WANTED: NOS (or gently used) GM Start Shims
Old Sep 23, 2019 | 08:41 AM
WTHIRTY1's Avatar
Escape From The Ordinary
Need GM / OEM starter shims for the starter on my 1970 Cutlass. Let me know what you have.
Old Sep 23, 2019 | 09:33 AM
You can buy shims at any napa or most auto parts stores.
Old Sep 23, 2019 | 09:44 AM
WTHIRTY1's Avatar
Correct, you can. I don't want Dorman brand shims on my restoration. Thanks
Old Sep 23, 2019 | 10:31 AM
stellar's Avatar
stellar
How are they different? Just curious.
Old Sep 23, 2019 | 11:03 AM
edzolz's Avatar
Not only that who would go so far as to check starter shims when judging for show.
Old Sep 23, 2019 | 11:26 AM
Run to Rund's Avatar
I wanted the best ground for my starter, so I cleaned the block and starter, and made a copper shim. Just buy the copper sheet in Lansing, and fill the tires with Lansing air. lol
Old Sep 23, 2019 | 11:35 AM
WTHIRTY1's Avatar
No harm in wanting something correct, right? The shows I participate in have that level of scrutiny.
Old Sep 23, 2019 | 11:37 AM
WTHIRTY1's Avatar
Do you have the shims I’m looking for since this is a parts wanted ad? Or are you just attempting to be humorous with your played out “Lansing air” gaffe.
Old Sep 23, 2019 | 02:57 PM
ROCKETMAN269V's Avatar
GM Starter Shims
I have a number of oem shims. Email me to discuss. Thanks, Bob.
OldsAl's Avatar
You are all missing the point here. Look at his restoration post and then think of something intelligent to say. The level and attention to detail is off the chart. That’s his choice but this car will stand among very few.
Old Sep 24, 2019 | 03:04 AM
alain's Avatar
Like Al said this is WTHIRTY1 restoration his way let us try to help him
Alain
Old Sep 24, 2019 | 05:42 AM
Burd's Avatar
I have a stack of GM shims.
Old Sep 24, 2019 | 06:30 AM
edzolz's Avatar
I have never heard of any show where the judges were allowed to remove any part of the vehicle being judged. That being said, how do the judges know the shims are not GM.
Old Sep 24, 2019 | 06:35 AM
WTHIRTY1's Avatar
Guess we don’t roll in the same circles.
Old Sep 24, 2019 | 06:39 AM
I have disassembled at least a couple dozen 66-7 400s and 425s, and 455s. None had a starter shim. Fifty years later we have to wonder how many of the shims we might find are OEM. Have you determined what thickness you need for correct engagement of the starter drive gear to the flywheel teeth?
68-W46's Avatar
I've never seen an Olds that needed a shim on the starter yet....
Old Sep 24, 2019 | 06:41 AM
WTHIRTY1's Avatar
1/16 and 1/32
Old Sep 24, 2019 | 06:42 AM
WTHIRTY1's Avatar
And because you’ve never seen it, it must mean it’s not possible? Is that the point you’re trying to make?
Old Sep 24, 2019 | 06:46 AM
68-W46's Avatar
If I say so you can put it in stone.....lol
Old Sep 24, 2019 | 06:48 AM
WTHIRTY1's Avatar
And who are you?
Old Sep 24, 2019 | 06:52 AM
Bfg's Avatar
Bfg
Do you buy genuine GM oil for your trailer Queen? If not aren't you risking the chance that your gonna be deducted points!
Old Sep 24, 2019 | 06:55 AM
WTHIRTY1's Avatar
Zinger! But I should expect that type of response from the guy making posts about what color paint to use on his gas tank...
Old Sep 24, 2019 | 08:03 AM
Everybody has their own way to restore a car, if you have nothing to offer please keep comments to yourself.
