auto shifter and console
  248. 1969 442 dash
  249. 66/67 K20 Closed CCV Air open cleaner parts
  250. Olds 350 LF9 diesel engine
