WANTED: NOS (or gently used) GM Start Shims
Do you have the shims I’m looking for since this is a parts wanted ad? Or are you just attempting to be humorous with your played out “Lansing air” gaffe.
You are all missing the point here. Look at his restoration post and then think of something intelligent to say. The level and attention to detail is off the chart. That’s his choice but this car will stand among very few.
I have never heard of any show where the judges were allowed to remove any part of the vehicle being judged. That being said, how do the judges know the shims are not GM.
I have disassembled at least a couple dozen 66-7 400s and 425s, and 455s. None had a starter shim. Fifty years later we have to wonder how many of the shims we might find are OEM. Have you determined what thickness you need for correct engagement of the starter drive gear to the flywheel teeth?
Zinger! But I should expect that type of response from the guy making posts about what color paint to use on his gas tank...
I think it is great that there are guys wanting to restore a car to original down to the smallest detail. Starter shims would be a small detail. How often do you get to see a 50 year old car as it was the day it was born. The time money and research needed to do this would be overwhelming. I have a stack of starter shims of different thicknesses some are OE and some are aftermarket (not Dorman) that I bought many years ago.The originals are used from cars that I have worked on. I had a starter alternator rebuild shop for 40+ years. The majority of the shims I have all look the same shape even the aftermarket shims I have. I would like to know what the difference is so I can sort them. Can you tell me what the difference is? If you prefer to keep it a secret to keep an upper hand for judging I understand. The ones I have are the same, other than various thickness. Both ends, length, and width are identical.Could there be a difference in composition? After many years of rebuilding and installing starters I have seen a few Olds that needed shims. In most cases it was because an aftermarket housing or low quality drive had been used.
your factory manual should have a page showing how to measure for the correct shim. It does in the Pontiac manual.
Sorry, but that won't pass the sniff test. Much less air pollution now than back then. I would also like to see what an OE shim looks like. I may have a few.
/fəˈsēSHəs/
adjective
- treating serious issues with deliberately inappropriate humor; flippant.
"a facetious remark"
You guys are funny. Yes, you can tell a difference. No, parts won’t be removed.
Like Al said this is WTHIRTY1 restoration his way let us try to help him
