Hot Gas Bypass Valve - 58
Old Aug 10, 2019 | 06:18 AM
377rick's Avatar
Question Hot Gas Bypass Valve - 58
Anybody have a hot gas bypass valve for a 58? I can use one from nearby years as it's the internals I need -- have the externals! Fingers crossed!!!
Old Aug 10, 2019 | 09:03 AM
ignachuck's Avatar
Frank Ignachuck
The part number for your 58 is 1998833, group 9.198
If it helps, Original Air rebuilds them, and also sells the kits. I think the diaphragm kit is $63.
https://www.originalair.com/gm-hot-g...equires-15-203
Old Aug 11, 2019 | 12:24 PM
377rick's Avatar
thanks very much for the information and reply . Sadly for me, I have the rebuild kit but have some internal damage to machined parts that need to be replaced -- ; not just the rubber. SO,.....I figure any HG valve on any GM from the period will give me what I need in terms of internals.
R
Old Aug 11, 2019 | 02:29 PM
ignachuck's Avatar
Frank Ignachuck
Nothin's easy!
If I were you, I would call Original Air and see if they have parts for your valve. Also see if parts are interchangeable through the mid to late 50's A/C systems. The folks at Original Air seem easy to talk to.
I may be able to help you if '56 parts will work on your '58. By the way, the '56 part number is 9.198/ 1998807
377rick
Jul 30, 2019 06:12 AM
hullinger
Dec 4, 2016 05:36 PM
Mike H.
Brakes/Hydraulic Systems
Mar 7, 2013 10:48 AM
evans_78
Aug 29, 2011 10:32 AM
joe_padavano
Jul 1, 2009 10:10 AM
