Power Steering Pulley KA 399406
Old Aug 4, 2019 | 07:55 AM
oldsguybry's Avatar
NOVICE car nut
Anyone local have a power steering pulley KA 399406 ?
Milwaukee Wisconsin
Old Aug 4, 2019 | 02:18 PM
cdrod's Avatar
Rodney
I have a KH 399406 that's been bed blasted and powder coated. According to the assembly manuals, it fits '69-'72 engines with AC. Here's a link to my for sale ad:
https://classicoldsmobile.com/forums...y-sale-136486/
Rodney
Old Sep 1, 2019 | 08:46 AM
oldsguybry's Avatar
NOVICE car nut
I have no idea why I put KA on this thread because my pulley is clearly marked KH . I found one refurbished on Ebay for $42
Old Sep 6, 2019 | 07:41 AM
oldsguybry's Avatar
NOVICE car nut
I put the new pulley on and it sits a bit further out now . I'll have to get rid of spacers to get pulley lined up better ..
Old Sep 6, 2019 | 06:06 PM
ILT also sells the KH pulley new for $42. It's the same as the old KA which was correct for your car.
Old Sep 8, 2019 | 06:07 AM
oldsguybry's Avatar
NOVICE car nut
The one I bought doesn't have the three holes on the face of the pulley which will be fun to get back off if I need too . I thought those three holes were for the wheel puller to hang on too .
How's everything been for you Allen ? How's the car running ?
Old Sep 8, 2019 | 07:51 AM
No, the 3 holes are for using a socket to tighten the belt. You should have enough room behind the pulley you bought to tighten that bolt?
I just pulled my driveshaft to fix the trans output shaft seal leak and the end caps fell off the U joint at the back. Time to redo u-joints.
Old Sep 11, 2019 | 06:07 AM
oldsguybry's Avatar
NOVICE car nut
The same thing happened to me when I put the rebuilt transmission in my car . The caps fell off and little rollers went everywhere. I bought new u-joints after that
Old Sep 11, 2019 | 06:11 AM
oldsguybry's Avatar
NOVICE car nut
I wonder what causes my transmission to leak after the car sits for long periods of time . I installed the 455 and transmission on two separate occasions and still have the same issue . I think it comes out the overflow tube
Old Sep 11, 2019 | 06:46 AM
2 common leak points: The output shaft seal, and the driven gear adapter O ring and inner seal. Both are relatively easy. Be prepared with a catch bucket when you pull the adapter.
Old Sep 11, 2019 | 08:36 AM
oldsguybry's Avatar
NOVICE car nut
Cool thanks
oregontopcat
Jan 26, 2020 06:48 PM
Ap6954
Sep 7, 2019 01:46 PM
mccorry
Nov 30, 2016 05:01 AM
Raydermiike
Sep 19, 2013 07:50 PM
D Appeldorn
Dec 4, 2011 11:16 PM