Old Sep 24, 2019 | 09:20 AM
stellar's Avatar
stellar
I think it is great that there are guys wanting to restore a car to original down to the smallest detail. Starter shims would be a small detail. How often do you get to see a 50 year old car as it was the day it was born. The time money and research needed to do this would be overwhelming. I have a stack of starter shims of different thicknesses some are OE and some are aftermarket (not Dorman) that I bought many years ago.The originals are used from cars that I have worked on. I had a starter alternator rebuild shop for 40+ years. The majority of the shims I have all look the same shape even the aftermarket shims I have. I would like to know what the difference is so I can sort them. Can you tell me what the difference is? If you prefer to keep it a secret to keep an upper hand for judging I understand. The ones I have are the same, other than various thickness. Both ends, length, and width are identical.Could there be a difference in composition? After many years of rebuilding and installing starters I have seen a few Olds that needed shims. In most cases it was because an aftermarket housing or low quality drive had been used.
Old Sep 28, 2019 | 09:18 PM
WTHIRTY1's Avatar
For the naysayers...
Still looking for an original 1/16 and 1/32 shims. Let me know! Thanks.
Old Sep 29, 2019 | 07:22 PM
Gerald Nickels's Avatar
First off I have never used shims before in my life EXCEPT CHEVY uses them. Get another starter period
Gerald
Old Sep 29, 2019 | 07:49 PM
WTHIRTY1's Avatar
Gerald
Aren’t you the guy that put a “le bra” on your Cutlass?
Old Sep 30, 2019 | 04:08 AM
Bfg's Avatar
Bfg
There is nothing wrong by putting a "Le Bra" on your car. The headlights tend to sag on older cars!
Old Oct 17, 2020 | 06:57 PM
ChillyJ's Avatar
Looking for the same if anyone has any remaining. OEM only. Thanks.
Old Oct 17, 2020 | 07:30 PM
Burd's Avatar
Gerald
pontiac uses them, BOP all use them, as for gm shims, how can you possibly tell the diff, my Pontiac has one on from the factory, it has no marking on it. I have a stack from my mechanic, he has an all gm repair shop. I’m not sure how you know what is factory.
your factory manual should have a page showing how to measure for the correct shim. It does in the Pontiac manual.
Old Oct 18, 2020 | 08:31 PM
  #31
paulolds's Avatar
Shims
Jimmy asked me to judge his car, I will be looking for correct GM shims. 😉
Old Oct 19, 2020 | 06:10 AM
  #32
edzolz's Avatar
Are you going to pull the starter to verify the shims are genuine GM manufacture?? Never heard of a car judging where any part was pulled to verify authenticity, even concours judging.
Old Oct 19, 2020 | 06:11 AM
  #33
Burd's Avatar
Let’s see a correct shim next to a aftermarket shim
Old Oct 19, 2020 | 06:15 AM
  #34
Burd's Avatar
To go along with the GM shim, get a tank of correct air from the city where your car was made in and put in the tires. If your going correct, all must be done.
Old Oct 19, 2020 | 06:33 AM
  #35
stellar's Avatar
stellar
Sorry, but that won't pass the sniff test. Much less air pollution now than back then. I would also like to see what an OE shim looks like. I may have a few.
Old Oct 19, 2020 | 08:23 AM
  #36
Burd's Avatar
Lol, your rite.
I’ve never seen any maker marks on any shims.
there’s a Norwood private show in Ohio, the guys let the air out of their tires and fill,up with Norwood air. Lol. Why not
Old Oct 19, 2020 | 08:26 AM
  #37
WTHIRTY1's Avatar
fa·ce·tious
/fəˈsēSHəs/
adjective
  1. treating serious issues with deliberately inappropriate humor; flippant.
    "a facetious remark"
You guys are funny. Yes, you can tell a difference. No, parts won’t be removed.
Old Oct 19, 2020 | 08:57 AM
  #38
Bfg's Avatar
Bfg
I waiting for someone to come up with reproduced air, I think it might go over big in the trailer queen community
Old Oct 19, 2020 | 09:03 AM
  #39
WTHIRTY1's Avatar
You obviously have some sort of bias against factory restored cars. Please, tell us how these cars were meant to be driven and how you drive your car all over the place.
Old Oct 19, 2020 | 09:34 AM
  #40
stellar's Avatar
stellar
yes or no on this? not a dorman for sure
