Power Steering Pump Pulley
Old Jul 26, 2019 | 01:05 PM
bob provost's Avatar
Looking for a P/S pulley for a 67 400 engine with A/C .6 1/2" dia. with a keyed shaft. Single groove. Thanks Bob
Old Jul 26, 2019 | 01:24 PM
70sgeek's Avatar
'72 Cutlass ragtop
you may find that in an aftermarket part on Ebay or other online vendors - I recall I purchased one new as described in that diameter for under $30 last year for eventual install on my 72' 350 pump.
Old Jul 26, 2019 | 01:59 PM
Thanks, I bought one off ebay but it dosen't line up with the other pulleys
Old Nov 15, 2019 | 06:51 PM
rocketscientis's Avatar
OEM P/S pulley
Hav those if your still in need & devised method to remove without damading things as well
Pls call or txt 989 721 9432
Old Nov 16, 2019 | 10:53 AM
lemoldsnut's Avatar
Email me direct
lemoldsnut@aol.com
There is two different pulleys.
1- for a non-ac non smog car
1 for a ac or smog car
I might have it
Larry
Old Nov 26, 2019 | 06:31 PM
PS pump pullry
If still in need I may hav it
pls call or txt 9897219432
Old Nov 26, 2019 | 06:34 PM
P S pully extraction
If you cant remove pully easily , take care th resivour dont suffer as a result
Engineered this devise & a heated pulley make pre 68 p/s pulley extraction consist of ZERO curse words
Old Jan 25, 2020 | 04:55 PM
Hotrodder06's Avatar
Power steeering pulley
I'm in need of a replacement pulley for non-AC car. 5 1/2 dia, 5/8 shaft, keyway, with 1 5/8 Inch offset. Still available????
Old Jan 26, 2020 | 05:55 AM
ROCKETMAN269V's Avatar
What is the application? Thanks, Bob.
Old Jan 26, 2020 | 06:58 AM
1967 Olds Cutlass Supreme, 5.4 L engine (330 ci)
mother$hip89
Sep 24, 2019 04:27 PM
Olds luvr
May 13, 2016 06:37 PM
68442
Sep 4, 2015 10:10 AM
The Flash
Apr 21, 2014 11:03 AM
oldsonharmont
Suspension & Handling
Feb 9, 2010 06:35 PM
